11-05-2012, 02:40 PM
#3211 |
I been called a Nut Job..
Oddometer: 1,816
LexLeroy, those are some beautiful had made parts.
Nitro Acres, nice welds. I got no rhythm...... My son and I have a job shop. We tig as much as we can. David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys ![]() There is a seat for everyone. |
11-27-2012, 04:38 PM
#3212 |
displaced Jeep guy.....
So you remember those oxy-fuel cylinders I came across a couple months ago? Yeah- I also scored two sets of portables, cheap.
I hae been an oxy-acetylene cutting FOOL over the last month. Trying to figure out brazing now- I blew through an oilpan I was trying to braze a fitting onto. I think I should have used a welding tip, not the cutting head (duh!). To my credit, I didn't activate the cutting jet. I still have to go get the big bottles filled. That's going to be a pain in the ass- local shops won't fill them if you don't have a pickup bed to put them in. Did the gent that was trying to use a pressure reg on a Lincoln 3200HD ever get the code broken on settings and such? I would like to give gas-MIG another shot.
Interested in a Charleston, SC ADVdinner? |
11-28-2012, 12:10 PM
#3213 |
Semi-Occasional
Oddometer: 1,534
I've got a Hobart 110v wire feed welder (with gas). I'm looking to weld up some exhaust pipes. I am NOT a highly skilled welder.
I'm looking for technique tips on welding mild steel pipes together. I found this YouTube vid that seems to make a lot of sense to me, at my skill level. Rather than try to lay a bead, the guy makes a series of tack welds around the tube. This strikes me as a way to really control what I'm doing. http://www.youtube.com/watch?v=_v_6j...eature=related Thoughts on this approach? Better suggestions...?
'74/'70 R98/6/GS Traveling Bike (construction under way) '91 Bill Holland Steel w/Dura Ace |
11-28-2012, 03:45 PM
#3214 | |
Boring Old Fart
Oddometer: 814
"I don't want a nickel... I just wanna' ride my motor-sickle." Arlo Guthrie LexLeroy screwed with this post 11-28-2012 at 04:17 PM |
11-28-2012, 04:55 PM
#3215 | |
Oddometer: 1,816
A series of tacks would be a series of welds made to break off. I weld exhaust with an SP100 turned down C 3 . I start at the top and make my way down. One pass each side. Make a dry pass to see where the gun will fit if its on the car. David
11-28-2012, 09:02 PM
#3216 | |
aka Road Monster
A 'tack' also needs to be strong enough to hold the parts in alignment and withstand the pressure of coaxing the rest of the weldment into alignment. And withstand the stresses of welding once the fit-up is complete.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
11-28-2012, 09:13 PM
#3217 |
Semi-Occasional
Oddometer: 1,534
What I mean is to use a series of short welds rather than a long bead.
11-29-2012, 08:59 AM
#3218 |
This will work fine, it's how I built the exhaust on my Jeep. Butt-welded tubes and short tacks. It's been bounced off of rocks and, while the tube has been squashed in areas, the welds have NOT failed.
Sent from my MB886 using Xparent Green Tapatalk 2
11-29-2012, 09:00 AM
#3219 |
Oddometer: 1,816
What I am trying to say is learn the machine. Set it so you can run a bead. It is the right welder for the job. .023 ER70S-6 wire and c/25 gas. I do a lot of exhaust.
If its too hot and you continually have to stop then turn the machine down. If you are almost blowing through then the heat is right. Have fun and enjoy the machine. Sent from the phone in my shoe. Maxwell Smart.
12-02-2012, 04:44 PM
#3220 | |
JockeyfullofBourbon
Oddometer: 5,645
In other words, tacks hold together only when subjected to a small force. And when the gap isn't right, the fitter will simply break the tack and have the welder start over.
"So what makes this protest different is that you're set to die, Bobby?" --May well come to that. "You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?" -- It's in their hands. Our message is clear. They're seeing our determination. |
12-02-2012, 05:12 PM
#3221 |
Paint it black.
Oddometer: 12,863
It's fine for exhaust, don't weld a roll cage like that or anything your life depends on. We call that WyoWelding(Wyotech teaches that and it's technically wrong), the weakest part of a weld is the start when it's the coldest and that technique gives you a full weld of cold starts...wrong, but fine for exhaust. |
12-02-2012, 05:26 PM
#3222 |
MotoBiggots Suck
Oddometer: 372
If a Tack was a Weld, it wouldn't be called a Tack....Tacks are to hold stuff together till you Weld it....a bunch of tacks stacked ontop of each other is Not a Weld.
Britt Lynn NitroAcres Ball Ground Ga |
12-02-2012, 07:17 PM
#3223 |
aka Road Monster
It all comes down to what you are welding.
A tack can be anything from a quick zap from a wire machine, think exhaust system, to hold the parts together. Or an actual weld such as needed to hold two pieces of pipe in alignment for welding. Or a short weld to keep two pieces of sheetmetal from warping so far apart that they can't be welded. Or heavy (1") Plate from warping from the heat input. Some tacks can be small and light and some need to be considerably more substancial it all depends on the application and circumstances.
12-03-2012, 11:09 AM
#3224 | |
former quadtard.
Oddometer: 490
i don't know how to ride a bike...yet XT225 - short, fat, and slow; it’s my motorcycle twin. F650 GS Dakar -little taller, lot heavier, and much faster. |
12-03-2012, 01:10 PM
#3225 |
n00balicious
Oddometer: 2,912
Most (if not all) NASCAR chassis are MIG welded. A quality MIG weld is more than strong enough for roll cage work as well as suspension components. I've seen my share of crappy TIG welds in offroad racing. Multiple pass welds where the root pass is cold and fills gaps in poorly notched/fitted tube and then a "sic Bro weave" washed over the top. Total crap strength wise, but looks like a million bucks.
"I couldn't wait for success, so I went ahead without it." |
