01-15-2013, 06:40 PM
#3301 |
Oddometer: 127
Can anyone tell me if this gas is 100% Argon or a 75/25 mix by looking at the label. I know it says Argon , but can't remember if my old bottle specified it was a 75/25 mix. This is a new bottle and just doesn't seem correct. It may just be me though.
01-15-2013, 06:56 PM
#3302 |
aka Road Monster
It's Argon.
If it was 75/25 or any other mix the label would indicate what and the % of each.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
01-15-2013, 07:05 PM
#3303 |
Oddometer: 127
Thanks fxstbiluigi
I knew it didn't seem correct.Guess a trip to the welding supply is in my future. The reciept states Ar/CO2 mix. |
01-15-2013, 07:18 PM
#3304 |
Beastly Gnarly
Oddometer: 376
One tip-off is UN1006, which is the (united nations) number for argon gas: http://en.wikipedia.org/wiki/List_of...s_1001_to_1100
The second is the word Argon without Carbon Dioxide or CO2 beside it. They gave you the wrong gas. |
01-15-2013, 08:06 PM
#3305 |
Oddometer: 127
Yeah thats what I thought, just did not pay attention to the old tank. "ARGON" on the label with nothing else should have been a clue
01-15-2013, 08:10 PM
#3306 |
Oddometer: 162
you dont need gas when you arc
Takes longer to learn arc but worth it rather change a rod size then a spool domains screwed with this post 01-15-2013 at 08:17 PM |
01-16-2013, 04:32 PM
#3307 |
Oddometer: 127
Use my little mig 95% of the time, but have the option of arc (stick) with this old dog if need be,
01-17-2013, 07:17 PM
#3308 |
Oddometer: 119
I've got not exactly a welding question but you should be the right group of guys to ask.
I'm looking for a portable rig I can use for those times when I'm in the middle of tearing something down and need to get a fastener red hot. Taking a motorcycle to work's oxy/act rig isn't always feasible when it's half torn down and getting the resulting broken off bolts out has not a bit of fun. Is a portable oxy/acetylene rig the most sensible choice? Recommendations for a red hot rig? |
01-17-2013, 07:42 PM
#3309 | |
n00balicious
Oddometer: 2,944
"I couldn't wait for success, so I went ahead without it." |
01-17-2013, 09:38 PM
#3310 |
Oops...
My 1/8" plate is now about an inch thick...
Getting better. I think if I had a smooth surface to start with my beads might actually look half decent. As it is, I get a nice puddle going and then hit a hole and muck it up. Stupid chunk of metal takes forever to get hot enough to carry a puddle and then I can get 2 or maybe 3 passes in before it's too hot. Think I'm to the point now that if I had a pedal I could do a lot better job... any suggestions for me? Hows it lookin?![]()
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
01-18-2013, 03:40 AM
#3311 |
I been called a Nut Job..
Oddometer: 1,851
I suggest you visit a scrap yard and find some more aluminum.
Looking good, Keep it up. David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys ![]() There is a seat for everyone. |
01-18-2013, 06:00 AM
#3312 | |
displaced Jeep guy.....
Something you may want to consider: oxy/propane. You will be able to use the same torch and will be able to get fuel gas easily at any place that sells propane for bbq grills. You won't be able to weld with it, but it actually cuts faster than acetylene and is much safer to store in a residential setting. With very little practice you will be able to heat to red hot, and if necessary, 'wash away' the bits of steel you don't want. I have actually saved a few bolts by washing off the stuck nut without damage to the threads. Sent from my MB886 using Xparent Green Tapatalk 2
Interested in a Charleston, SC ADVdinner? |
01-18-2013, 07:00 AM
#3313 | |
Oddometer: 1,851
Once you get the hang of it, you can weld, braze or cut with the torches. All you need are the proper tips. My first welder was a set of "Metal Master" torches. I used them until I bought an engine drive. Its by far the best way to learn to weld. Once you master torch welding, stick and tig are easy. Torches new cost me about $300 plus tank rental or purhase depending on your gas supplier. Things can be had much cheaper from harbor freight or tractor supply. I think both even sell tanks. 30 years later I am still using those torches. David
01-18-2013, 07:43 AM
#3314 |
Sleep, Wrench, Ride
Oddometer: 4,521
Considering the surface you're working on and that you don't have a pedal, it looks great. I don't see any grease smudges on your work either; did you find a new pair of gloves?
My scrap guy came recently and cleaned me out. Otherwise I would mail you some more pieces to work on. Hopefully I'll be building an alu skidplate today, maybe I'll have some decent scrap left over...
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
01-19-2013, 12:05 PM
#3315 |
Old Enough To Know Better
Oddometer: 5,527
Question for the oxy-acetylene folks: How often should I be taking my torch in to have the o-rings serviced/replaced? Its a Victor set and is only used sporadically for home/hobby use for cutting and heating.
TIA
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
