Old 04-07-2013, 08:37 PM   #3421
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
I guess I'm confused about my torch setup, there is just 3 lines, gas, coolant supply, coolant return.
Is the copper line inside of one of the coolant lines?
Jayrod1318 is offline   Reply With Quote
Old 04-07-2013, 08:46 PM   #3422
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
That's my understanding. Someone will be along in a minute...................
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-08-2013, 03:03 AM   #3423
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,536
Yes!
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is online now   Reply With Quote
Old 04-08-2013, 05:09 AM   #3424
small_e_900
Amanda carried it
small_e_900's Avatar
Oddometer: 1,825
Yes.
In the last two years, I melted two, because I'm a dumbass.
Anyone figure out a way to automate the water flow so that an idiot who always remembers to plug-in the water cooler but often forgets to turn it on can save himself the embarasment and expense of replacing the torch lead?
____________________
The highest function of love is that it makes the loved one a unique and irreplaceable being.
Tom Robbins
small_e_900 is offline   Reply With Quote
Old 04-08-2013, 06:38 AM   #3425
David R
David R's Avatar
Oddometer: 2,536
Originally Posted by small_e_900 View Post
Yes.
I did it once. The cost of the hose and time it takes to change it are enough to remember. I now have two tig machines. Now if one breaks I can keep working.
Some machines will not turn power if the water solenoid is not on.
Sent from the phone in my shoe. Maxwell Smart.
Old 04-08-2013, 04:27 PM   #3426
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
I got the pump to work, it had dried out coolant sticking the vanes. I took it off and soaked it in some vinegar and hot water. I thought I needed a new pump, a quick google search showed that they use this PROCON pump on espresso machines, They get gunked up sitting for a long time and people soak them in acid to free them up. worked for me!
She plugs into the back of the unit, so when you flip the power switch on the welder it turns on.
Now I just need some argon. Pretty sure the cylinder I have is out of date, it also has 750psi of 75% argonx25% co2 mix. Any takers in Fort Collins?
How much is a large tank of argon going for these days if you own the tank? I don't want to get screwed.
Old 04-09-2013, 07:01 PM   #3427
redprimo
Oddometer: 487
In California a full tank of argon runs about $120.
For those that are prone to melting power cables on water cooled TIG Torches they make a brass fitting that has a fuseable link that melts before you fry the cable. Last one I bought was about the same price as a power cable. The replacement fuse strips are only a couple of bucks for a package.
redprimo is offline   Reply With Quote
Old 05-13-2013, 09:07 PM   #3428
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,097
Yes three lines black hose has gas usually 100% Argon with right hand threads
Second line is red has the conductor inside of it with left hand threads for water
Third line blue is return line also left hand threads for water.
Dont run the torch without the pump on. Even if there is water in your lines. You wont have very many seconds to weld without a pump running. Most Lincoln TIG rigs have a switched AC socket in the back to hook a water cooler into if it doesnt have one already built in.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 05-14-2013, 01:40 PM   #3429
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,590
Remove the switch ... so that as soon as you plug in the cooler, the coolant starts circulating?
Pike Bishop is offline   Reply With Quote
Old 05-14-2013, 02:57 PM   #3430
small_e_900
Amanda carried it
Oddometer: 1,825
Well, Duh.
So simple it's brilliant.
Thanks.
Tom Robbins
Old 05-19-2013, 06:42 PM   #3431
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Finally had a few minutes to try out my free to me lincoln tombstone welder, and the 7018 AC welding rod that larryboy gave me- mucho thanks to that, I tried welding with the old 7018 rod that was given to me with the welder, it's really difficult to start and keep an arc. With the 7018 AC, it came pretty easy.
And I see that it's much easier to weld thick metal than thin stuff with a stick welder (I knew that before, just confirmed it I guess).
So here's a picture:
Not sure if you can really see much, but let me hear the criticism. . . . top weld on the lower piece was my last weld on the thicker steel, it looks ok to me for the first 20 minutes of arc welding, but I need to figure out the pinholes I get once in a while- I assume it's inconsistent arc length? I've found that it's easier for me to weld backhand, which is the opposite of how I learned to oxy-acetylene weld. Probably because the filler rod is in the opposite hand.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-19-2013, 06:47 PM   #3432
David R
David R's Avatar
Oddometer: 2,536
Zac
For first welds they look good.
I would work on keeping a shorter arc. I see some spatter that is usually caused by too long of arc or dirty metal.
Slow down a little and don't mess with the thin stuff unless you have too.
Keep at it.
Old 05-19-2013, 06:51 PM   #3433
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,972
Yeah, 7018 is a drag arc type of rod...strike the arc by dragging, then you want to stay almost in contact while welding.
Old 05-19-2013, 06:54 PM   #3434
slackmeyer
slackmeyer's Avatar
Oddometer: 3,125
Keep at it.
Thanks. It seems like once I get an arc started, I can almost keep the rod coating touching the metal to keep the arc the right length. I was noticing that as I was welding.
Any tips for the thin stuff if I do have to? Or is welding <1/8" with a stick just not done any more? I have some 3/32" rod, it's a lot harder to keep up with than the 1/8".
Zak
ktm
old bmw
others
Old 05-19-2013, 06:58 PM   #3435
slackmeyer
slackmeyer's Avatar
Oddometer: 3,125
Looks like you confirmed my suspicion while I was posting. . . . thanks for the welding rod, we'll see if I just use the whole lot of it practicing or not. . .
Zak
ktm
old bmw
others
Times are GMT -7.   It's 04:48 AM.
