Old 09-12-2013, 05:50 PM   #3586
Addicted
To Riding
Addicted's Avatar
Oddometer: 254
Hmmm. I will have to start using my respirator when I'm doing stainless. Never heard its particularly bad before. I better keep reading this thread!
Adventure commuter 5 days a week.
'09 WeeStrom
'08 690 Enduro, '08 CRF150R Plated
'09 GG 280 Trials, '97 GG 270 Trials
'74 Jawa Californian
Addicted is offline   Reply With Quote
Old 09-12-2013, 05:56 PM   #3587
jules083
jules083's Avatar
Oddometer: 3,968
Yeah, it's pretty rough. I know that we are just now learning the effects of it, it's hard to say just how much we don't know.
I've work air moniters at work a few times while welding stainless. A box fan sitting in front of you pulling the smoke away does wonders.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 09-12-2013, 05:58 PM   #3588
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 524
Driving in rush hour traffic windows down on a freeway isn't good for you either...or second hand cigarette smoke...then there is the smoke off a BBQ Grill...deadly.
Being born will lead to death.
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres is offline   Reply With Quote
Old 09-12-2013, 07:43 PM   #3589
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,598
I forgot one question.
I am going to use propane from time to time as an alternative to acetylene for cutting and preheating. For welding/brazing I will use acetylene.
The reason for this is twofold - propane is cheaper and has more BTUs, plus I am getting a large tank for heating the shop.
So, properly regulated, I should be able to use the propane off the LPG tank? I only need like 5 PSI right?
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 09-12-2013, 07:49 PM   #3590
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,347
I don't know for sure, but I think if you use propane you will need different regulators AND tips... Might want to look into that.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 09-13-2013, 02:59 AM   #3591
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,538
MY acet regulator screws right onto the propane tank. If you use acet tips for cutting you will do a lot of cursing. I don't think it has more BTUs.
I did buy some propane tips for the cutting torch. They work, but you can't beat acet. I don't mind paying for the better gas, it makes my life easier.
About the welding fumes.
A few problems I have. Yesterday I replaced a weld on cutting edge. The new edge was painted, so I ground the paint off where I was going to weld and 1/4 to 1/2" more. The paint still burned from the heat. Fumes are nasty. I have the same problem with galvanized. Grind it off but it still burns off on the back side of your piece.
I switched from mechanic to weldor. Mechanic has it own hazards. Battery acid, exhaust fumes, raw gasoline, moving parts and working underneath things that are jacked up. I still have all my fingers. :)
Just try and get workers comp insurance for a welding shop....
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R screwed with this post 09-13-2013 at 03:05 AM
David R is online now   Reply With Quote
Old 09-13-2013, 07:37 AM   #3592
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,476
I find it amazing how much misinformation exists about the properties of oxygen propane and oxygen acetylene gas temperatures. One (more) accurate source is here - but it still has some conflicting information: http://en.wikipedia.org/wiki/Oxy-fue...ng_and_cutting
Another is to go out and get an older Linde book on oxy-acetylene or read the esab book online: http://www.esabna.com/EUWeb/oxy_handbook/589oxy2_4.htm
I wish some of the myths on web pages and message boards about propane were true. But they aren't. One detail about cutting with oxy-propane is that it has a 4.5:1 oxygen to fuel ratio compared to 1.5:1 for oxy-acetylene; which means acetylene cutting uses much less oxygen. Good luck!
Stan_R80/7 screwed with this post 09-13-2013 at 08:05 AM
Stan_R80/7 is offline   Reply With Quote
Old 09-13-2013, 07:58 AM   #3593
Firemanmike69
Firemanmike69's Avatar
Oddometer: 125
If your looking at alternative fuel gasses,we just switched to propylene, it uses the propane regulator and hose but it's own cutting tips and rosebuds. So far we love it compared to acetylene
Firemanmike69 is offline   Reply With Quote
Old 09-13-2013, 09:23 AM   #3594
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,598
BTUs depend on the volume measurement you use.
Per CF propane has more BTUs, per pound about the same.
http://www.engineeringtoolbox.com/he...ses-d_823.html
Then you have to compare the cost - I believe propane is cheaper (not to mention any possible savings of oxygen.
You can use propane for cutting and pre-heating if you use the right tips and technique (or so I have read), but not for welding as the flame does not produce a shielding gas like acetylene does when it burns with oxygen (again, I read this - I am going to go with it).
I am going to have propane anyway for the heating and possibly other uses in the shop (possibly metal treating of various kinds), so why not use it if it works? I am given to understand that a lot of metal shops use it for cutting and pre-heating if they do a lot of that.
'09 Husaberg FE570
'99 Beta Alp
Old 09-13-2013, 09:26 AM   #3595
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,598
I figure if I have it then I will use it, but I don't work as a welder or fabricator - I am a code monkey (I write software). I used to be a prof. diesel mech and I do have some welding skills and training. I have a big project coming up that I decided it would be best to do myself - if I can get the first part (make an aluminum flatbed for my truck) done myself then I will tackle the second part.
'09 Husaberg FE570
'99 Beta Alp
Old 09-13-2013, 07:55 PM   #3596
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,347
So now we're talkin oxy HYDROGEN welding, eh?
-Charles De Mar.
Old 09-13-2013, 09:52 PM   #3597
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,598
Haha.
No - i'll use MIG for most of it I think. Maybe TIG for some stuff.
The truck has this huge steel HD bed on it now - it was a farm or construction truck. For my purposes I don't need the steel bed because all I will be doing is putting a camper on it, or hauling light stuff if the camper is not on it. I might not even really need the bed actually - I might just mount the camper on the frame instead.
Either way, the steel flatbed on it now isn't needed and is way too heavy. I might sell it or use the steel for something else.
Selling it as scrap isn't even worth the time as I would at best get 10 cents per pound. The bed has some nice 1/4 or 3/16 inch diamond plate sheet, then of course the frame and under the frame some heavy i-beams to mount to the truck frame and the hitch mounting, so it is worth salvaging some of that and reusing it.
I was going to get a mil-surplus S280 command shelter and use that as the camper, but then I thought about all the mods I would want to do to the shelter, and the fact that the camo paint on it is toxic, and decided it would be better if I started from scratch instead - then I could build it exactly the way I want it.
'09 Husaberg FE570
'99 Beta Alp
Old 09-14-2013, 11:46 AM   #3598
lightfighter
where does this go?
Oddometer: 2,289
not sure if this is a good place for this, but anyone familiar with snapon mig welders? im looking at a YA212A on craigs list, quick search on the interwebnet shows they are rebadged century or similar... there are haters out there, but with a 60 percent duty cycle, and knowing im only going to use it lightly...
im looking for a survey of what it might be worth. never mind what he is asking. :)
looks like it is ready to use, less the bottle.
lightfighter screwed with this post 09-14-2013 at 11:54 AM
lightfighter is offline   Reply With Quote
Old 09-14-2013, 12:49 PM   #3599
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,233
I am sure this has been asked and answered before but I couldn't find a search entry that found it. I want to get a gas setup to do occational repairs and fabrication. I am talking about welding or brazing a Scott's stabilizer to the frame, fixing lawn furniture, other vehicle work, etc. No big projects or production work. A motorcycle frame is probably the heaviest type of metal. I may do some cutting but it will be sheet material just a little too thick to cut easily with a hacksaw, no plate. Probably find things that need bending at some point too.
I live in a residential area without a garage or shop so I will have to haul it out of a storage shed to use out in the driveway. Therefore, I am considering one of the portable units with the smaller tanks. I don't need top of the line but don't want junk or anything that is going to be a hassle. I keep and maintain tools for a long time.
I have done a fair amount gas and stick welding but it has been quite a few years.
Is there anything faulty in my conclusions?
Should I plan on renting or buying the tanks?
Any specific recommendations for what to buy or where to get it (or things to avoid)?
Any other thoughts or suggestions for the kind of work I am interested in?
Thanks.
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 09-14-2013, 05:10 PM   #3600
David R
David R's Avatar
Oddometer: 2,538
Used one, it was good. Check the duty cycle, see if it's for 10 minutes or one hour.
Times are GMT -7.   It's 08:33 AM.
