Old 11-23-2013, 04:58 PM   #3751
jules083
jules083's Avatar
Oddometer: 4,159
Originally Posted by redprimo View Post
For TIG I prefer a huntsman fiber hood with a non auto large lens. I'm possibly the only person on this forum that prefers a non auto hood, but It works for me. I like auto helmets for MIG but as I've aged and progressed to wearing bifocal glasses I have had problems seeing when TIG welding. I've tried the insert readers and they help, but when I dug out my old huntsman it was so much easier to see with that huge 4" x5"" lens. Much easier than trying to juggle a pair of readers and a pair of bifocals in the shop.
I hate auto hoods. Last time I used one was for a 6G stainless test in June. Hadn't used one in a few years before that, I made one tack then went back to manual.
Shade 11, glass filler plate. No auto ever built is that clear and reliable.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 11-24-2013, 08:39 PM   #3752
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,507
I wear a mid-line Hobart adjustable every day.
One of my guys at work got the Kobalt for $99 with the graphics. I'm impressed for the dollar. However my next hood will be a 3M Speedglas
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 11-25-2013, 04:29 AM   #3753
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Titanium- who's welded it. Who's machined it? I need some info on both. I've heard it'll ignite when welded and burn,and it eats carbide up. Looking for someone that has experience with it.
Danjal is offline   Reply With Quote
Old 11-25-2013, 04:34 AM   #3754
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
The older ones sucked and flashed you unless you blinked on start.then your eyes had to adjust for lighting and focus. The new ones are tons better than the old.
I have a Lincoln Viking. It works pretty good,nice and clear when shaded and not.
This is a cheaper Lincoln brand. Might be as good. Haven't seen it yet in person.
http://m.lowes.com/product?langId=-1...97&view=detail
Old 11-25-2013, 05:54 AM   #3755
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
Won't burn, that is Mg.
I weld it several times a year, and machine/fab parts for myself from Ti.
Different types machine better than others..some of it will kill a cutter in a matter of seconds.
What are you doing?
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres is offline   Reply With Quote
Old 11-25-2013, 06:12 AM   #3756
xymotic
xymotic's Avatar
Oddometer: 8,368
Hi All,
The Aluminium subframe on my poor husky has been broken a FEW times, gussetted and strengthened in one place it breaks in another.
So now I've busted out the battery tray, and I want to try and repair it myself since it hasn't been 'pretty for a long time :) I figure I should be able to do it 'good enuf' to get by until I can get a decent tig setup. I'm using a 110v hobart now, with no spoolgun so any tips on what wire I should use? Most of what I am doing is 1/16 max.
Being cheap, and since I only have all of about 1.5" to weld total, Can I get by with using the c25 I already have or do I absolutely have to have argon?
Also, I'm wondering if it's possible to re-heat treat the whole thing when done? (how?) I'm not sure how important that really is since the welds in general have held.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 11-25-2013, 07:29 AM   #3757
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,107
What are you doing?
It won't easily burn as bulk material but the shavings will burn like Mg, we have had Ti fires in our shop.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is online now   Reply With Quote
Old 11-25-2013, 08:28 AM   #3758
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,615
If you are going to weld aluminum with a 110 mig and no spool gun what you need are patients of a saint!
Welding aluminum like that is like "Playing pool with a rope" (a quote of my dad not about welding)
It can be done. They make a teflon liner for your mig gun and use 5356 wire because its stiffer than pure 4043.
Perhaps a little help from the folks on the Hobart site.
Yes you need PURE Argon.
Best of luck. Show us how it comes out, pics and all!
David
Originally Posted by xymotic View Post
Hi All,
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 11-25-2013, 08:58 AM   #3759
xymotic
xymotic's Avatar
Oddometer: 8,368
Lol. I was afraid that would be the case. I might pay a guy 100 to do it a third time...
Sent from my VM670 using Tapatalk 2
Albert Einstein
6:10 to Yuma
Old 11-25-2013, 11:05 AM   #3760
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,514
We do everything with it here. What do you want to do with it?
Machining chips can be flammable, but mostly as grinding swarf. Use the correct speed and feed and get inserts designed for the proper Ti alloy.
tbarstow is online now   Reply With Quote
Old 11-25-2013, 06:04 PM   #3761
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Receivers out of tubing and bolts out of round stock. I need to make and weld 2 nuts on it to hold a top picatinny rail. The tube is 6-4 IIRC. ..060". I'll get the actual specs later if it's that important.
Old 11-26-2013, 09:16 AM   #3762
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
Learn something new everyday, welded a lot of it, machined a fair share of it and never had it catch fire...also see a ton of exhaust made from it, glow red and not ignite.
Thanks for the heads up, I will now separate out the Ti swarf off the lathe..(I have always just separated the Mg chips and grinding dust.)
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres screwed with this post 11-26-2013 at 09:27 AM
Old 11-26-2013, 09:25 AM   #3763
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,630
Learn something new everyday, welded a lot of it, machined a fair share of it and never had it catch fire...also see a ton of exhaust made from it glow red and not ignite.
I may have to fire up the lathe, {pun intended} and see what happens.
FYI, iron and aluminum powder will burn also. They are not extremely easy to ignite, much like titanium. I think all metals can burn (but would need to reference the chemistry book on that one). Some are just easier to ignite as a powder.
Stan_R80/7 is offline   Reply With Quote
Old 11-26-2013, 09:31 AM   #3764
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
I have actually caught the grinding dust box on my big belt sander on fire..dull red glow...with occasional bright white flashes..gets a lot of mixed use, Alum, Steel..
TIG Welding Ti or Mg correctly, The odds of it catching fire are ZERO.
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres screwed with this post 11-26-2013 at 10:23 AM
Old 11-26-2013, 09:52 AM   #3765
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,577
This
Anything that can oxidize can explosively combust given the right particle size and air/fuel ratio.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Times are GMT -7.   It's 10:16 AM.
