Old 11-30-2013, 07:52 PM   #3781
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,471
As a bit of trivia, propane and oxygen uses a 1:5 ratio. So, the trip to the welding shop can't be avoided with propane and twice the oxygen is needed compared to acetylene.
Stan_R80/7 screwed with this post 11-30-2013 at 07:58 PM
Stan_R80/7 is offline   Reply With Quote
Old 11-30-2013, 10:33 PM   #3782
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
I wasn't trying to say that the trip to the welding shop could be avoided. But acetylene is expensive these days, and propane is much easier to get.
FWIW, I feel I should mention that oxygen is a very dangerous gas in it's own right, and should be treated with at least as much care as acetylene. I don't have an oxy-acetylene setup these days, largely because I just don't feel comfortable with them stored in my garage (which is right underneath the two bedrooms of my small house).
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 12-01-2013, 04:56 AM   #3783
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,471
I am not intending to 'defend' acetylene compared to propane, but pointing out the trade-offs. Some people are very uncomfortable with acetylene (e.g. it will explode, is dissolved in acetone, etc.), but handled correctly is safe. Oxygen should be treated with respect, plus it has no odor for leak detection. I rent oxy-acetylene bottles when needed, other than a Oxy-Acetylene tote with a MC and #1 bottles. But that is out of convenience since an Arcet shop is ~ 10 minutes away.
From my limited experience, acetylene is a versatile fuel gas. But propane is very convenient and may be less expensive for some jobs. It seems all bottled gases have more than doubled in price in the last ten years. Also, filling (swapping) the bottles costs nearly the same for a large bottle compared to a small. If I were learning to oxy-acetylene weld, I would get a Victor torch set and rent a big acetylene bottle and accompanying oxygen bottle - even if that entailed renting (or buying) a trailer. Once the learning phase was over, then consider buying bottles.
Old 12-01-2013, 07:34 AM   #3784
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,068
O/A Trivia
The gas supplier may even deliver for free..... When I bought my O/A rig about 12-14 years ago I bought the tanks and the gas supplier (either Holox or may have already sold out to Airgas) said they deliver free. They constantly run big flat bed trucks all over around here delivering industrial and medical gases, so its easy for them to combine deliveries in an area.
YMMV.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 12-01-2013, 01:28 PM   #3785
redprimo
Oddometer: 487
OA is a very versatile choice for a welding set up. It may not be as cost effective to use when figuring in the cost of gas and the extra time it takes to weld vs a point and shoot MIG set up. But in situations where you are off grid and only do occasional welding I think it is the smart choice.
For brazing silver you my want to look for an old presto lite torch. it is an acetylene only rig and may be chaper to use. It is not as fine of a flame as a mini torch with a small tip.
I have done several cast iron repairs with OA and vrass brazing rod. the key is to drill a hole at the end of any cracks and to grind a groove with 60 degree sides. If it is a clean break you need to bevel the edges and make a fixture to hold the parts together. pre heat both parts and then braze away. When done let the parts air cool, DO NOT USE WATER. I repaired a CI water pump with a spiral weld around the entire pump using a cutting torch and some flux coated brass rod. By the time I was done brazing the whole pomp as glowing dull red. I put a metal box over it to hold the heat in so it could cool slowly and the thing held until the bearings went bad 10 years later.
redprimo is offline   Reply With Quote
Old 12-03-2013, 08:39 AM   #3786
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,499
Originally Posted by Thebes View Post
But dealing with the tanks seems a pain. I read that I should NEVER transport acetylene in an enclosed vehicle? Is a welding shop likely to stop me from doing so? I have no way of using a hitch mount, the best I could do is put it on the hood or modify the vehicle (for which I'd need the torch in the first place). I live past the end of BFE down dirt roads, I think the nearest air-gas retailer is about 2 hours away, the dirt roads are only a couple miles but it is a half hour to town IF I find someone who runs tanks back and forth between Taos and Santa Fe.
I used to carry bottles in my van. The welding shop discouraged, but allowed. After reading this article, I now hook up my trailer if I need to haul an acetylene bottle. If you absolutely, positively have carry in your car, leave all the windows open. If you've ever ignited a balloon filled with acetylene, it will give you a small idea of the explosive power of a car filled with gas.
Cutting steel with a torch leaves a ragged edge. When I built my trailer I put an abrasive blade on my circular saw and used that for all the cuts. I went thru a lot of blades cutting 700#'s of steel.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle screwed with this post 12-03-2013 at 08:44 AM
HellSickle is offline   Reply With Quote
Old 12-03-2013, 11:49 AM   #3787
MiteyF
MiteyF's Avatar
Oddometer: 2,012
Related to this, and thus, welding (kind of), I've been searching for a good way to cut steel tube (2x2 or smaller, both square and round) *somewhat* accurately without investing a bunch of money in a horizontal band saw or abrasive chop saw. Is there another way besides my angle grinder and cutoff wheel, or am I gonna have to pony up for a chop saw? I've never used an abrasive bladed chop saw that didn't take eons to make a cut...
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 12-03-2013, 12:11 PM   #3788
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,499
Huh? A chop saw should cut thru smaller tubing in seconds. The horizontal band saw should take a lot longer. Cutting 6" channel with my circular saw took a bit of time.
Old 12-03-2013, 12:31 PM   #3789
eric1514
(R)
eric1514's Avatar
Oddometer: 301
Perhaps this?
http://www.harborfreight.com/3-12-ho...saw-68104.html
Find a 20% off coupon in some magazine and it becomes real cheap.
Eric
eric1514 is online now   Reply With Quote
Old 12-03-2013, 12:37 PM   #3790
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
It takes forever and a day to cut metal with a masonary blade.
Luke is offline   Reply With Quote
Old 12-03-2013, 12:40 PM   #3791
MiteyF
MiteyF's Avatar
Oddometer: 2,012
Originally Posted by eric1514 View Post
Perhaps this?
Eric
The only power tool I've ever bought from HF has actually done me very well. I've got their benchtop drill press... for $60 (plus a $20 2 year warranty = $80, highly suggested) it's given me no problems whatsoever in my 3+ years of occasional use... may just have to take a look. Although I'll factor a *real* blade into the price, since we ALL know the stock one will suck balls.
Old 12-03-2013, 12:46 PM   #3792
MiteyF
MiteyF's Avatar
Oddometer: 2,012
A good horizontal band saw will make an abrasive chop saw look like a children's toy.
Old 12-03-2013, 01:51 PM   #3793
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,114
Do you have an O/A torch and bottles.......... cutting torch? I've seen some people that were really good with a cutting torch, Years ago thats all there was Learn how to use it. It's a lot cheaper than cutoff blades and ya arn't breathing all that dust or have it down the back of your neck.
Use a straight edge to help guide the torch when the length of cut allows
Cutting anything thinner than 1/4" plate is not recommended because of warpage, but sq. tube, channel and pipe are easily cut with a torch.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 12-03-2013, 01:56 PM   #3794
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,471
The people I have watched that appeared to know what they were doing (i.e. paid pipe fitters and welders) always used a portable bandsaw for such work. HF sells one (that I have bought - but not used much): http://www.harborfreight.com/power-t...saw-47840.html. I bought my portable bandsaw to use with a small generator to cut 20' sections of 1/8" steel angle to carry home.
I have yet to see a blade on a HF tool that was adequate. Milwaukee sells a more industrial portable band saw for ~ 2-1/2 times the price as the HF. Slow speed is needed for cutting steel. Having used abrasive blades, I found the bandsaw a huge improvement - and the lack of vibration, noise, and abrasive dust are appreciated also.
Old 12-03-2013, 02:10 PM   #3795
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,536
2 x 2 steel tubing can be cut with a hack saw.
A grinder with a true (1/16") cut off blade will do the job, it may take a jig to get it to cut straight. Wheels are availabel at tractor supply for $2.00 each.
Chop saw!
Sawzall works on steel with the right blade and if it goes slow enough. Full speed on steel and the blade turns blue then the teeth fall off.
Portaband is great, but $300 is a little steep. I have one.
I bought a horizontal band saw from harbor freight in 1985 for $179. I now have a bigger one that circulates coolant. I still use the small one.
A good man with an ox acet torch can make a nice cut. You don't learn it in a minute.
Good luck
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Times are GMT -7.   It's 04:56 PM.
