Old 12-04-2013, 03:58 PM   #3811
MiteyF
MiteyF's Avatar
Oddometer: 1,995
Originally Posted by Strong Bad View Post
Wait....wut?????? The rack is not chrome, it is chrome plated like said only a few 1000ths thick. Chrome plating commonly starts with a layer of copper then a layer of nickle and finally a layer of chrome. Chrome alloys are commonly welded and stainless steel is predominately nickle and chrome. So where did you come up with it can't be welded? Hexavalent chrome is what is hazardous and it is a very small % of the fumes given off but regardless breathing any fumes should be avoided. If you want to remove it you could use emery cloth (sand paper)
He said "chrome" when he s*technically* hould have said "chromed". This is common language. You're nitpicking, and everyone else knew what he meant.
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 12-04-2013, 04:22 PM   #3812
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,421
Hexavalent Chromium is dangerous. Still, you should be careful with regular chrome as it may convert, but I wouldn't worry too much about it.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 12-04-2013, 04:42 PM   #3813
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,248
he "technically" should
Nit picking, detailed, exact..what ever. Hey you got any nits you need picked??? Apparently, I'm good at it! Relax mang
I was more concerned with his saying you can't weld chrome (or chromed) because that is simply wrong.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 12-05-2013, 08:03 PM   #3814
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
This has probably been asked, sorry way too many post to dig through for a reasonably quick answer.
I have done some mig welding in the past, I need to fab up some metal and welding is the only solution.
Most of the thickness will be 1/8 th or less.
What affordable welder that can be bought, hopefully used will do the job?
Budget: little as possible.
Thank you.
Bbasso is offline   Reply With Quote
Old 12-05-2013, 08:36 PM   #3815
p0diabl0
Oddometer: 561
My welding q:
I just want to weld some small scale things, .05" thickness tubing, etc. - can I do that with a cheap arc stick welder and patience? It doesn't have to be pretty, or even that strong.
Ninja 650R Tourer/Commuter, TW200 Playbike
p0diabl0 is online now   Reply With Quote
Old 12-06-2013, 03:03 AM   #3816
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,496
Originally Posted by p0diabl0 View Post
My welding q:
Fat Chance
.05" thick steel requires 50 amps as a rule of thumb to weld in one pass. Tubing is more difficult to weld than plate. I suggest tig for the heat control. Mig will do it, this is a little thinner than exhaust tube. Stick welding exhaust can be done. Mig is MUCH easier.
I am not saying it can't be done but....
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 12-06-2013, 03:06 AM   #3817
David R
David R's Avatar
Oddometer: 2,496
Thank you.
Almost any welder will do 1/8"
David
Old 12-06-2013, 06:55 AM   #3818
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,688
Originally Posted by CodyY View Post
Cold saw's got nothing on the HEM saw. We have a Cyclone @ work with 24" of auto-feed. http://www.metalsaw.com/HEM-Cyclone-Semi-Auto.cfm
Meh, there's a really nice horizontal bandsaw at TechShop and I usually prefer the cold saw for the types of tubing and such I cut. I find it more accurate than the band saw. JMHO
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 12-06-2013, 07:46 AM   #3819
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,421
Originally Posted by David R View Post
Fat Chance
David
If it's mild steel, I prefer a gas torch for anything that thin. MIG would be my second choice.
Old 12-07-2013, 09:59 PM   #3820
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,493
Really? If we slow it down a bit it'll hold a couple thou all day long.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 12-08-2013, 06:33 AM   #3821
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,688
I think we are comparing apples to oranges. You obviously have a really nice horizontal saw with auto feed. Ours is a JET with hydraulic down feed and that's it. I can line up a cut in tubing faster and more accurate on a cold saw than setting up the cut on a bandsaw. Angle changes, vice clamping etc are all faster on a cold saw than bandsaw. I'm sure for automated cutting the bandsaw you have wins hands down.
I will also say for solid stock the bandsaw is the clear winner.
Nessmuk
Old 12-09-2013, 04:21 PM   #3822
CodyY
CodyY's Avatar
Oddometer: 9,493
Indeed. This one's a beast. Thats 6" od DOM that had just come out
Old 12-09-2013, 06:40 PM   #3823
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,089
Thank you.
The Power MIG 140C. Runs on 120V and welds thin sheet well. The instructions on the inside panel of the 140 has the correct settings to help you set the machine to weld the metal thickness you are using.
You can get one at any welders supply store.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 12-10-2013, 03:43 AM   #3824
David R
David R's Avatar
Oddometer: 2,496
That is a good machine, but don't let anybody kid you it will not put out 140 amps at welding voltage on a regular 110 volt circuit. 90-100 amps would be more like it.
SURE it will weld the .050 pipe you were asking about and do a nice job.
Old 12-10-2013, 07:17 PM   #3825
little_twin
little_twin's Avatar
Oddometer: 398
I am just looking for a little critique on my welds. I just picked up a miller 211 and am loving it.
Here are some of my most recent, any feedback is appreciated.
Bumpstop mounts
Boxed in engine mount
Plated front spring hanger to crossmember
Rock sliders
All welds were lightly brushed or have no clean up post weld.
little_twin is offline   Reply With Quote
Times are GMT -7.   It's 03:55 AM.
