Old 04-16-2014, 09:09 AM   #3991
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,339
Originally Posted by crazybrit View Post
The HF ones have a "Heavy duty cast iron body":
http://www.harborfreight.com/5-inch-...mps-39609.html
http://www.harborfreight.com/6-inch-...amp-37850.html
Though I noticed yesterday that the deep-throat ones, ooh err, that would probably work better, are apparently "Malleable steel":
http://www.harborfreight.com/5-inch-...amp-45916.html
If I do it, I may spend a bit more and use these:
http://www.amazon.com/IIT-23325-Deep.../dp/B001VSY14Q
Sailah may well be right however.
Either way, they welded just fine. I think I used stick with 7018 rod. Tools like this generally aren't as important as a mission critical application (engine block or suspension component).
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 04-18-2014, 01:16 PM   #3992
jules083
jules083's Avatar
Oddometer: 3,826
Are they supposed to glow when you're done?
9 passes without breaking arc. 2 guys on the same machine, each have our own stinger hooked up to a Y. Keep going in circles and passing the arc off to each other, change your rod while the weld is on the other side. No chipping slag.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 04-18-2014, 10:35 PM   #3993
Ironwood
Friday Harbor, WA
Oddometer: 749
And what is it you are accomplishing, pray tell?
Ironwood is offline   Reply With Quote
Old 04-19-2014, 04:38 AM   #3994
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,485
I "Think" they are boiler tubes. I hope they are thick because I "think" I see undercutting on the red one.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 04-19-2014, 05:22 AM   #3995
jules083
jules083's Avatar
Oddometer: 3,826
They are boiler tubes. 2.25" OD, 1.25" ID. So 1/2" thick. The undercut happens when you run them out that fast, as the metal heats it will flow down and sag at the top. After the slag is chipped off and the tube stops glowing one more pass will dress the top up. They don't get left as pictured, I just wanted to get a shot of it glowing.
The reason we ring them like this is because rod angle is terrible on some of the back sides, and you can just barely reach it. Restarts aren't feasible normally, so we just keep the weld going. Sometimes just one round at a time, it depends kn the situation.
Old 04-22-2014, 01:54 AM   #3996
tommu56
tommu56's Avatar
Oddometer: 1,360
out of position welding
Back ground Im a gorilla welder welds are ugly and usually strong.
machine hobart champion
I want to weld some stake pockets to my trailer and cant get the vertical welds to stick.
I've tried 7018 1/8, 3/32 6013 1/8 3/32 with no luck
the frame is 5x2 x 11ga box steel and stake pockets are 3/32 thick
On the flat I can get 7018 to run ok (they are old rods) but on up hill they just don't stick.
tommu56 is offline   Reply With Quote
Old 04-22-2014, 04:14 AM   #3997
David R
David R's Avatar
Oddometer: 2,485
Gorilla welder,
Both pieces need to be clean as in fresh ground no rust or scale, even mill scale. Keep a short arc and work your UP with a weave.
Vertical up is a learned skill. Get the hang of it then weld your stake pockets in. FRESH DRY 3/32 7018 @ 80 amps is what I would use. You could also use 6010 or 6011 but I don't' know how many amps. The machine should do the job.
It took ma a semester to learn vertical up. Once you have it, any position is a piece of cake.
Good luck
David
Old 04-22-2014, 09:47 AM   #3998
tommu56
tommu56's Avatar
Oddometer: 1,360
Originally Posted by David R View Post
Gorilla welder,
Good luck
David
Thanks I'll get some new rods and try again.
tom
Old 04-22-2014, 11:24 AM   #3999
David R
David R's Avatar
Oddometer: 2,485
Point the rod straight in or a little up.
Pics please
David
Old 04-22-2014, 12:47 PM   #4000
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,075
Just use 6010 rod run vertical up with a whip technic.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 04-22-2014, 05:42 PM   #4001
JonnyCash
turd polisher
Oddometer: 1,571
Anyone know of a pair of Miller 5" X-Clamps going cheap? I'm in the middle of making my own welding table with 3/4" slits that will accept them (as I like the theory of them) but I'm buggered if I'm going to pay $40 a pop (and that's the discounted online price). Was pondering cannibalizing a cheap Harbor Freight C clamp (I can make the boss on my lathe) but I'm not sure how effective I'll be at welding cast iron.
I've had good luck with ones from Grizzly. They have a little one pictured in their catalog(it's orange), but they have a bigger one that I have bought a bunch of that isn't pictured. I think they're like $15 each, and I can't break them.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 04-22-2014, 07:19 PM   #4002
tommu56
tommu56's Avatar
Oddometer: 1,360
6010 DC ROD I have AC welder I had to look it up because I usually use 6011.
thanks for posting I had to look it up and learned something.
Old 04-25-2014, 02:39 AM   #4003
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 374
Sir , Now its Water tide Sir .
Cooling Water Instalation in India .
(One of about 500 Joints that look like this .)
("Please let me out of here befor i kill the welder")
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 04-25-2014, 08:26 AM   #4004
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46 31.714' E 010 27.212'
Oddometer: 3,803
Originally Posted by Schrauberklaus View Post
("Please let me out of here before i kill the welder")
That is a weld? Cripes, I have oxy-acetylene welds that look like a TIG weld and I do this as a hobby. I'll be plugging in my new Everlast PowerTIG 250 EX soon. I always wanted a TIG.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 04-25-2014, 10:13 AM   #4005
jules083
jules083's Avatar
Oddometer: 3,826
I don't know about 'water tide' but it looks like it'll hold corn at least.
Seriously though, I'd get fired for that. At the very minimum they'd pull my welding certifications. Might even get put on the next drug test.
Times are GMT -7.   It's 02:21 AM.
