03-07-2007, 06:17 PM
#31 | |
Oddometer: 674
03-07-2007, 06:22 PM
#32 | |
Motorsick
Oddometer: 1,703
I would search the internet for Chicago Electric and see if you can find a new spool gun. Or try this: http://www.lincolnelectric.com/produ...ig_140_180.asp
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
03-07-2007, 06:31 PM
#33 |
aventurero
Oddometer: 926
Thanks KTM. Thats the problem I'm having. Well it will make a good garage sale item I guess.
03-07-2007, 06:32 PM
#34 | |
Motorsick
Oddometer: 1,703
Usually you need to protect the molten aluminum from the oxygen that is in the air or it will react with it, and form Aluminum oxide. You normally use Argon gas to do this. The argon will flow around the molten aluminum and is delivered through a torch nozzle of the electric arc. If you don't protect the molten puddle then the oxygen will cause your weld to have gas holes in it (porosity) and the filler rod will ball up an not flow. I have never seen a good aluminum stick electrode that actually worked. In the sixties they used to call TIG welding using 100% helium gas Heliarc Welding. Helium is also a good inert gas to use to protect molten aluminum weld puddles. Because of costs most people now use argon gas rather than helium.
03-07-2007, 06:38 PM
#35 |
aventurero
Oddometer: 926
One more question for ya. I have a 1961 Airstream camper I am re-modeling and I need to weld some of the frame joints on it to strengthen them up. Would a stick welder work best? I'm guessing but the frame seems to be a little thicker than a standard PU truck frame but not much. I took a ton of welding classes in high school but never used the knowledge since then. I bet I can still weld pretty good though.
Thanks for your knowledge sharing.
03-07-2007, 06:40 PM
#36 | |
Syndicated
Oddometer: 11,285
- Jim |
03-07-2007, 06:41 PM
#37 | |
Motorsick
Oddometer: 1,703
I'm not sure what material is used for those clamps. As long as they can weld it without distorting it you should be fine. You also want to make sure that it is not made out of cast aluminum just because it is harder to weld. I would be careful if you plan to use these brackets to hold brake calipers on though. You don't want them to fail, and brakes have huge stresses transfering the the lower fork. I would use 5356 filler rod and TIG weld it. 6061 is a very common aluminum grade that is friendly to welding.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. KTM640Dakar screwed with this post 03-07-2007 at 07:03 PM |
03-07-2007, 06:42 PM
#38 | |
aventurero
Oddometer: 926
03-07-2007, 06:50 PM
#39 | |
Motorsick
Oddometer: 1,703
Welding is like riding a bike. Once you learn it you will get up to speed quickly even if it has been awhile. Yes, a great project for stick welding. Frames are nice and heavy and will take the heat of welding easy. Try using a 7018 stick electrode. If you use a 1/8 inch diameter stick set your machine to DC+ and use about 95 amps if you are welding overhead, or 105 amps if you can weld in the flat position. If you have not welded in a while try a 6013 electrode. It is a little easier to run. Both will over match the strength of your frame.
03-07-2007, 06:59 PM
#40 | |
Motorsick
Oddometer: 1,703
03-07-2007, 07:20 PM
#41 | |
aventurero
Oddometer: 926
03-07-2007, 08:11 PM
#42 | |
Syndicated
Oddometer: 11,285
Sure epoxy 'liquid steel' stuff. Or a solvent bond like ABS cement if it is ABS. Even the red and blue wire spindles are plastic. It has nothing to do with what country the machine components are made in. Or, you can prolly fashion one out of PVC or a wood dowel. Maybe you can reuse the spring and wingnut that it came with. Open up the case and see what's behind the spool. There almost nothing inside of a transformer power supply. Feel free to attach anything you can think of the sheet metal to support the spool. Just as long as nothing conductive touches the wire. - Jim |
03-07-2007, 08:20 PM
#43 | |
Syndicated
Oddometer: 11,285
I like the process. - Jim |
03-07-2007, 08:22 PM
#44 | |
Motorsick
Oddometer: 1,703
03-07-2007, 09:02 PM
#45 | |
aventurero
Oddometer: 926
Thanks |
