03-14-2007, 03:33 PM
#76 | |
Motorsick
Oddometer: 1,707
I know there are Thermoplast and Thermoset types of plastic, and one type can be melted when heated and the other one burns if heated. But I can't remember which one is which. I think it's the Thermoplastics that can be melted. I have had very little experience with welding plastics. You can problaby google educate yourself about plastic welders. If it is anything like other bonding methods you probably need to have clean dry joints to weld together. Oil on the surface of the plastic will negatively effect the weld I would expect.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
03-14-2007, 04:04 PM
#77 |
Syndicated
Oddometer: 11,286
This is great. A typical welding forum right here on our own ADVrider. Authentic too. Whose the fella with the tripping breaker, benp1981? Do you have a voltmeter Ben? - Jim |
03-14-2007, 04:14 PM
#78 |
Syndicated
Oddometer: 11,286
![]() Super deal gsweave, good work. Nice fillets for such a short stick weld. You sure tailed off the beads nicely, even while reaching the edge of the part, and going around a radius. Right about there is where I'd be burning a hole in the material. - Jim |
03-14-2007, 08:53 PM
#79 |
Oddometer: 22
Frame problem?
KTM - thanks for offering this service. Here is what I have for a problem. This is a 1999 BMW F650 Funduro. This is the outside of the swingarm pivot on the left frame side.
I just bought the bike in January and have not rode it. Somehow I missed this problem prior to buying the bike. I suspect it was cracked but the paint had not cracked until sitting in my garage and the temp varied. Or I just plain missed it. I don't think the seller saw it and the third party I had look at the bike missed it also. I have not rode it and I don't plan on riding the bike unless I think everything is right/fixed. ![]() I ground the paint off with a dremel. - Now that I look at it not well enough. I will have to grind more paint and see if that vertical crack is travelling north. ![]() It appears the crack is right next to the weld. I think the weird looking thing is a spider I scared out of the swingarm pivot. ![]() How do I go about fixing this? Or more realistically if I take it to a pro welder what should I expect from him. I like to be a little educated in what work I am having done - not that I want to act like a know-it-all. |
03-14-2007, 09:12 PM
#80 |
Syndicated
Oddometer: 11,286
Are you going to take the swingarm out of the frame? It's prolly cracked on the swingarm side of the tube too. Maybe remove some more paint and see what you can see. It could be a silver brazed join. It looks very smooth for a weld, but that could be the powder coat. Try a wire wheel to remove the paint, so it won't 'cover' a crack by pushing metal across the gap. - Jim |
03-15-2007, 08:39 AM
#81 | |
back on the 2 wheel wagon
Location: 3.2% UT, formerly of bar on every corner-burgh, PA
Oddometer: 143
here is a scan of the schematic of this machine. i agree that an erratic high line voltage spike could be the problem. the clamping diode (is that what the 'Z' component is? 2 zener diodes for bi directional clamping?) on the input is always connected to the line voltage, so that's probably not the problem. on my machine the fan doesn't come on until you start welding or cutting, then i think it's thermostatically controlled. i also have had zero problems with properly sized extension cords. we went as far as to measure voltage at the welder under load to make sure there was not excessive voltage sag under load. one thing i did notice on an udersized cord i once borrowed someone built was that you can hear the fan speed slow down as you weld. what is the difference between properly sized wiring run in the walls and a properly sized extension cord? is it the extra resistance of an additional plug? i think most people cringe at the cost of buying the right gage wire for extension cord and end up with an undersized extension. in BenP's situation, the extension cord may be acting like a soft start resistor, limiting startup current. BenP, you should try putting a voltmeter with min/max logging on your line and see what the peak voltage is over the course of a day. also, you could just live with it. it's most likely only going to wear out breakers. Mike
03-15-2007, 08:46 AM
#82 | |
Yinz, blinkers are on.
Oddometer: 9,976
First the good news. The Funduro is a great bike, I had a 97. That piece might be cosmetic rather than structual. I have my fingers crossed for you. Grind away the rest of the paint on the vertical crack. The bad news. It needs to come apart to know for sure. Because of the needle sleeve it needs to be apart to weld. Stuctual or cosmetic, it needs repaired Question is, does the bushing gain integrity from that collar or is the collar just a protective piece for the Needle sleeve (#331723452830) and stud? The micro fishe isn't clear enough to tell, As you can see from 01 on, the swing arm attachment was redone, but I have never heard any weakness reports on the ealier frame design. Photo is left side 01 650 GS swing arm attachment. ![]() A replacement frame is $1080. But it would be a daunting task for most to swap one out. best of luck. Dan
If your looking for me. I will be at Rella's eating Blackberry pie. http://advrider.com/forums/showthread.php?t=791094 http://www.youtube.com/watch?v=_ampAFmwP_E gsweave screwed with this post 03-15-2007 at 09:03 AM |
03-15-2007, 09:30 AM
#83 | |
Oddometer: 9,976
Thanks, I expected to burn through there too. The Blue Max rod saved my embaressment. It surely isn't perfect but should hold for another 60,000 miles.
If your looking for me. I will be at Rella's eating Blackberry pie. http://advrider.com/forums/showthread.php?t=791094 http://www.youtube.com/watch?v=_ampAFmwP_E |
03-15-2007, 10:58 AM
#84 |
Oddometer: 22
Funduro frame
Dan,
Thanks for the input. I kinda thought it would have to be taken apart to be repaired. I was a little worried that the heat from welding might distort that area and cause problems with the bearing fit. I don't think I would go the $1000 frame replacement route unless forced to. This is starting to not be as much fun as I had hoped. Tom |
03-15-2007, 11:23 AM
#85 | |
Syndicated
Oddometer: 11,286
I thought you were using the McKay GP electrode? And Blue Max is a stainless steel filler if I remember. Did you use 309 or something? Hmm . . . SS rods do use lower heat, and 309L for low carbon steel . . . I'm gonna have to try that. - Jim |
03-15-2007, 10:12 PM
#86 | |
Oddometer: 9,976
The same rod, I believe. The 3/32" rod is marked as GP, The larger sized rods are marked as 2100 Blue Max. Yep, they are both Stainless based. I really like the control I get with them. We weld lots of Stainless here at work, And they are really good for bonding M-2 tool steel to 400 series metals. We have to weld some really odd metal combo's here, at times. So if there is any doubt which rod to grab, grab the Blue Max. I am sure Todd will cringe at that, but it seems to work for us.
03-16-2007, 06:05 PM
#87 | |
Oddometer: 2,006
03-16-2007, 06:17 PM
#88 | |
Oddometer: 2,006
03-16-2007, 06:47 PM
#89 | |
Syndicated
Oddometer: 11,286
The test results look good for what I need it for. 92kpsi yield and 22% elongation. I always use low-carbon, so 92k is plenty strong enough. I'm gonna get me a sample. Hey there KTM, can a Blue Max 2100 too-much-absorbed-moisture flux coating can be dried in an oven? - Jim |
03-17-2007, 04:43 PM
#90 | |
Motorsick
Oddometer: 1,707
Regarding mositure, water, oils, zinc coatings, rust, mill scale, oxides, grease, or any hydrocarbon on the metal you are welding. You should never let stick electrode get wet. It is even bad to keep it out more than eight hours in a humid environment. If you have a rod oven you can probably get away with drying it once. The real reason that moisture (and all of the other listed contaminants) is bad for welding is because H2O is a source of hydrogen. The problem with hydrogen is that it is the smallest atom we know of. And if you introduce it to a molten weld puddle, and the puddle freezes back to a solid the hydrogen will diffuse out of the solid weld, and leave behind a hole where it used to be. This is called porosity and it is an unexceptable defect in a weld.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. KTM640Dakar screwed with this post 03-17-2007 at 05:11 PM |
