Old 05-18-2009, 08:46 PM   #991
CR_TurboGuy
Iowhat?
CR_TurboGuy's Avatar
Oddometer: 478
Not strictly a welding question, but deals with molten metal:
Is it possible to plasma cut magnesium?
--JOsh
1990 Yamaha XT600E - Old Faithful
1983 Yamaha CV80 Riva/Beluga Scooter - Scooter Trash
CR_TurboGuy is offline   Reply With Quote
Old 05-18-2009, 09:58 PM   #992
tundrawolf
Desert Rat V Star
Oddometer: 313
--JOsh
If you like uncontrollable fires
I remember a fireman telling me why magnesium rims aren't so common anymore:
In an accident, when the rims caught fire, inexperienced firemen would hose the vehicle down, and the rims would burn so hot, it'd actually use the water as a catalyst and burn HOTTER and more violent!
tundrawolf is offline   Reply With Quote
Old 05-19-2009, 07:10 AM   #993
studley
Lord and Master
Oddometer: 682
Thanks! I will kick some of the crap out of the way and check on the power box. This building was built in 1947 so anything is possible. I think the box is grounded to a water pipe which is grounded to the other metal pipe etc etc....
I will check it out today.
EDIT..
Much later....
Oh Right!!! No more dropped radio. KTM640, you called it dead on. Cleaned all connections, added a loop to ground with a stake. No more problem. Thank you.
Originally Posted by KTM640Dakar
You need to put an earth ground on the welder. You can drive a copper rod into the ground and connect it to the main power box that the ground of your welder is on.
I will get older but I refuse to grow up!
studley screwed with this post 05-19-2009 at 05:31 PM
studley is offline   Reply With Quote
Old 05-19-2009, 07:30 AM   #994
CR_TurboGuy
Iowhat?
Oddometer: 478
Oh, I'm quite familiar with what happens when you add water to already burning magnesium. A neighbor that works in the industrial laundry machine business who gets old magnesium dryer parts introduced me to that phenomenon at a campfire. I've actually got a bunch of magnesium electronics cases from work that were being thrown out, so I snagged them for campfire fun. Just wondering how to cut them into smaller, more manageable pieces. Guess I'll have to break out the portaband & give it a go.
--JOsh
Old 05-20-2009, 10:14 AM   #995
ghostridernv
ghostridernv's Avatar
Oddometer: 109
Brazing and Heat Treating
Just wanted to let you FF's know I manage a heat treating and brazing facility in northern nevada. Since this is related to welding, I thought I'd metion it here. As to not hijack this thread, feel free to PM me if you need answers to any heat treating or brazing questions. A free service to all advrider members (will be checking for the secret handshake at the door).
Regards,
Ghost
ghostridernv is offline   Reply With Quote
Old 05-20-2009, 06:38 PM   #996
WIsixfitty
ceiling unlimited
Oddometer: 2,301
Originally Posted by LoJack
I make frames, but the other kind:
This one is a little one off... It's actually going to be about a foot and a half longer. It's based on the Surly Bikes Big Dummy and Pugsley. Most of the bikes I make are pretty normal compared to this...
Lojack
Noice.
Are building frames in Madison? Or Waterford or Watertown?
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 05-22-2009, 09:31 PM   #997
Toyanvil
Toyanvil's Avatar
Oddometer: 1,683
Millermatic 35 ?
I have a Millermatic 35 made in 1989. I have been thinking about buying a new Miller 212, would this be a good replacement? My 35 works good with .035 wire but when I try .023 the wire will not feed right, I have the right drive wheel and tip for .023 but it still will not feed smooth. My dealer thinks I need to replace my gun liner does this sound right? My 35 has low hours and is in good shape, but is 20 years old. I am not sure if I should buy a new miller 212 or keep replacing parts on mine.
This is the only picture I have of it right now.
2004 BMW 1150 GS-1993 BMW R100GSPD-2009 Yamaha TW200 1961 Sunbeam Alpine.
Life is like riding a bicycle, to keep your balance you must keep moving.
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Hell, some of the places I’ve been there weren’t even roads!
Toyanvil is offline   Reply With Quote
Old 05-22-2009, 09:36 PM   #998
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,110
Regards,
Ghost
Thanks Ghost, that's great.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 05-22-2009, 09:42 PM   #999
KTM640Dakar OP
Motorsick
Oddometer: 2,110
That old Miller of yours is a soild machine, better than the new 212. It was made before ITW bought miller and screwed them up.
Get yourself a new gun liner and a roll of .030 L-56. The .023 wires don't feed through a 15 foot long gun very well.
Old 05-22-2009, 09:50 PM   #1000
Toyanvil
Toyanvil's Avatar
Oddometer: 1,683
That make sense. How thin can I weld with .030?
Old 05-22-2009, 11:09 PM   #1001
maloosik
Squishimus Squidimus
maloosik's Avatar
Oddometer: 493
What a great thread.
I was a weldor (not a welder) for about three years in my youth. Eventually I got my 3G plate cert. and then pipe cert 6g. Tig was my favorite particularly aluminum but I also liked using 7/8 electrode stick (7018) on heavy equipment repair, usually loader blades or buckets. Running uphill was really challenging for me but there was nothing like a 10 foot multi pass horizontal bead that curled the flux up by itself every 6 or 7 inches.
I worked in a small shop repairing and fabricating everything from cast aluminum lawn mower decks, bowling pin re-setters, hand rail, truck frames, semi-booms, motorcycle frames, Cadillac seat frames, aluminum BMW oilpans (lots of those), gas tanks, bed frames, dining room tables, magnesium shuttle parts (I helped set up the jig), roller coasters, engine blocks, cast manifolds, radiators, flow meters, tank farms (50K gallon gasoline tanks) trains, slabs of 2" and 3" plate in a hospital MRI lab, after first constructing the room's ability to hold it... and I could go on and on.
There is something about the arc and manipulatiion of a molten pool of metal that is intoxicating to me. I learned more in those three years than in all of my higher education, and loved every minute of it.
I gained a skill that allowed me to discover an art. For me, welding could not be a career, but it will never really leave me, I'm hooked. I actually endued up enjoying so much more than just the puddle; the layout design, material prep, finish etc. It's just a real satisfying endeavor.
Props to the OP for starting this and for providing me with a lot of reading; most of which I answered in my head before reading the response...
Of all the advrider threads I have enjoyed this one is way up there.
Thanx ....
Oh and I remember working with one old timer who just did stainless pipe he said to me once; there are no stupid or old weldors, they either get killed or if they aren't stupid they retire before they get killed. Most of his career was spent repairing or building oil pipeline. He showed me a picture of his welding truck (Lincoln DC welder) suspended level over and alongside a cliff (the whole truck was hoisted by a crane) 2 feet from a broken pipe. He was sitting on the edge of the truck with a stinger in one hand and a cigarette in the other, smiling, and not dead yet.
Sorry no question... well maybe one; how old are you?
I am happy to be here in this country and to know that the sport here is also important because the crowd here know about bikes and the riders, no? So they so much love. So it's important that this sport can grow up in this country... ~ Whorehay Lorenzo
maloosik screwed with this post 05-22-2009 at 11:34 PM
maloosik is offline   Reply With Quote
Old 05-23-2009, 07:13 PM   #1002
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,072
In the small amount of MIG knowledge I've absorbed since I started only about 11 years ago as a home shop weldor, .030 and .035 wire should let you weld thinner stuff than .023. At least at lower amperages (below spray transfer and you'll be way lower for thin stuff, naturally) .023 gives better penetration - something not that good for thin stuff.
I had an old hotrod project for a few years and spent a lot of time shaping and welding in patch panels. Just as I had read about, the thicker .035 wire was easier to use than the thin wire. So I started using .035 for thin stuff and .023 for thicker stuff and the very few multipass jobs.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 05-26-2009, 03:26 PM   #1003
CR_TurboGuy
Iowhat?
Oddometer: 478
I've got a Lincoln Pro-Mig 175, the back label has these two sets of numbers:
U1050810644
11009
My question - is there a spool gun available for welding aluminium for this welder? Also, this model has the a,b,c,d,e current settings. Could I order an adjustable switch to replace the existing switch & get variable current?
--JOsh
Old 05-26-2009, 09:44 PM   #1004
andmoon
andmoon's Avatar
Oddometer: 3,190
Sorry I am too lazy to read all the posts and search isn't too helpful....
I want to buy a 110v wire feed welder to practice welding. My only welding experience was going blind trying to stick weld. My welding will be 1/4 inch mild steel or thinner.
Which model welder do you rec.? The cheaper the better.
Don
POVERTY SUCKS
andmoon is offline   Reply With Quote
Old 05-27-2009, 08:57 AM   #1005
LoJack
LoJack's Avatar
Oddometer: 1,606
Originally Posted by WIsixfitty
Noice.
Madison. www.banjobicycles.com
LoJack is offline   Reply With Quote
Times are GMT -7.   It's 02:24 AM.
