Old 01-10-2010, 05:32 AM   #1216
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 681
maybe at the very heaviest duty a tow hitch into my car etc.
That's about the very last place you would want to weld when you are learning...especially with an el-cheapo mig.
Gary
Gas Hog is offline   Reply With Quote
Old 01-10-2010, 09:40 AM   #1217
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,540
Gary
How about *eventually* a tow hitch?
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 01-10-2010, 10:07 AM   #1218
gsweave
Yinz, blinkers are on.
gsweave's Avatar
Oddometer: 9,976
Originally Posted by Inane Cathode
If i'm a noob at mig welding (a few tries, seat rails into my car [that i'll have to cut out cause its wrong anyway]) whats a good size/brand to get into?
Lets say i have a shoe string budget, and the best i've got for power supply is standard house mains. How many amps should i be looking for? Brand? Supplier? All that i'm looking to do is little projects, roof rack for the car, body panel repair, maybe at the very heaviest duty a tow hitch into my car etc.
AC-255 20% duty cycle
http://www.mylincolnelectric.com/Cat...rs&locale=1033
If your looking for me. I will be at Rella's eating Blackberry pie.
http://advrider.com/forums/showthread.php?t=791094
http://www.youtube.com/watch?v=_ampAFmwP_E
gsweave is offline   Reply With Quote
Old 01-10-2010, 05:54 PM   #1219
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 681
Still wouldn't be my weapon of choice for a hitch..but if you know what you are doing you can get away with a lot of short cuts.
I guess my point is when you are just starting out.. start with projects that don't envolve life and death. I have seen some real messes with hitches.
None of us are born with much knowledge..we all have to start somewhere.
Gary
Old 01-10-2010, 09:52 PM   #1220
Inane Cathode
Cheated Anion
Oddometer: 4,540
Gary
Absolutely. I'll probably just stick with minor stuff. Luggage racks, roof racks, so forth.
_______
Pokey The Wunderbus
The VEEP Project
Old 01-10-2010, 09:54 PM   #1221
Inane Cathode
Cheated Anion
Oddometer: 4,540
Originally Posted by gsweave
Stick welding though? Isnt that a bit clumsy/advanced/powerful for sticking conduit and light angle iron together?
_______
Pokey The Wunderbus
The VEEP Project
Old 01-11-2010, 07:35 AM   #1222
gsweave
gsweave's Avatar
Oddometer: 9,976
cheapest entry into welding anything.
If you can arc weld the others are easy.
Old 01-13-2010, 07:24 PM   #1223
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,072
Just got a Uniweld mini torch set to play with.
I took a gas welding class during the summer as part of my A&P program and I thought I was doing pretty good, but I'm having trouble getting started.
I'm working with 16ga mild steel. The tip size is #2 and my filler rod is 3/32" RG-45 (I know too big, but its the smallest i've been able to find).
It seems like the tip is running way too hot.
We were working with the same steel and thickness, but we were using Harris torches with 0 size tips.
I can't seem to get a puddle going. It pretty much goes from dull red to gone in half a second and the filler rod isn't cooperating too well either.
Also when we were doing the class it was about 98 degrees outside as opposed to the 55 it was today.
Suggestions?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 01-13-2010, 07:48 PM   #1224
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,907
The #2 tip is too big, even a #1 might be a bit big, the "O" you were using in school would work prolly the best.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 01-13-2010, 08:44 PM   #1225
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,072
Cool thanks!
This sounds kind of dumb, but are most tips the same or do I specifically need one from uniweld, I know mixers are often different but we're just talking about the tip here.
Old 01-14-2010, 07:58 AM   #1226
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,907
Originally Posted by EvilGenius
Cool thanks!
Actually that's a pretty good question that I don't know off hand as I don't know the uniweld brand. I've always used Victor which is prolly the most common torch. There are a lot of knock-offs of the Victor torch out there and swapping tips could very well be possible. I would simply take your existing tip with you and see what the welding supply shop has that is a match. You want all of the little "o" rings on the tip to seal in the torch handle or you could have a problem.
Old 01-14-2010, 08:12 AM   #1227
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,072
That's what I was planning.
I did find last night that some of uniwelds tips are virtual copies of a particular Harris tip, but I lost the site.
Old 01-20-2010, 12:11 AM   #1228
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Send a message via MSN to r00t4rd3d
Would a gas-less MIG welder be okay for making racks and pannier supports ? One of my old jobs I did alot of stick welding but really cant afford a setup like that and was looking at a couple cheaper MIG welders. Also Ive never ran a MIG welder but have read if I can stick weld okay I should be able to MIG weld with no problems. What should I get ?
03 Honda XR250R
r00t4rd3d is offline   Reply With Quote
Old 01-20-2010, 05:22 AM   #1229
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,072
It'll be fine, just not very pretty.
Like stick welding.
MIG welding isn't any different in concept than stick, you just have to adjust wire feed speed with the dial instead of your hand.
I'd wouldn't go with anything capable of less than 140 amps for what you're doing.
Old 01-28-2010, 06:13 PM   #1230
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 1,702
http://www.sealseat.com/prod01.htm
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Times are GMT -7.   It's 03:40 AM.
