01-28-2010, 06:17 PM
#1231 | |
Motorsick
Oddometer: 1,703
Go to Home Depot and buy a Lincoln Power MIG 140C.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. It is not the destination, it's the journey. |
02-06-2010, 12:30 PM
#1232 |
Oddometer: 1,851
i'm trying to install an aux felt cell on my st1100. over the net i bought a used cell. when i got around to looking over the cell i noticed that to make me feel comfortable about my install, i need to strengthen the main attachment points,with a bushing. there's nothing that i've found "off the shelve" so i'm toying with the idea of making this. i've decided to use some 4130 crome-molly to fab two bushings. the plan is to weld some .5" dia(wall thickness .i25") tubing to a washer (home made fender washer...also .125 thick). the only welding equipment i have on hand is a stick welder.today at the local h.d. store i noticed that they sell 3/32 welding rods, although i will probably buy at the local welding supply place. this will be the smallest thing i ever tackled with such equipment- is it possible to weld something this small? i'm already assumeing that i'll have to clean it up with a dremel tool and files.oh yes i nearly forgot, i also have a rather small mapp gas/oxy set. i,ve alrerady assumed that this is too under powerd to weld steel, even something this small- i'd be delighted to find i am wrong about the gas approch.
02-06-2010, 09:34 PM
#1233 |
Cheated Anion
Oddometer: 4,540
I built a roof rack for my car as my first real welding project. Hobart 125 handler, flux core wire. Galvanized (i know, no problems) half inch conduit and some 1/8th inch flat stock for gussets etc.
Flux wire welds dont look that bad, i think. It's just the ash, slag, and occasional splattery dots that make it look bad :) |
02-08-2010, 09:24 PM
#1234 |
Oddometer: 1,851
i was intending to get by with what i had onhand. i'm guessing that i'll just have to go out and buy a pound of 3/32nds weld rod and just see if i can.
02-08-2010, 10:45 PM
#1235 | |
Two-wheelin' Fool
Oddometer: 2,566
02-14-2010, 05:20 PM
#1236 |
1.5 Finger Discount
Oddometer: 20,073
When gas welding, is it a terrible thing to go back over a bed you just finished with the torch and redo the bead without adding anymore rod?
In our A&P course they were pretty much telling us you have to get it right on the first pass or it's no good. But I don't see how it would be necessarily any different to go back and smooth out the bumps if you're not over heating or melting anymore material. Just slightly reshaping what was already puddled.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
02-24-2010, 06:51 PM
#1237 |
oldertrble
Oddometer: 23
I need to shorten my side stand 2" due to lowering my bike - how is this done?
Thanks Steve
When you're in jail good friends will come and bail you out. Your BEST friends will be in the cell next to you saying, "Damn, wasn't that fun." 690 KTM SM 690 KTM Enduro 2008 KTM Superduke (orange, the fastest color) |
02-24-2010, 08:40 PM
#1238 | |
Dirty Old Man
Oddometer: 771
Ride the DEZ 05 FE 550 Husaberg plated 09 KTM 690 |
02-25-2010, 04:50 AM
#1239 | |
Adwrenchurer!
Oddometer: 2,418
If you have, and want to retain, the stock wide "foot" at the bottom, you may want to cut out a section from the lower middle of the sidestand, and reassemble (weld, braze, pin, splint, etc.) the outer pieces. The other alternative is cutting the bottom off, and then welding on a home-made foot. Beware that if you lowered your bike 2", it doesn't automatically imply that the sidestand has to be shortened by 2" as well. Likely, in lowering your bike, the spring rates/sag have changed as well, as did the leverage ratio of the wheels/sidestand/CofG system. You may want to experiment before deciding on the final length. -- Ilya
'07 Ducati 1098 - tentatively, FOR SALE '09 KTM 690Duke - the best street bike I ever had! '08 KTM 450EXC-R - two seasons of NE enduros, and still going strong '02 Suzuki SV650 CCS/LRRS #760 Expert |
02-25-2010, 09:07 AM
#1240 | |
Two-wheelin' Fool
Oddometer: 2,566
Normally your weld filler metal is much stronger than your base metal. The application of heat to the base metal alters the properties slightly and there is a heat affected zone between the filler metal and the base metal. Adding more heat increases the size of the heat affected zone and makes it more likely to fail, along with distorting your welded piece more. You'll also notice some slag on top of your weld. There may be additional inclusions just below the surface. If you need to "fix" your weld, you would normally grind it down to get rid of the surface slag and any near surface inclusions. |
02-25-2010, 10:24 AM
#1241 | |
1.5 Finger Discount
Oddometer: 20,073
02-26-2010, 07:08 AM
#1242 | |
Two-wheelin' Fool
Oddometer: 2,566
02-26-2010, 07:22 AM
#1243 | |
Old Guy nOOb
Oddometer: 2,686
I did it the most complicated way possible. I made it adjustable by splicing in some custom machined parts. The sleeve has internal threads and the knurled ring is a lock nut. Turns out I never need to adjust it, I think I have gotten smarter about choosing the slope where I park, so my perceived need for adjustability went away. [IMG] [/IMG][IMG] [/IMG]
It isn't the conditions its the decisions Don't bring a motorcycle to a car fight |
03-08-2010, 02:05 PM
#1244 |
Aspiring advrider
Oddometer: 3,345
What tungsten types do you use for Aluminum? I've been using red but picked u a Grey and Orange to try out. Although, I've read that white (zirconated) is good.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub "Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer |
03-08-2010, 02:46 PM
#1245 | |
n00balicious
Oddometer: 2,909
Zirconiated tungsten is color coded brown and yes it is good when welding AC. ://www.millerwelds.com/resources/articles/tungsten-electrode-guide
"I couldn't wait for success, so I went ahead without it." |
