Old 03-12-2010, 08:12 PM   #1246
Toyanvil
Toyanvil's Avatar
Oddometer: 1,405
I am looking at replacing my 1989 Millermatic 35 with a Millermatic 211 Auto-set with MVP and Spoolmate 100 series spool gun for aluminum. Would this be a good set up for my home? I would like to weld aluminum, but I usually weld wild steel .065 to 3/8"
2004 BMW 1150 GS-1993 BMW R100GSPD-2009 Yamaha TW200 1961 Sunbeam Alpine
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Hell, some of the places I’ve been there weren’t even roads!
Toyanvil is offline   Reply With Quote
Old 03-15-2010, 07:48 PM   #1247
KRS
Sand.... My Nemesis
KRS's Avatar
Oddometer: 333
How crazy is it?
Current Bikes: '07 DL1000
Past Bikes: '00 KLR650, '92 Vulcan, '86 Seca 650RJ
KRS is offline   Reply With Quote
Old 03-15-2010, 07:59 PM   #1248
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,345
Does anyone else goof around with these welder things? It's a fun new toy.
I had to try it. I won't show you the half dozen I vaporized before I got the settings right.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 03-15-2010, 08:04 PM   #1249
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Nice one! Now try for an edge to edge fusion lap weld.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 03-15-2010, 08:06 PM   #1250
SimpleSimon
Aspiring advrider
Oddometer: 3,345
I did....
The only problem is...I can't get my welder to go below 5 amps and it won't let me turn off pulse. I can get two to stick..but it looks like ass and half of it blows through in a few spots.
I'll leave it up to the real welders and not some bored nerds like myself.
Old 03-15-2010, 08:24 PM   #1251
LazyBoy
stressless adventurer
LazyBoy's Avatar
Oddometer: 151
In response to Toyanvil....I really like my MM211. I think it's the perfect size for home use. Works pretty well on 115v but mo' betta on the 220v. I just got a spool gun but unfortunately haven't set it up yet. Lots of info and help on the Miller forum. It's become a very popular choice for the hobby welder. Hope this helps a little.
IBA #7230
LazyBoy is offline   Reply With Quote
Old 03-15-2010, 08:33 PM   #1252
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,910
Originally Posted by SimpleSimon
I did....
Aluminum beer cans are pretty hard to weld too.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Old 03-15-2010, 08:43 PM   #1253
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
I did....
Maybe do a series of back stitch welds? I'd just like to see a picture of it. You don't have to waste gas over it on my account.
Old 03-16-2010, 07:16 AM   #1254
MommysLittleMonster
MommysLittleMonster's Avatar
Oddometer: 778
try two on the sharp edge
then after that try cans
05.5 KTM Adventure S
03 KTM 625 SXC
www.BBFabrication.info
Beef up your KTM Adventure subframe!
http://advrider.com/forums/showthrea...2#post13099772
MommysLittleMonster is offline   Reply With Quote
Old 03-16-2010, 08:09 AM   #1255
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,074
Which would be a better surface for a weld table?
Flat solid steel top or heavy gauge steel grating?
The flat would suck more heat out of the metal during welding, but the grating wouldnt warp nearly as easy.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 03-16-2010, 10:24 AM   #1256
SimpleSimon
Aspiring advrider
Oddometer: 3,345
I tried and failed miserably. What did you use as a heat sink/settings? I just haven't figured out the right settings on my unit. Even at low settings, it just peels the blades back once I get near the edge.
Not the most productive thing I can do with my Argon.
Old 03-16-2010, 02:00 PM   #1257
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,444
Every table I've worked on has been steel plate ranging fron 3/16 to 1/2". I've never seen anyone use grating for a weld table. You want a surface that is very flat and easy to clean. Steel plate can be cleaned with an angle grinder and/or wire wheel. I've never had any issue with the table warping.
Pablo83 is online now   Reply With Quote
Old 03-16-2010, 04:58 PM   #1258
gsweave
Yinz, blinkers are on.
gsweave's Avatar
Oddometer: 9,976
Two inch thick carbon steel. stout stop fooling around.
If your looking for me. I will be at Rella's eating Blackberry pie.
http://advrider.com/forums/showthread.php?t=791094
http://www.youtube.com/watch?v=_ampAFmwP_E
gsweave is offline   Reply With Quote
Old 03-16-2010, 05:41 PM   #1259
SimpleSimon
Aspiring advrider
Oddometer: 3,345
I saw a nice welding table that had a fold-old plasma cutting grate. They used sheetmetal pieces to be load bearing in the grate so they can easily swap them out should they get butchered during cutting.
Old 03-16-2010, 05:44 PM   #1260
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,074
The grating I'm looking at is 1/8" steel strips about 2" wide and about 30" long. They're setup on their sides and run parallel to each other about 1 to 1.5" apart.
Times are GMT -7.   It's 03:36 PM.
