05-31-2010, 09:52 PM
#1396 | |
Syndicated
Oddometer: 11,286
06-01-2010, 02:12 AM
#1397 |
Oddometer: 883
I'm looking at purchasing a new welder ( only have an old Arc ) , Ive been away from welding for years but I used to do it a lot in my work . I want at least a Mig , gasless or both .
Even something that could weld aluminium would be good ? What's new in Welders now ? I just think I seen one that can do Arc , Mig & Tig , is that true ? Thanks
06-01-2010, 03:46 AM
#1398 |
Oddometer: 344
I aquired a DC-TIG welder not that long ago. One of those older transformer based units. It came with a WP-17 torch.
Now, I'm used to small and light tools (in my daily life I do some soldering which often involves electronic components with 0,5mm/20mil pin-to-pin pitch). That WP-17 torch is quite huge, and the hose connecting the torch to the welder is not that flexible at all. This is especially a 'problem' when welding small-diameter pipe. I suppose it will improve with more hours behind the torch, but still. Since I am welding below 100Amps with an 1,6mm - 1/16" tungsten 90% of the time: aren't there smaller, lighter torches with a more flexible hose/cable? What's the hot setup for this? |
06-01-2010, 07:11 AM
#1399 |
n00balicious
Oddometer: 2,918
The low quality welding cable is not as flexible due to it has less strands of wire while making the same gauge as quality cable. Also air cooled torches are more bulky than water cooled.
"I couldn't wait for success, so I went ahead without it." |
06-01-2010, 07:50 AM
#1400 | |
Oddometer: 344
The machine is a Lastek LASWIG 160 DC-H. Which is, as far as I know, a relabeled Fronius design. Should be OK, right? The ground clamp is a sturdy one with heavy gauge flexible cable. Not one of those Chinese welding cables with a crocodile clamp on it. I think the torch is the same quality, but they wrapped the welding hose/cable plus the control cable in a woven (nylon?) sheeting to prevent damage. I think that it's designed for far higher currents than what I'm using, which requires heavier gauge cable and a larger torch than necessary. Is the difference in 'ease of manouvring' between a nice, small watercooled torch and the WP-17 aircooled torch huge? And which one would you recommend for up to 100Amps welding current (80 amps would be fine too) and 1,6mm (1/16") tungsten? |
06-04-2010, 04:16 PM
#1401 |
Old Enough To Know Better
Oddometer: 5,518
Dumb question time...
I know you can't lay gas cylinders down and draw from them if they contain liguid (like acetylene tanks with the acetone and maybe CO2 which is liquid at normal tank pressres), But, can you lay argon and argon/CO2 (C25) cylinders down while using them? My reason for asking is that I'm looking at shrinking the footprint of my MIG cart. I already put up with using a 40 cu ft bottle of C25 to keep the package small, but I noticed that if I could position the bottle under the welder just a few degrees above horizontal I can trim the cart down to make room for other things on the limited floor space I call a garage/shop. TIA.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
06-04-2010, 04:43 PM
#1402 | |
Two-wheelin' Fool
Oddometer: 2,565
06-04-2010, 04:49 PM
#1403 |
Syndicated
Oddometer: 11,286
What °K is your workshop? I mean, generally. |
06-04-2010, 06:53 PM
#1404 | |
Oddometer: 5,518
But my shop probably averages around 302.6 Kelvin for 6-9 months out of the year. Yeah, it's a sweatfest all except the coolest months of the year. I have to keep an oiled rag next to the bench to wipe sweat droplets off my cheap ass Chinese mill/lathe to keep it from flash rustng overnight where I touch bare metal parts of it. I spray all bare metal tools down with Maxxima Chain Wax at least once a year to prevent flash rust from the humidity.(And it works great). Welcome to Floriduh.
06-04-2010, 07:14 PM
#1405 |
El Gran Payaso
Oddometer: 5,940
Ah, just what I was looking for.
Just bought a used Miller Dynasty 200 DX TIG, and am being given some lessons/pointers/tips/help etc. from two different welding shop owner/friends. Ultimate goal is to be able to build a chromemoly bicycle frame or even something from this website: atomic zombie I have a bunch of scrap, a table, filler rods (for steel), tungsten, etc. For now, I'm just running beads and practicing joints, at different amperages. Just trying to "learn how to ride a bike", type of thing. I purposely passed up arc and MIG welding and went straight to TIG. I know that gas welding is a good precursor to TIG welding...too late. I have two auto darkening welding helmets, and as soon as I can get decent at it, I'll be passing the hobby on to my son. I hope he stays with me and sees how I mess up. I'll be reading through this thread now that I've found it. My current roadblock: laying down "dimes"/using filler rod. I still have to find out what "dipping" really means. I'm at the point, I think, where I'm using the torch to melt the rod, and I know that's not good. Tonight I practiced correct angle on both the torch and the rod, and dipping the rod into the puddle. If there's a good video that explains how to coordinate the filler rod, amp control (foot pedal) and moving the torch along the workpiece, I'm all Just got a box of clamps via UPS today. I purpose to practice, practice, practice, then head up to Ashland to attend the frame building class at United Bicycle Institute Ergo, forgive me for not pre-reading the thread before posting. I just got all excited with I saw the title and just jumped in. Kinda how I operate.
06-04-2010, 08:16 PM
#1406 | |
Syndicated
Oddometer: 11,286
The Argon will be a gas at those temps and pressures. But at those temps the CO2 will be liquid above around 1000psi or thereabouts. Which will not be much of a problem if the liquid gas doesn't pass through the regulator. With a 25% mix the liquid will not reach the valve even with the tank flat on its side. But something to think about with an Argon/CO2 mixture is the ratio of the output when the CO2 is liquid. |
06-04-2010, 09:12 PM
#1407 |
Oddometer: 5,518
That last sentence is an interesting point. (You can tell I'm not up on all the relevant gas's behavior.) But as a mix, will the CO2 precipitate out and liquefy at around 1K psi? Or being in a mixture, will it remain in the gas state and in the mixture? I'm guessing since argon is inert, there would be no molecular bonding in the mix to prevent separation, and the gaseous mixture is sustained primarily/only by Brownian Movement.
If the CO2 is sloshing around as a liquid in the bottom of the tank until I draw the pressure down below the liquefication threshold, I'd be more worried about it hitting the regulator as a liquid if I had the tank laid down too far - not very likely if C25 tanks have no siphon and draw from directly under the regulator, but if you knew my luck with abnormal incidents... Are all you lurkers taking notes? This is one of those light hearted give & take exchanges that should illuminate some of the more esoteric issues that sooner or later come into play while you're welding.
06-04-2010, 09:24 PM
#1408 |
Syndicated
Oddometer: 11,286
You can always mix your own, with one tank each of argon and CO2. Get you a couple of cheap Chinese flow meters, and crank up the CO2 above 25% when the conditions need it. |
06-05-2010, 12:40 PM
#1409 |
El Gran Payaso
Oddometer: 5,940
Stacking Dimes
The classic "stack of dimes" look - I read somewhere in this thread that it applies to aluminum.
If so, why not steel.....but more importantly.....how does one coordinate amp control/filler rod/torch movement to get the "look"
06-05-2010, 10:54 PM
#1410 | ||
Sleep, Wrench, Ride
Oddometer: 4,449
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
