Thread Tools | Search this Thread |
Rating:
Display Modes |
03-08-2007, 08:51 AM
#1 |
Oddometer: 5,248
Easy Garmin Mapsource Routing for N00bs (Tutorial)
Mapsource is cumbersome... Auto-routing doesn't always take you where you want to go so... How do we tell it where we want to go?
Since this is a pretty frequently asked question around here, I figured I'd share my method with you FF's. This is the quickest way I've found to set it up right. First, You plug in your start and finish points using the Route Tool on Mapsource. An Example... Red Mesa to Hurricane First click on Red Mesa, then click on Hurricane. ![]() The screen will spit out this. Note: I'm using towns already easily visable. If you want to go from a specific location... simply zoom in and find it or use "FIND" and mark it as a waypoint first. Trouble with this route is that I really wanted to take the north route around Lake Powell. Question is, how do we make it route us that way? Simple as using the Selection Tool, the little arrow, and clicking on the route. First click will turn it Yellow, next click will draw a line from start to end that bends with the pointer. Drag it to a place on the way of your preferred route and click. ![]() It'll autoroute again... ![]() OK, thats close to where I want to go... repeat until you have it. ![]() Note: Added Escalante...look for the green dot along the route. There, thats the route I wanted to take. Transfer it to your GPS and turn it on from the Route File. Do Not let the GPS recalculate this route for you...It'll generally offer. Cheers ![]() Bet theres a lot of N00bs who didn't know they could do this. Download the attached route to your My Garmin folder... I actually have a sub-folder "Routes" inside there... Open... ![]() You've updated to the latest Mapsource right? [geek] ![]() ![]() In GE, Tools...Play Tour... ![]() Ridin' the Dragon, who..hoo.. ![]()
CMWoody screwed with this post 12-21-2007 at 04:07 PM |
03-08-2007, 09:08 AM
#2 | |
Oddometer: 9,698
BTW, with some some GPSs (noteably the 60 and 76 series), all that got transferred from MapSource to the GPS were your user-defined via points that define the route, so a recalc on activation is ALWAYS done. - Mark |
03-08-2007, 09:35 AM
#3 |
Oddometer: 103
I didn't know that!
Thanks! How do I prevent the recalc? I have two options on a Rino530: shorter distance, faster time. After selecting I can cancel. Will the cancel retain the uploaded route?
06 TE250 Plated, 05 CRF50, 03 DR-Z125L 02 XR80, 04 RM125, '76 WR250 "I suppose that's the great romantic lure of the motorcycle; it's a key to adventure" - Steve McQueen |
03-08-2007, 09:36 AM
#4 |
Oddometer: 5,248
removed
CMWoody screwed with this post 12-21-2007 at 12:37 PM |
03-08-2007, 11:46 AM
#5 | |
REMF
Oddometer: 8,546
Somehow the 276c and other units transfer exact routing info, keeping the route the same as you planned in Mapsource. I originally thought this would be a problem with my 60Cx, but it's not a big deal in real world usage IMHO. Some discussion here: http://www.advrider.com/forums/showthread.php?t=139836
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
03-08-2007, 12:47 PM
#6 |
Oddometer: 714
Hey thanks for the hints cmwoodys.
My theory is ... in the future everything will double as an iPod Dock. |
03-08-2007, 12:56 PM
#7 | |
Vstromdek
Oddometer: 141
03-08-2007, 01:07 PM
#8 |
Oddometer: 9,698
Yes, this incremental building of routes (rubber-banding through your via points as you refine it) is the only way to fly with MapSource. I think a lot of folks never figure it out as it is fairly counter-intuitive to have to first click the route to select it, then click it again to stretch it. I would expect a dragging UI, although I think they do it the way they do so you can do other things like scroll and select other tools while in rubber-banding mode.
The issue of routing discrepencies between MapSource and the GPS has been a long-term bugaboo for Garmin. In addition to the GPS-varying mandatory-recalc problem discussed here, there is the issue that routing preferences are globals in both MapSource and the GPS, rather than "sticking" to routes. If these preferences were made properties of routes, they'd get transferred along with the route so you wouldn't have to manually make sure your preferences stay sync'ed. I suspect the reason for this problem is that Garmin never has standardized on a GPS-independent standard for routing preferences, so with 300-odd models in the field, trying to get everything the same would be an exercise in herding cats. - Mark |
03-08-2007, 08:15 PM
#9 |
Runs at Mouth Adventurer
Oddometer: 1,214
Very nice article! I would like to add one comment:
When you are auto-routing in the boonies, you may not end up with many turn prompts since the program doesn't have any "major" intersections to work with. I like to add a via point at most minor intersections, and at major features like a river or lake access. This way I get some "approaching via point" prompts that normally wouldn't ever occur with a basic computer generated route. John Davies Spokane WA |
03-09-2007, 07:49 AM
#10 | |
Vstromdek
Oddometer: 141
03-09-2007, 08:10 AM
#11 |
Oddometer: 7,607
Cool. I didn't know you could do that with Mapsource. Thanks for taking the time to post it - I'm going to bookmark it.
03-09-2007, 09:44 AM
#12 | |
Aged Adventurer
Oddometer: 1,110
Also, via points at intersections tend to be ones that you are going very slow at. Slower speed means a much smaller tolerance for 'hitting' the spot. Just past the intersection usually means you are rolling along again and you'll 'hit the spot' almost every time. Good info here.
Phil in Seattle, WA |
03-10-2007, 08:36 AM
#13 |
Allergic to Asphalt!
Oddometer: 5,979
Nice write up!
Too bad it only works w/ the city map and not the topo, where the good roads & trails are. Thnks, Dan
03-16-2007, 09:02 AM
#15 |
Have bikes, will travel
Oddometer: 529
Ditto
This is a great trick!!! This will make routing a trip of Rt66 easy as opposed to a chore.
