Old 10-27-2009, 10:08 AM   #1546
matloik
kludge
matloik's Avatar
Oddometer: 1,253
Originally Posted by mmitchell57
Made some more progress this week. Check out the pictures.
Not to throw a wet towel on to your project, but ... are you following any building codes, at all? Prescriptive? Got your lateral bracing needs covered? Are your headers sufficient? Does the ground ever freeze there, or could it settle? I can't tell from your pics if you've got any kind of below-grade foundation piers or... I'd hate for your windows to crack and your doors to get stuck ...
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is online now   Reply With Quote
Old 10-27-2009, 10:39 AM   #1547
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Living in southern NC the ground doesn't freeze. I'd worry if I was more north. Also, living in the county, this isn't considered a perm. building, so it's basically a shed. I'd even go to say that 70% of the yards have some type of shed on skids in the back yard. All that's required for a shed is 24 on center walls with 16 on center 2x4 floors. In comparison to the other trash I've seen in the neighborhood, this one is far better.
The only that I'm worried about, and will add extra support too, are the load bearing parts of the floor. That's not to hard to fix with some sweat equity.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 10-27-2009, 10:41 PM   #1548
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,326
Tirebiter,
How old is that drill press?
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 10-28-2009, 12:58 AM   #1549
duckrider
User Awaiting Email Confirmation
duckrider's Avatar
Oddometer: 993
Originally Posted by tirebiter
Less is more...
How many beers did it take to put up that back shelf?
duckrider is offline   Reply With Quote
Old 10-28-2009, 03:52 AM   #1550
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 5,012
Guess thats how it comes out when you work with one foot on the edge of a milk crate and the other on a lawn mower handle.
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 10-28-2009, 05:00 AM   #1551
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Less is more...
Good gracious man, you have a shoe horn for getting in that room?
Old 10-28-2009, 08:53 AM   #1552
inspectorpacket
back in the saddle again.
Oddometer: 234
goodies for the man castle
ran across this today on a great tool blog.
http://toolmonger.com/2009/10/27/com...for-your-shop/
inspectorpacket is offline   Reply With Quote
Old 10-28-2009, 11:31 AM   #1553
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Crap man, as if my "I want for the work shop" list isn't long enough! lol Good find and it looks easier then most other kits i've seen.
Old 10-28-2009, 11:53 AM   #1554
CR_TurboGuy
Iowhat?
CR_TurboGuy's Avatar
Oddometer: 478
Can't speak to the quality, but saw a similar system from HF a while ago - seems like a good deal.
http://www.harborfreight.com/cpi/cta...emnumber=66747
--JOsh
1990 Yamaha XT600E - Old Faithful
1983 Yamaha CV80 Riva/Beluga Scooter - Scooter Trash
CR_TurboGuy is offline   Reply With Quote
Old 10-28-2009, 11:57 AM   #1555
VTvfr
VTvfr's Avatar
Oddometer: 445
--JOsh
Exact same system
Chad
'07 990 Adv
'07 250 XC-W
(plated)
'03 600RR
(track duty only now)
'94 VFR750 (sold)
VTvfr is offline   Reply With Quote
Old 10-28-2009, 03:41 PM   #1556
BigEasy
BigEasy's Avatar
Oddometer: 1,793
FWIW I use this stuff in a commercial application at work. I am in the environmental clean up business and have to install relatively disposable systems to cure problems. At one of my sites I have 3 150 hp/750 CFM air compressors to do my clean up work. I bought some rapid air kits to run local air in my site workshop area and it rocks. It was easy to work with and so far has been worry free after about 6 months.
A friend wants me to run plant air in his new Man Castle and this is the shit I'm gonna use to do it. What would be a 2 day job will take me less than 6 hours from what I can tell.
I just looked at the blog link and there were 2 bitches: price of the tube, no dryer. I can buy cheaper tubing all day long but it will not hold pressure over time. High pressure air line breaks aren't fun take my word for it. Air line dryers are not expensive and can be had by the superhuman effort of, oh let's say a trip to WalMart, or Harbor Freight.
All who wander are not lost
"Play hard and FLOOR IT" Stevie Ray Vaughan
just remember: the only difference between genius and stupidity is genius has limits
BigEasy is offline   Reply With Quote
Old 10-29-2009, 04:12 PM   #1557
Juice Box
Got Ink?
Juice Box's Avatar
Oddometer: 2,905
[IMG][/IMG]
Juice
www.dualsportridersoflouisiana.com
Juice Box is offline   Reply With Quote
Old 10-30-2009, 03:46 AM   #1558
rick danger
Off the wagon
Oddometer: 5,012
When I did my shop I ran 1/2" black pipe all over the place for air. I'm not sure I would want anything else that was going to be sheetrocked over and inaccessible. It was alot of work though. If I would have used plastic I would want it surface mounted.
Old 10-30-2009, 04:38 AM   #1559
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
For some odd reason, that's what I was thinking this was until you noted it wasn't. I would expect to run this surface mounted as well. If I was to go and put it behind drywall, i'd definitely go w/ pipework. The kit he shows does remind me of the rigid hose quick connect stuff. It's like pipe, but the connections are like that of this hose system. The benifits of this flexible conduit appears to be that you only cut one lenght, run it, and hoook it up. Nice. In theory, what the trade off?
I'm not trying to give the guy who posted it a hard time. Just running a quick pro vs. con to see how it fits to people's applications. I'm honestly still lusting over it.
Old 10-30-2009, 04:39 AM   #1560
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Nice lift! Nice start to a bike. What type is it? Doesn't appear to be the typical DRz or KLR.
Times are GMT -7.   It's 10:05 PM.
