Old 12-20-2009, 10:14 AM   #1861
propforward
PIE!romaniac
propforward's Avatar
Oddometer: 12,668
Originally Posted by Gas Hog
How do you like it so far?
Very much indeed! It is a basic belt drive back gear lathe - but because the headstock is a little more basic (change the belt to change speeds etc) it means that you get a lot of features for your money. This one has automatic cross feed as well as the normal feeds, and an excellent range of speeds, forward and reverse on the motor, metric and standard threading gears. I am pretty impressed with the overall quality of the machine. With the back gear it can drive slowly enough to work large diameter steel, and it also has a removable gap on the bed. In real terms way more capability than I really need for most of my projects - but my view is that on these kinds of tools (tools in general) you are better off going for something more capable than you need, as they generally last longer. Came with a pretty good tool set too. Faceplates, 3 and 4 jaw chucks, steadies and live and dead centers. It came with a solid base, but it was too low for me, so I made the wooden frame you can see there. In any case my workshop floor is all broken up, so I had to make a base in order to get the lathe level.
I tried to find a used American made machine, but they hold thier value, and really rough ones are as expensive as the new Grizzlies. Then the opportunity came up where I got given this, for various reasons I won't go into. So it worked out, and having it around has been brilliant.
As you know - you do without, and then when you get one you wonder how you managed. Or else you just do stuff you wouldn't normally have done.
It's not a man purse, it's called a satchel.
Indiana Jones wears one.
propforward is online now   Reply With Quote
Old 12-20-2009, 01:45 PM   #1862
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,499
Laconic is offline   Reply With Quote
Old 12-21-2009, 05:04 AM   #1863
crawdad
Oddometer: 469
Lots of great pictures in a great thread!
Had to add another mill this year, and just didn't have the room with all of the bikes parked everywhere.
So did a expansion on the end of the building. Not even close to done but at least I can shut the doors. Got the floor painted under the machine but still have the rest of the floor to finish. Note on the floor paint..I am using Sherwin Williams Tile Clad epoxy. Which will dry on its own..but I have a fairly thick pad at 18 inches with the in floor heat. You have to hustle when rolling it on and the concrete is 82 degrees..
Still have the walls to finish..but not completely sure what I want there yet. Going to do a bunch of overhead cabinets at the 10ft level to try and keep some floor space open. It is amazing how fast it disappears
Here is a shot of my fleet crammed over in the corner. And a shot of the new Horizontal.
Need to get the floor finished so I can get a few more of the larger pieces skated in.
A lot of work...and still more to go... but hopefully it will pay dividends in the coming year. Now what the hell am I going to finish those walls with...
Gary
Hey Gas Hog, If you don't mind my asking what kind of work do you do? I notice in a later post you mentioned lots of recoil pads, firearms industry? Just curious, if its none of my business just say so. No offense. I lived in Co. in the 80's and worked in a machine shop in Broomfield. I miss that work, and Colorado too.
crawdad is online now   Reply With Quote
Old 12-21-2009, 05:58 AM   #1864
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 1,015
257bob,
That looks a lot like my project not all that long ago..except you have a lot of interior walls going on. So what is the plan
crawdad,
Yes much work in the bang bang world. Just parts now..mostly motorcycle the rest automotive.
So in my latest trip to the big city I got a few items at the Harbor Freight. I ended up with some of the smaller plastic stackable trays. I got them outlast night and got a start on my bolt bin project. The come with rails to hang them on the wall but I am stacking them on some rivet rack I got the same day. These are real decent little trays if anyone is looking for some. Next trip down I am going to load up, they come 20 to a box.
Gary
Originally Posted by rtwdoug View Post
It was made out of chinesium, which is sort of like metal, only softer
Gas Hog is offline   Reply With Quote
Old 12-21-2009, 07:15 AM   #1865
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,499
257bob,
Nothing as elaborate as yours....
1145 sq.ft. energy star home with 22' x 34' attached garage. Not as big as I would have liked, but bigger than I've ever had.
Old 12-21-2009, 08:04 AM   #1866
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,223
GasHog -- I'm a little a concerned that your machine seems to be sitting in a giant pool of water...what the hell is that all about?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 12-21-2009, 10:12 AM   #1867
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 1,015
Not at all, this extension is just 4 walls..with a big money pit on the floor...
I did get a few of the things I wanted done, but not without a lot of "do it my way or else" speeches.
No one could understand why I wanted the pad so thick..or why I was putting insulation under the pad...or "what do you think that little plastic pipe in the pour is going to do?"
If I was doing a job as complex as yours there would be bodies everywhere.
DevilNinjaDog,
Yes that is a concern I think my in floor water heat may be leaking...
Or I just mopped the floor...one of the two
Gary
Old 12-21-2009, 10:27 AM   #1868
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,499
DevilNinjaDog,
Gary
Well, we're paying someone to do the build for us; contracting a house would interfere with my day job. (Although I am thinking about flying Pecos Bill in to do the heated slate floor on the sunporch. )
I considered slab on grade, in-floor heat but there was a little too much slope for the slab. Also, we are where a/c is a must, so I would have had 2 systems to install. My brother has used the in-floor heat up in Maine; there is absolutely nothing like it.
Laconic screwed with this post 12-22-2009 at 05:45 AM
Old 12-21-2009, 10:54 AM   #1869
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Originally Posted by rick danger
garage
All those tools and equipment and you haven't made a paper towel holder!
scooteraug02 is offline   Reply With Quote
Old 12-21-2009, 12:36 PM   #1870
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
His inner artist comes out when arranging the paper towels, why would he organize them!
Do you talk to people you meet on the road?
Home is where the skid lid sits.
xcgates is offline   Reply With Quote
Old 12-21-2009, 12:50 PM   #1871
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 5,002
Now you know I have to weld one up out of solid 1 1/2" round and some 6"x6"x 3/4" angle.
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 12-21-2009, 01:06 PM   #1872
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 12-21-2009, 05:13 PM   #1873
Wreckluse
Will work for beer
Wreckluse's Avatar
Oddometer: 444
Make sure you use stainless!
Indecision is the key to flexibility.
07 950 SM R
09 450 EXC dual sport
08 DRZ 400 SM Adventure
12 GasGas 250 Pro
Wreckluse is offline   Reply With Quote
Old 12-21-2009, 05:43 PM   #1874
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,940
Thumb
We have a winner! HMC with palletizer?
On sale at Harbor Freight?
I'm taking a few MasterCam X4 Courses right now. This stuff is cool as fcuk.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. screwed with this post 12-21-2009 at 05:54 PM
D.T. is online now   Reply With Quote
Old 12-21-2009, 09:28 PM   #1875
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 1,015
A Harbor Freight coupon..now that would be cool
OK a report card on some of the stuff I got last weekend. The press board shelving unit with doors...is heavy 210lbs..and a piece of crap. This is why I only buy one of something I haven't used before. Been a while since I had my hands on this stuff so I forgot. It will work to store my MC stuff in, so that is cool...but press board sucks ass.
The rivet rack I got is a different story. Made in the USA if you can believe it, and goes together in minutes. I was going to take up 3 shelves with the plastic bins for bolts and screws... but had to stop loading it up as the shelf's are ...press board.. So need to go back the lumber yard and get some 2x12's and then this will be a nice unit. I am going to snag a couple more of these.
Gary
Times are GMT -7.   It's 04:37 PM.
