Old 02-27-2010, 02:24 PM   #2131
Rashnak
Lorem Ipsum
Rashnak's Avatar
Oddometer: 9,775
Originally Posted by hcallaway
This building is between 25-30K. OSB under all the metal. 12 Eaves. Overhang all the way around the building. 16 x 32 and 16 x 20 porches. Ridge Vent. Windows and Doors. This does not include the roll up doors I will install. I did the site prep. Trusses on 4' centers. Stamped PE Plans.
These guys were out of Ohio and will travel to build pretty much any where from NC to NJ on the east coast and the mid west.
what are you gonna do inside for a floor? gravel?
Rashnak is offline   Reply With Quote
Old 02-27-2010, 04:49 PM   #2132
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,406
I am from Richmond (Chesterfield Va) and the barn is in the next county.
Way too much clay going on.
Looks like a nice building. Same soil as we have around here, by the looks.
From our current project;
Laconic is offline   Reply With Quote
Old 02-27-2010, 10:08 PM   #2133
Island Rider
solo adventurer
Island Rider's Avatar
Oddometer: 123
my dream shop
Ok, I'll jump in...here are a few early photos of my shop. I had to move 1000 miles out of California to afford it, but it was worth it. I assembled the Miracle Steel building by myself in 11 days after the concrete was pored. I thought the site prep would be easy because it was flat, but it took 300 tons of rock to get a decent bed for the slab. The soil is a bit moist.
Island Rider is offline   Reply With Quote
Old 02-27-2010, 10:16 PM   #2134
Timmer
Timmer's Avatar
Oddometer: 2,411
Nice shop, Island Rider.!!
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 02-28-2010, 03:42 AM   #2135
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,406
By yourself? Impressive. How did you find Miracle Steel as far as quality and customer service?
Nice looking place.
Old 02-28-2010, 04:06 AM   #2136
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
Is that a Unimog in the corner?
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 02-28-2010, 08:21 AM   #2137
Island Rider
solo adventurer
Oddometer: 123
Good eye RoyB. I specifically chose the Miracle Steel because it looked like it wold be doable by just me and the forklift. I thought the quality was fine and they were always helpful.
Old 02-28-2010, 09:12 AM   #2138
RoyB
Oddometer: 1,578
Talk about a pair of "All Terrain Vehicles"!...........
I'm just a nut about MOGs.............Someday.......
Roy B
Old 02-28-2010, 10:37 AM   #2139
Rashnak
Lorem Ipsum
Rashnak's Avatar
Oddometer: 9,775
what is the tubing in the foundation for?
Old 02-28-2010, 10:55 AM   #2140
RoyB
Oddometer: 1,578
Radiant heat..........Hot water will be circulated through those tubes, heating the concrete slab, creating extremely even heat. Once the floor heats up it creates a "trombe" and will hold this heat for a long period of time. Opening and closing the garage doors will not lose the built up heat like a hot air system would. This is easily the best way to heat any type of living space, but even more so in a garage.
Roy B
Old 02-28-2010, 01:01 PM   #2141
Island Rider
solo adventurer
Oddometer: 123
Yep, what Roy said. I put down 2500 feet of pex so that someday I can afford to heat the place. I will probably have to sell either the bike or the mog to afford that tthough. I do recognize the irony of having 2500 square feet of shop space and having to sell all (not really all) of the cool stuff to pay for it. I'm pretty sure that is some kind of karmic law, "Wife's karmic law of toys".
Old 02-28-2010, 02:33 PM   #2142
Bruce Caldwell
Bruce Caldwell's Avatar
Oddometer: 1,016
Wow! nice shop for sure. I wish I could afford something like that. But at least I was able to build a small shop last year that is all mine. I gave the wife the garage. My shop ain't much but at least I now have an insulated & heated/air conditioned space to work on my bike & other projects. Before, in the summer time while wrenching on the bike, within 5 minutes i'd have sweat running into my eyes.
late-braker
Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa
Bruce Caldwell is offline   Reply With Quote
Old 02-28-2010, 07:05 PM   #2143
hcallaway
hcallaway's Avatar
Oddometer: 41
The clay has dried out pretty good so I was able to start working the grade in the garage. I will lay gravel and 4-5" of 3000-4000 psi concrete. I am going to use wire mesh or a combination of wire and rebar.
hcallaway is offline   Reply With Quote
Old 02-28-2010, 08:16 PM   #2144
Badger
Badger's Avatar
Oddometer: 323
Did you leave the pink foam down for the concrete pour? and if so, how did you do the pour?
Je chasse le chien
Honey Badger Don't Give a Shit
Badger is offline   Reply With Quote
Old 03-01-2010, 08:52 AM   #2145
Island Rider
solo adventurer
Oddometer: 123
Badger- since the slab is heated it must be insulated to at least R-10. Rock, sand, vapor barrier, foam, wire, rebar, pex, concrete.
Times are GMT -7.   It's 05:54 PM.
