Old 03-02-2010, 07:20 AM   #2146
bosco
Raybanned
bosco's Avatar
Oddometer: 11,702
Originally Posted by Island Rider
Yep, what Roy said. I put down 2500 feet of pex so that someday I can afford to heat the place. I will probably have to sell either the bike or the mog to afford that tthough. I do recognize the irony of having 2500 square feet of shop space and having to sell all (not really all) of the cool stuff to pay for it. I'm pretty sure that is some kind of karmic law, "Wife's karmic law of toys".
I'm heating 600 sf w/ a conventional 40 gallon electric hot water heater and think I could easily double the square footage w/out issue. It was fairly inexpensive to implement, less than $500 for everything (pex & fittings included).
___________________________________
"It's called the American Dream - because you have to be asleep to believe it." -George Carlin
bosco is offline   Reply With Quote
Old 03-02-2010, 09:06 AM   #2147
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,279
If I had to do my garage again, I'd insulate the slab.
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Old 03-02-2010, 11:19 AM   #2148
duckrider
duckrider's Avatar
Oddometer: 993
My son heats a 2k sq ft house, a 30x60 shop and a green house with pex in the floor. He built a 300 gal box that surrounds a 3'x4' firebox. When the water temp drops to 155* the draft opens and a blower is activated. At 165* blower shuts off and draft closes. It works great and so far he's just burning slash from a pre commercial thinning project on his place.
duckrider is offline   Reply With Quote
Old 03-02-2010, 02:56 PM   #2149
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,560
Radiant heating is a good way to warm, but in the south, forced air is king for a reason - you can't cool with a radiant system. Here, cooling for a shop is often a big plus.
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 03-02-2010, 03:56 PM   #2150
lightfighter
where does this go?
Oddometer: 2,277
but I will say this, even in AZ, working on vehicles in the winter, you could not EVER beat a warm floor. and a portable evaporitive cooler wll do a 2 or three car garage real nice even on a 100 degree day. (mind you, i have niether. i borrowed a propane space heater this winter, and this summer, i'll be hot... again.)
lightfighter is offline   Reply With Quote
Old 03-02-2010, 04:31 PM   #2151
Rashnak
Lorem Ipsum
Rashnak's Avatar
Oddometer: 9,713
poor man's air conditioning
Rashnak is offline   Reply With Quote
Old 03-02-2010, 04:43 PM   #2152
StormTrooper
Enough Already!!!!!!
StormTrooper's Avatar
Oddometer: 197
Originally Posted by Rashnak
Now that is funny
2008 R1200 GSA - "I am sorry but I am out of cell phone range"
1974 CB750 - you want this for your man cave!
StormTrooper is offline   Reply With Quote
Old 03-02-2010, 07:02 PM   #2153
koncha
Oddometer: 10,044
With a geothermal loop, you can heat and cool. Not cheap but possible.
koncha is offline   Reply With Quote
Old 03-02-2010, 07:09 PM   #2154
Rashnak
Lorem Ipsum
Rashnak's Avatar
Oddometer: 9,713
I think you would have to dehumidify if you wanted to do geothermal cooling.
Old 03-03-2010, 07:20 AM   #2155
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
I'm at a mental block for the moment. What's something fairly durable but inexpensive that I could cover the top of my work benches with?
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 03-03-2010, 07:25 AM   #2156
duckrider
duckrider's Avatar
Oddometer: 993
In the summer 55* well water circulates through the floor, but seldom needed. In the summer 50* temp swings are common here. 100+ in the afternoon and 65 by 1 AM. Also it's not humid. It doesn't get really hot until mid afternoon.
Old 03-03-2010, 07:26 AM   #2157
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,629
Hardboard. use countersunk brass screws to keep it in place. Pics in a minute.
Yea, whatever.
RC Pilot is offline   Reply With Quote
Old 03-03-2010, 07:35 AM   #2158
RC Pilot
Shut up and fly!
RC Pilot's Avatar
Oddometer: 5,629
I have my bench built at 24" depth. This allows me to split a 4"x 8" sheet of hardboard lengthwise. I can then use one half and keep the second half in reserve for later. pardon the mess, projects in work. FYI, teh bench top itself is 3/4" MDF split lenghtwise and tehn screwed/glued together for an 1.5" thick super sturdy top.
One of the projects
Yea, whatever.
Old 03-03-2010, 07:43 AM   #2159
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
02tac, i appreciate the information. Looks like a good option. Thank you!
Old 03-03-2010, 07:51 AM   #2160
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,560
Cooling the water is difficult. You could just let the 'used' water run into the ground, but that is wasteful. Plus in many hot areas of the country, water is in short supply.
Also, the cool or cold slab would have some condensation on it. This water could play havoc with any flooring material you might have, as well as be a slippery surface and promote mold growth.
'13 R1200GS
'08 WR250R
Times are GMT -7.   It's 04:20 PM.
