Old 09-16-2010, 03:03 PM   #2716
propforward
PIE!romaniac
propforward's Avatar
Oddometer: 12,783
Originally Posted by Dahveed
Well, you may already be doing it. In your drawing here are the blue posts the existing barn poles?
That's exactly what they are.
Since the barn is already bearing the roof load, you can get by with 24" oc on the wall framing, especially if you're going to sheath the interior with . I would likely align the wall framing with the inside face of the posts and only use thicker lumber where required - around the window opening for example.
This is fantastic. That's exactly what I'm planning on. The 24" centers is good, I had planned on 16, but not needing to go that way is just fine.
Are you planning to deck and store anything on the ceiling joists? If you are, be sure to account for that load in the span calculations.
Good point. I am only framing in 2/5ths of the pole shed...might do more in due course, but basically there is no need to store stuff on top of the workshop. Knowing me as well as I do, I'd only put crap up there that I'd never use anyway.
In the photo of the exterior of the barn, there is a door and a garage door. What are you going to do with those openings? Your structure inside will prevent you from opening the door, won't it?
Overall it looks good.
Those are in the front of the shed, I'm going to frame in the very rear 2/5ths away from those doors.
Thanks for looking it over! Greatly appreciated. This is my first construction project, so it's all feedback like this really helps. Suffice to say I have been quizzing people with appropriate knowledge here at work too, which is how I ended up with this arrangement.
I am liking the T1-11, but it's a bit pricey. Not sure on that approach yet.
"Anyone who quotes themselves in their own sig line has a serious ego problem" - propforward
propforward is offline   Reply With Quote
Old 09-16-2010, 04:34 PM   #2717
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,562
I see, I thought you were framing the left side. The rear makes more sense.
Once again, since the barn is already doing all the heavy lifting, you could use a pretty thin sheathing material. Of course, the thiner it is the harder it will be to attach things to it.
It will be very hard to beat OSB in the price competition. That stuff is just flat out inexpensive.
One last thing (for now anyway) you might want to consider using a pressure treated (PT) lumber for the bottom plate in each section. Also I'd put a layer of roofing felt under it too. Concrete is usually porous and ground moisture will pass through the concrete and wet your wood. Of course, any metal you use in PT lumber needs to be a special double dipped zinc designed for PT wood or stainless. Also, whatever material you choose to for you interior sheathing, you need to install it 1/2" above the concrete so it doesn't wick up any ground moisture.
I've gotta run, let me know if you have any questions.
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 09-16-2010, 07:49 PM   #2718
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,526
When I lived in CA the building dept had pamphlets that stated the requirements for various projects. You could check with them that way you don't build something that later won't get approval.
Craigslist varies in different areas but I see lumber and such on the craigslist down here. You never know someone may have extra, bought materials for a project but decided not to do it or you could find something way better for less than new cheap materials.
scooteraug02 is offline   Reply With Quote
Old 09-16-2010, 08:49 PM   #2719
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Originally Posted by zenben
That's a smart idea, supporting the unit heater from underneath.
Think I'll use that idea for inspiration.
Thank you.
I didn't like the way the manufacture wanted that heater mounted, so those are 5/16 steel rods going up through the ceiling to some bracing in the attic, and that part you see is welded out of 1" square tubing.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 09-16-2010, 09:03 PM   #2720
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,562
Where I live in Texas, I don't think you can build a fire in your fireplace without a permit. I would definitely avoid getting one if its not needed. I don't think the process adds any benefit to the project. It may be very different up there, but I suspect it similar. It goes something like this:
1 - Take your plans down to city hall.
2 - wait in line for an hour only to be told your missing a required drawing.
3 - Go home, create missing drawing, and go back the next day.
4 - Wait another hour and hear a different person say "you don't need that drawing for your project."
5 - pay your fee.
6 - go to plan review.
7 - "Looks ok, here's your permit"
8 - Inspector comes out, "you can't do that, oh and BTW, you'll have to bring the rest of the barn up to code too."
9 - You'll also need to get an electrical permit. Must be a licensed Master Electrician to get that."
10 - because you're doing something different (finishing out a section of a barn) expect a lot of bizarre thinking trying to get your project to fit in the code.
'13 R1200GS
'08 WR250R
Old 09-17-2010, 04:52 AM   #2721
propforward
PIE!romaniac
Oddometer: 12,783
That tends to be the way of it. However, I called the building guy for our township ( a nice, small, sparsely populated area), and he seemed pretty reasonable. I explained what I wanted to do and he was totally on board with it. The application goes directly to him. Quite a few people around here frame out barns this way (otherwise you can't do shit in them over winter) so he didn't seem phased. We shall see though!
In Mn you have to go through the state for the electrical permit. I still have to get that going.
Old 09-17-2010, 05:32 AM   #2722
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,562
Hopefully he'll remain reasonable for the entire build. Having a small town helps because you'll have to deal with fewer people, unless those people are jerks.
Its good to build to code. In the past engineers wrote the code and it was reasonable, but lately the manufacturers have figured out that by taking control of the code, they can mandate the use of their products. So now there are a few items required in the code that marginally increase the safety of the building at twice (or more) the cost of prior products. Why compete fairly when you can just get the governmental body to require using your products?
Here in Texas any sort of enclosing in a barn is an infrequent event, so its possible you could end up with the code book being applied over-zealously, depending on your building official.
Here where I am, only the master electrician and plumber can get these mechanical permits. Its a pain. I called for an inspection and got a nasty note and a red tag on the door. It turned out my plumber never called to get a permit.
'13 R1200GS
'08 WR250R
Old 09-17-2010, 08:33 AM   #2723
propforward
PIE!romaniac
Oddometer: 12,783
Yeah I hope so. It's a potential minefield.
In any case I'll keep you posted as to what happens. I was half tempted to just do the project, but you can land in hot water that way, so I have decided to keep it on the up and up. I figure it will be for the best long term, if/when I sell the place.
The permit app doesn't even call for drawings, but I'll provide them anyway - can't hurt and I already modelled the thing on the pooter anyway.
Old 09-17-2010, 08:48 AM   #2724
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,193
Only give them what they want, nothing more.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 09-17-2010, 08:55 AM   #2725
propforward
PIE!romaniac
Oddometer: 12,783
Yeah, fair point.
Old 09-17-2010, 09:04 AM   #2726
TomTom63
Motorradfahrer
Oddometer: 1,625
What's up with all those garages and barns? Y'all have your priorities messed up...
TomTom63 is offline   Reply With Quote
Old 09-17-2010, 09:45 AM   #2727
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Talking
KTM on white carpet, how long was the wife out of town for?
Old 09-17-2010, 09:56 AM   #2728
TomTom63
Motorradfahrer
Oddometer: 1,625
Quite some time actually . And, we have wood flooring now (not because of the KTM in all fairness)
Old 09-17-2010, 10:12 AM   #2729
propforward
PIE!romaniac
Oddometer: 12,783
I done that already. The dining room table makes for a good workbench.
So is the kitchen table
Panic room is a crap movie
Jason and the Argonauts is much better
But my new workshop's going to be more betterer, and have machine tools and stuff like that.
Old 09-17-2010, 10:21 AM   #2730
TomTom63
Motorradfahrer
Oddometer: 1,625
I like the shop / kitchen combination the best...
Times are GMT -7.   It's 11:39 AM.
