Old 02-25-2011, 08:58 AM   #3271
Shuffler
Getting a grip...
Shuffler's Avatar
Oddometer: 1,674
Originally Posted by trailer Rails View Post
Yup, actually a M610 but pretty much the same thing.
what does a decent used skidsteer go for? how maintenance intensive are they?
________________________________
AMA | COHVCO | TPA | NCTR | BRC
Niwot Synthetics
KTM 950A | KTM 300XCW | BMW R1100RT
Shuffler is offline   Reply With Quote
Old 02-25-2011, 01:23 PM   #3272
mellowdave
Красное октябрь
mellowdave's Avatar
Oddometer: 153
Originally Posted by Guy Young View Post
Mine has become a carb shop, or sorts, here of late:
Off a '93 Suzuki GSX1100G
This was following a fork oil change, change all hydraulic fluids, valve adjustment, and oil and filter change. In other words, the Man Castle is now a garage, a shop.... it's whole purpose for existence.
Now, if I could just figure out what's wrong with these fookin' carbs........
I HATE "fookin carbs" more than anything, but I always seem to find myself working on them...
Always do sober, what you said you'd do drunk. That'll teach you to keep your mouth shut.
Ernest...
2000 Ducati 996::Several XRs
mellowdave is offline   Reply With Quote
Old 02-25-2011, 02:47 PM   #3273
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,039
Originally Posted by JHVA View Post
Looks like I have company in the organized clutter category. 24 x 32.
You have inspired me to dig out my workbench and turn it into a bike service station. I built it 20 years ago out of 4x4 (6) legs, 2x6 cross ties and a top made of 2x4s drilled and bolted together.
Time to kick the wifes car out of the garage and claim my man cave.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 02-26-2011, 07:28 AM   #3274
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Pictures of both items are required! Especially when the wife lights you up cause your kicking her car out of the garage.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 02-26-2011, 08:11 AM   #3275
trailer Rails
trailer Rails's Avatar
Oddometer: 3,344
I got mine cheep because it is old and had some carb issues and bald tires. Maintenance is very low because these things are over built and are intended to work 8 or 10 hours a day, every day. If you want a decent machine that needs no work, I would expect $8000-12,000 would get you that.
I got mine for $3400, put new tires on it and rebuilt the carb. It is still a bit rough but it works and should do fine for the projects I planned for it this summer. Once those are done I am going to sell it and buy a nice lawn tractor with a plow.
trailer Rails is offline   Reply With Quote
Old 02-26-2011, 10:44 AM   #3276
Lonestar2112
scatology expert
Oddometer: 7,039
Here are pictures of the bench. It is buried with crap.
F*CK CANCER
Old 02-26-2011, 09:17 PM   #3277
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,425
yep ...
Hey ....
My workbench is a twin to that one .... both in the way it is built and with all the junk on top.
My dad helped me build it over 30 years ago ....
I need to get it cleaned off - it is on my to-do list
Honda
GsVs is offline   Reply With Quote
Old 02-28-2011, 11:19 AM   #3278
JHVA
Oddometer: 1,865
Nice solid looking bench!
My bench top is an old solid wood door also have another bench made of 2x6's.
Greater Williamsburg Tag Map
2009 BMW R1200GS
1971 MGB Roadster
1965 Yamaha YG1-K Rotary Jet 80
JHVA is offline   Reply With Quote
Old 02-28-2011, 12:10 PM   #3279
Lonestar2112
scatology expert
Oddometer: 7,039
I built it so that I could set and engine on it to rebuild it. Ended up sell that car before I tore the engine apart, kept the work becnh. If we ever have a bomb attack, I'll hide under the bench.
F*CK CANCER
Old 03-06-2011, 05:32 AM   #3280
Guy Young
Guy Young's Avatar
Oddometer: 8,427
Finished up the trolley hoist yesterday
Finding the occasional need to lift stuff, I decided to put up a hoist system in the garage. What started out as this for "light" lifting:
Is now this:
Started out with a couple 10' sections of wide flange I-beam:
That I welded some saddle plates to bolt up to the sistered 2x10s that went the full width of the garage:
With help of a number of folks, we hoisted them into place and I through-holed enough plates to hold them in place for the night. Finished up the remaining 20 holes the next evening. Hardware was 1/2" all-thread cut to length to accept flats and lockwasher.
Next step was to bridge the gap between the two sections and I did that with a couple pieces of 2x2 angle iron welded back-to-back then welded into place:
Some may ask why I just didn't go with a beam the full width of the garage. The reason was that the sections came in 20ft. lengths, and I had no way to carry it, so I had'em whack it in two. In addition, a full 20' width would have cut me short on either side (garage is 24' wide). Next lengths available were either 30' or 40'. I would have had to buy the full length and have one heck of a "drop" that I couldn't use. Since I will be using jack posts under the side I'm lifting on, I won't be able to carry a load from one side of the garage to the other anyway. The angle iron "bridge" is there so I can move the trolley from one side of the garage to the other, but no lifting will be taking place there in the middle.
The jack posts were modified so all the bits stay together and they can be moved into place as a unit without having to mess with the end plates and end screws.
Everything stays tucked into place off to one side when not in use to keep it out of the way:
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 03-06-2011, 06:55 AM   #3281
keener
Speed changes you.
keener's Avatar
Oddometer: 925
Nice, clean job. I am in process of building a lift with 2x8 beams. I like the idea of having temporary posts, brilliant! I am planing to lift the KATOOM up for maintenance or lift and store my trailer.
keener is offline   Reply With Quote
Old 03-06-2011, 07:36 AM   #3282
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,199
Nice work on the overhead lift, Guy.
Laconic is online now   Reply With Quote
Old 03-06-2011, 11:23 AM   #3283
justanotherider
justanotherider
justanotherider's Avatar
Oddometer: 177
Guy:
Thanks for taking the time to share your solution and your photos. You've given me some food for thought in planning my new shop.
justanotherider
justanotherider is offline   Reply With Quote
Old 03-06-2011, 09:04 PM   #3284
Ridemuch
SUP
Ridemuch's Avatar
Oddometer: 2,258
What's with the fancy wiring going on?
"Ya Rob, well she either gets used to the fact that I ride pretty much every weekend or she needs to find herself another boyfriend" KTMike
"There is no bad weather, only bad gear." Dahveed
Ridemuch is offline   Reply With Quote
Old 03-06-2011, 09:10 PM   #3285
tmus2122
MSF Instructor 24yrs
tmus2122's Avatar
Oddometer: 26
All per code I bet, looks scary to me
tmus2122 is offline   Reply With Quote
Times are GMT -7.   It's 03:30 AM.
