Old 03-07-2011, 02:06 AM   #3286
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,773
Originally Posted by Ridemuch View Post
What's with the fancy wiring going on?
Looks like the light fixture and I'm guessing he ain't done yet.
Sometimes it takes time to get it all where it needs to be when you're a one-man crew...
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 03-07-2011, 02:28 AM   #3287
Guy Young
Guy Young's Avatar
Oddometer: 8,528
LOL!
I had to disconnect a light and pull the wire out when I sistered in the 2x10 to the originial floor joist. Once the 2x10 was up I pooched through it I pulled the wire through. Since the light that was disconnected had a bum lamp socket, I pulled it down so it could be replaced. In the interim, I reconnected the leads so the last light in that center string would give me a little more light during the beam raising portion of this little project. With all of that behind me, I put up the missing light back up yesterday so them nekked wires are no more.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Old 03-07-2011, 02:57 AM   #3288
Guy Young
Guy Young's Avatar
Oddometer: 8,528
T'was a missing light fixture (now up and wired back in), and ain't that the truth. Fortunately, I had help getting beams raised into position, but had that fallen through I'd figured out another scheme to gettum up myself. Just would have taken a little longer.
Old 03-07-2011, 03:46 AM   #3289
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 5,003
Originally Posted by AWM View Post
Theres the two machines I NEED!
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 03-07-2011, 09:04 AM   #3290
justanotherider
justanotherider
justanotherider's Avatar
Oddometer: 177
Guy:
You've an elegant solution there mate - I'm jealous. I wonder what you did at the bottoms of the jack posts - is there an adjustment mechanism there?
justanotherider
justanotherider is offline   Reply With Quote
Old 03-07-2011, 10:10 AM   #3291
Guy Young
Guy Young's Avatar
Oddometer: 8,528
Originally Posted by justanotherider View Post
Guy:
What I did at the bottom is this:
And what I did at the top is this:
There is a spud that is on the top of the jack screw that engages a hole in the top plate. As you can see, there is a dimple in the plate. Trying to figure out how to secure the plate to the screw so it wouldn't fall and bounce off my head, I was about to fire up a lathe (I know absolutely nothing about) to cut a groove in that spud for an e, or c-clip.
Pondering the issue, I grabbed one of the 1/2" flatwashers I had for the beam plates, and the ID of the washer was perfect for the OD of the spud. The washer OD and thickness was perfect and it nestled down in that plate dimple. I stuck the jack screw in my vise and adjusted it so the plate (when sitting on top) had just enough clearance on the underside to allow it to turn. I then cranked up the TIG and put a couple of spots to secure the washer to the top of the spud. Voila - jack screw rotates and the plate stays put.
In the pix I showed, the screw is at the top, but I am going to reverse that. I put a couple pieces of thin utility angle on the top piece of wood so it was a no brainer when moving them into position, which also provided lateral support until I could climb up the ladder to snug up things. I'll flip the posts so the jack screws are on the bottom and do away with the need for a step ladder to tighten things up. The guides will get moved to the top.
Sometimes you don't consider everything in the heat of battle, else I would have put the screws at the bottom coming out of the chute. After standing back a taking a second look, it makes much more sense to put them there.
Old 03-07-2011, 08:06 PM   #3292
justanotherider
justanotherider
Oddometer: 177
Nice work.
I figured you had an adjustment at the bottom; but couldn't see the bottoms in the photos you posted. Makes a lot of sense to invert the posts, so you can quickly adjust from floor level.
Let me know if you want some free lodgings in Canada while we 'putter' a little in my shop.
justanotherider
Old 03-08-2011, 12:24 AM   #3293
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,522
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-08-2011, 02:13 AM   #3294
Guy Young
Guy Young's Avatar
Oddometer: 8,528
Nice work.
Appreciate that. I piddle and putter out there a lot.... when I really need to be doing stuff.
I inverted the posts last night, and took a shot of the adjustment end mod I made to keep the plate in place when I had the wood spacers off.
Guy Young screwed with this post 03-08-2011 at 02:39 AM
Old 03-08-2011, 03:02 AM   #3295
xavier296
Alaska n'Back
xavier296's Avatar
Oddometer: 286
My garage looked like this in San Diego (bike's stored in seperate shed in the back)
But now, living in Italy, I can only have 3 vehicles (including motorbikes), so I don't have all my babies here.
2011 R1200GSA 30th Anniversary
79 R100RS
Build Thread: http://advrider.com/forums/showthread.php?t=732078
I welcome any and all couch surfers if you are traveling through Augusta. I even have a well stocked garage for emergent repairs.
xavier296 is offline   Reply With Quote
Old 03-08-2011, 06:14 AM   #3296
trailer Rails
trailer Rails's Avatar
Oddometer: 4,633
Originally Posted by bmweuro View Post
Home made Wrangler frame?
trailer Rails is offline   Reply With Quote
Old 03-08-2011, 09:16 AM   #3297
Boxer Metal
Mad Scientist
Oddometer: 3,522
40's rat rod truck frame. 6" Z in the front and 18" Z in the rear. It will have air bag suspension as well.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-08-2011, 10:47 AM   #3298
SRMN8R
Down & Out
SRMN8R's Avatar
Oddometer: 3,002
SRMN8R is offline   Reply With Quote
Old 03-14-2011, 02:22 AM   #3299
Leafshutter
Leafshutter's Avatar
Oddometer: 73
My own little Castle
09 Triumph Tiger SE Photos
02 Triumph Bonneville America Photos
06 BMW R1200 GS (sold) Photos
Leafshutter is offline   Reply With Quote
Old 03-14-2011, 06:37 AM   #3300
BOBF4S
BOBF4S's Avatar
Oddometer: 13
I ran out of space in the garage , so i made a plan .
BOBF4S is offline   Reply With Quote
Times are GMT -7.   It's 01:45 AM.
