01-31-2012, 09:18 AM
#4216 |
SUPPORT THE SECOND
Oddometer: 1,674
Thats bullshit , you cant get our hopes up and then throw us under the bus . We need you to make it commercially , so that we can buy it and it fits most bikes .
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog If you don't organize your tools, you're a terrible person.---Aghartha You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02 |
01-31-2012, 05:24 PM
#4217 |
Oddometer: 9,781
And assume the liability if you have issues with your lift when you use only one side to lift several hundred pounds.
01-31-2012, 06:41 PM
#4218 |
SUPPORT THE SECOND
Oddometer: 1,674
That's why we have engineers.
01-31-2012, 06:46 PM
#4219 |
Oddometer: 9,781
Yes, and the engineers from the LIFT manufacturers specify to load all 4 arms as equally as possible.
That said, the way he's doing it I am sure is safe, as I would imagine that in application this lift will support adequately a vehicle that is unbalanced by the weight of his bike... Probably. But in engineering this product to do what it is doing, you would also be violating the engineering recommendation of lift makers. You have to figure that lifts vary, for instance this is probably very OK on a 10,000 pound doube upright lift with a top beam, this may be very not OK on a lighter lift with a bottom plate, where there is no structure at the top to resist the two uprights coming together. In application the goal of a double upright lift is to have the force primarily going as evenly as possible straight down into the ground through the metal uprights, and not a force that pulls one side in and back. |
01-31-2012, 07:17 PM
#4220 | |
SUPPORT THE SECOND
Oddometer: 1,674
01-31-2012, 08:16 PM
#4221 | |
Oddometer: 9,781
Just have to think, if this is you engineering a product for sale, even with a disclaimer like follow all recommendations of llift manufacturer, ensure adequate thickness, strength, and integrety of concrete anchors prior to use etc. etc. You have to figure somewhere out there lies the moron who figures that it might not be a bad idea to lift the bike swung to the rear fully and extended rearwards so that it is close to the work bench. And that this moron may also not have had the correct diameter carbide tip drill for the anchors they used, and elected to use the next one larger because they had it. And said person kills themself. And their family tries to sue the lift manfucturer who goes, shit right here in my manual it clearly states not to lift uneven loads, blah blah blah. So they go, huh, this product allows uneven loading. I think its damn clever, and will probably set about making a similar unit for other usages. But if its a commercial produuct one might consider a table that utilizes two opposing lift arms or similar to atleast "bridge" the uprights. Commercial products = gotta avoid the dumbnuts. |
01-31-2012, 08:29 PM
#4222 |
Adventurer Ordinaire
Oddometer: 346
solved
put 600 pounds on the other side too
Dusty_Bottoms screwed with this post 01-31-2012 at 08:38 PM |
01-31-2012, 08:31 PM
#4223 |
Oddometer: 2,442
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
01-31-2012, 08:33 PM
#4224 | |
SUPPORT THE SECOND
Oddometer: 1,674
02-02-2012, 11:38 AM
#4225 |
Oddometer: 618
Can anyone visit the motorcyclist cafe? we might be in the area this summer.
09 DL 650,08 WR250R 09 KLX250S(gone), 03 R6 (gone) 04 WR 450(gone), 01 EX 250(gone), 06 DL 650(gone) , 89 KLR 650(gone) |
02-02-2012, 04:14 PM
#4226 | |
Granpa Hoon
Oddometer: 2,625
If you are comming thru this area let me know.
Dean O BMW nut and Happy Camper Copperhill, Tn. www.Motorcyclistcafe.com Founder San Jose BMW |
02-04-2012, 02:34 PM
#4227 |
Oddometer: 2
this is where i spend all of my time......
02-06-2012, 02:44 PM
#4228 |
Eat, Sleep, Ride, Repeat
Oddometer: 796
02-07-2012, 04:52 AM
#4229 |
"Cool" Aid!
Oddometer: 41,488
I DID say SLOW build, right?
![]() Well, after getting moved, always a major pain, and setting the house up with 22 sets of blinds, and buying new furniture, and putting up 19 pictures, 6 clocks, 2 TVs and numerous other things like shelving and hooks in bathrooms, I finally got started on the garage. I got all the stuff moved to one side so I could start cleaning the drywall of messed up drywall mud and dirt. In a couple days I will be able to paint one side, and do the VCT flooring, then move everything and do the other side. (Exactly why I wanted to do this BEFORE we moved in!) ![]() I expect to have some photos soon! Jim
Click here for BMW Maintenance and Repair DVDs and Corrections. "Combo-Order Discounts!" JimVonBaden screwed with this post 02-07-2012 at 08:13 AM |
02-07-2012, 06:40 AM
#4230 |
Oddometer: 2,442
