Old 02-28-2012, 05:40 AM   #4366
C-Stain
Unreasonable
C-Stain's Avatar
Oddometer: 2,215
Originally Posted by JimVonBaden View Post
These are the kitchen cabinets, AKURUM. Heavier than the basic shelving units. These are part of a Kitchen kit that you can buy as shown.
Jim
linky?
TransLab a Go Go 2011
Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail
"Second star to the left and straight on till morning” ― James T. Kirk
C-Stain is offline   Reply With Quote
Old 02-28-2012, 08:42 AM   #4367
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Originally Posted by rick danger View Post
Lookin' Good Jim!
Thanks Rick, though mine pales to obscurity in comparrison to yours!
Jim
Old 02-28-2012, 08:43 AM   #4368
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Thats what I'm going to use too. Cheapest way to go. I can do my floor for $600 where Racedeck or similar would cost me $3500. I'm going to cut them on my table saw. tried it and it seems to work ok. I'm doing blue/white checker and. down the middle will be 6' wide all black. With yellow 3" stripes down each side and two yellow stripes down the middle so it looks like a road The black tile has flecks of white/lighter colors that almost makes it look like asphalt. (if you use your imagination). I have 6' doors on either side of the room, so the "road" will go from one to the other. The bikes will be on either side of it so they wont get run over by a tractortrailer or something
That's going to look great Rick!
Jim
Old 02-28-2012, 08:45 AM   #4369
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Originally Posted by C-Stain View Post
linky?
http://www.ikea.com/us/en/search/?qu...M+Wall+cabinet
Pay close attention to the width. There are a lot to choose from.
Jim
Old 02-28-2012, 09:01 AM   #4370
lightfighter
where does this go?
Oddometer: 1,887
how slippery are those vct tiles when wet? relative to a painted floor?
andwhat blade did you use on the saw?
lightfighter is offline   Reply With Quote
Old 02-28-2012, 10:08 AM   #4371
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
It depends on if you polish them, or just put on a finishing fluid. Polished they are like any other wet smooth surface. Unpolished they grip pretty well.
I used a simple carpet knife and scored the tile at least 5 times, then snapped it off. Took about 20 seconds to cut each tile. If useing a power saw, you would want the teeth as fine as you could get them to prevent breaking off chunks of tile,
Jim
Old 02-28-2012, 03:58 PM   #4372
trailer Rails
Oddometer: 888
Here is my plan, I think it is somewhat to scale. 30 feet wide by 50 feet deep.
Where the truck is located a vehicle lift will be installed.
The Bobcat and lawn tractor are at the front right.
I think I am only going to do one garage door and double man door. In front of the truck will be the wood shop area. I would like to keep the welding area at the opposite end of the garage, maybe the motorcycles will have to go in a different area.
I am having a hard time visualizing everything. It almost seems like there is not enough room. I am looking for suggestions. I think I just need to nail down where the lift will be installed, then I can put stuff in from there.
trailer Rails is offline   Reply With Quote
Old 02-28-2012, 04:46 PM   #4373
mcma111
mcma111's Avatar
Oddometer: 7,979
Don't put the vehicle lift next to the work bench area because every time your working on the bench you'll be running into the lift post. Put the lift on the other side of the garage.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-28-2012, 05:29 PM   #4374
P B G
Oddometer: 9,781
Figure out how much offset you'll need between the side of the lift and the centerline, if you put the lift towards the wall that's how far in the midline of that car will be when on the lift, compare that to door location.
I would be tempted to put the lift all the way in, and use it to store some of that stuff, tractor, atv etc. When not in use.
Old 02-28-2012, 06:24 PM   #4375
Tech23
Tech23's Avatar
Oddometer: 414
What the other guys have said concerning lift location is good advise .Have you selected a lift yet? Also consider how far you'll need to run an exhaust tube from the tailpipe if you plan on running cars with closed doors and windows during the winter months if you put the lift all the way back with only one garage door. Also consider lighting for lift placement, it's nice to have a lift near the garage door in good weather so you can raise the door and take advantage of sun light. Also consider which side of the garage is the best side for the roll up door if taking advantage of sunlight is something you want to do. Sucks having a garage door open in nice weather then having the sun shining directly in your eyes while under the lift. Might be better to place the lift so that a vehicle can be driven straight thru it to the back of the shop rather than place where it might be a obstacle.The diagram you posted is a start, could you label what the pieces are along the walls...work benches, floor shelving units etc.?
Floor shelving is nice because you can rearrange it if necessary, but it eats up floor space, conversely wall mounted shelving keeps the floor open but can dictate what can go against the walls. Measure out the width of all your shop equipment that you want to place against the walls, bench grinder if it's pedestal mounted, drill press (unless it's a bench top style), tool box width and anything else you don't want in the middle of the floor to get a better idea of how you want it laid out. Take the measurement total of all the equipment you know you want against a wall and compare that measurement with available wall space.
Tech23
CRF 150/230/ Supermoto Conversion
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
Tech23 is offline   Reply With Quote
Old 02-28-2012, 07:22 PM   #4376
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
I picked up a nice "little" Craig's List find today for $40.
It is on a 4X6 trailer, and took two of us struggling hard to get it there. It is 7'4" tall, 40" wide, 27" deep and I am estimating it weighs 200#!
Note the shelving unit behind the photo above that this is replacing.
At some point it was modified in the past, and I thought I would have to UNmodify it. The open side was too narrow for much, and the shelf not at an ideal height.
But, when I started loading it with the stuff off the shelf, I realized it was actually perfect for storing my extra sheet metal and plastics.
I have a lot more to load, and I will add another shelf after the second one, but I think I am going to like it!
Overall it fits nicely with the IKEA cabinets, though it is 8" deaper, it looks good and fits the space well.
Jim
Old 02-28-2012, 07:29 PM   #4377
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 1,287
+1 Regardless of lift type, it'll be in the way by the bench area.
One door? Fine, make it a 16' wide door. otherwise regret will follow.
That nice double-size man door? Put it down at the other end, so you can pull your tractor out without unloading the whole garage (my regret I didn't do that with my end-loading garage).
Woodworking area? Close it off from the mechanical shop area with a wall, or build an additional separate space (or large shed). Wood dust has no place in a garage shop if you're doing mechanical work, body work, welding, painting, etc. We had carpenters in during our kitchen remodel who had to setup a saw in my garage and they put more dust in my garage in 2 days than I did in 30 years. Dust collection system is fine, along with dust segregation.
HapHazard is offline   Reply With Quote
Old 02-29-2012, 02:43 AM   #4378
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 4,868
Jim
Jim, I was going to ask you if you sealed your tiles or not. They told me at Lowes I should seal them with something. But I dont want something that will show tire marks when I roll a bike across them.
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 02-29-2012, 03:55 AM   #4379
Terence FFM
prof. cat-herder
Oddometer: 342
Bluhduh I must be doing something badly wrong...
Maybe it's time to move to the sticks. Where I live, you are looking at around $65/sqft for the land alone.
Still, it's always good to have a plan in case I win the lottery...
"The powerful will delegate to the untalented until failure is achieved" Dogbert, CEO
Terence FFM is offline   Reply With Quote
Old 02-29-2012, 05:32 AM   #4380
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Once I am done with all the moving crap around I plan to seal them. Mainly to make them easier to clean. A good Armstrong sealer wont be slipery, yet will protect the joints from water that can loosen a tile if it sits and seeps in around the edges. The tile glue is water based.
Jim :cool:
Times are GMT -7.   It's 09:32 AM.
