Old 03-01-2012, 02:04 PM   #4396
roverchild
Oddometer: 59
repost
Messy/Farm Shop
Slighly less messy auto shop
Upstairs wood shop
Shop in the very very early stages, this is where we plan to put a 50'x80' shop. heated and foam insulated with some big ol doors at each end. anyone know a good lift that will easily handle a one ton truck?
roverchild is offline   Reply With Quote
Old 03-01-2012, 02:40 PM   #4397
Tech23
Tech23's Avatar
Oddometer: 414
Originally Posted by spafxer View Post
This photo of ScooterAug's garage reminded me of my situation.
I'm lucky enough to be able to leave my roll up door open while working in the garage most of the time. This effectively blanks out a good portion of my lighting from the ceiling. Does anyone have any ideas on mounting lighting to the garage door? A coiled cord to supply power to them or ??
I have the same diamond plate shop lights mounted in my garage. Mine are mounted directly to the ceiling and hard wired though. I have one row of three that are blocked when the doors are up also. I put those three on a separate wall switch so I can turn them off when the door/doors are up. The doors are only open during daylight hours anyway. Even though all the ceiling lights are wall switch operated I did keep the pull chains on all the shop lights so that I can turn on/off the lights in any location/order.
I think some sort of light mounted to the sides of the doors aimed where they are needed might work. Mounting an incandescent style lamp to the door will make for short bulb life from vibration of the door going up/down...I wouldn't even attempt to mount a florescent style lamp to a door for fear of a glass tube coming down. Mounting any light to a door just sounds dangerous, and most likely against building code.
Tech23
CRF 150/230/ Supermoto Conversion
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
Tech23 is offline   Reply With Quote
Old 03-01-2012, 06:08 PM   #4398
ducnut
Oddometer: 2,453
BendPak is pretty much the industry standard. They've got some really big stuff; 2-post up to 18K pounds.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-01-2012, 06:14 PM   #4399
roverchild
Oddometer: 59
thats the brand that we have been considering.
Old 03-01-2012, 06:20 PM   #4400
ducnut
Oddometer: 2,453
My brother has 2 of 'em, in his repair shop. I've a buddy who was a full-service auto service/gas station maintenance tech, for lack of term. He's installed and serviced them all, but, always touted the goodness of BendPak. If you were more of a home shop/hobbyist operation, you could probably get away with about anything. But, that doesn't look like you.
'96 Ducati 900SS
Old 03-01-2012, 06:43 PM   #4401
LoFlow
Oddometer: 902
I've been hanging out here for a while and drooling over some of the nice garages so I may as well show mine. It's small, old and not nearly as well organized as some of yours, but I have fun in it.
And once in a while I like to drill things.
The highway's a storyteller...No time to write it down.
LoFlow is offline   Reply With Quote
Old 03-01-2012, 07:26 PM   #4402
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,498
Looks like a great use of space, and well organized!
Jim
Old 03-01-2012, 07:31 PM   #4403
Meles meles
Oddometer: 164
Messy/Farm Shop
Classic! Land-Rover parts everywhere.
Meles meles is offline   Reply With Quote
Old 03-01-2012, 07:33 PM   #4404
therealbigman
bout a dollar 3.98
therealbigman's Avatar
Oddometer: 3,071
Would you like to add some more driller thangy's
Marko
08 xr650l 99 xr650l 84atc200s 85atc200s 80ct110 99xr70 04xr50 85atc70 87trx70
Dumb ass people do dumb ass things
therealbigman is offline   Reply With Quote
Old 03-01-2012, 07:46 PM   #4405
Riteris
Dessert Runner
Oddometer: 2,514
I would consider placing lights off to the side and angled inward. Maybe even put lights on the wall?
I don't know if you can add windows to your garage door but if so, hang lights directly above the windows when the garage door is open.
Chris
I am taking the advice of all those people that told me, "Hey kid, why don't you go play in traffic!"
Riteris is offline   Reply With Quote
Old 03-01-2012, 08:05 PM   #4406
LoFlow
Oddometer: 902
[QUOTE=therealbigman;18114431]Would you like to add some more driller thangy's
Oh that Delta is a dandy!
Old 03-01-2012, 08:07 PM   #4407
therealbigman
bout a dollar 3.98
Oddometer: 3,071
[QUOTE=LoFlow;18114689]
Yep , made by our Homeboys also , not the new Tiawan , Japanese , or whatever the hell there made ,
Marko
Old 03-01-2012, 08:56 PM   #4408
Ko
Observant as never
Ko's Avatar
Oddometer: 1,074
Originally Posted by rick danger View Post
Thats what I'm going to use too. Cheapest way to go. I can do my floor for $600 where Racedeck or similar would cost me $3500. I'm going to cut them on my table saw. tried it and it seems to work ok. I'm doing blue/white checker and. down the middle will be 6' wide all black. With yellow 3" stripes down each side and two yellow stripes down the middle so it looks like a road The black tile has flecks of white/lighter colors that almost makes it look like asphalt. (if you use your imagination). I have 6' doors on either side of the room, so the "road" will go from one to the other. The bikes will be on either side of it so they wont get run over by a tractortrailer or something
Don't want to sidetrack the display of shops/garages and such, just to offer a tip or two- VCT tiles break very easily if you lightly score them on the top (there's a shiny top and a somewhat dull looking bottom althoug they look similar), and then bend it. With practice you can have multiple cuts break easily. If you have a complex cut around something just take a heat gun to it and it becomes buttery- then it burns but hopefully you stopped by then. If you heat the cuts yo uscored you can easily cut through.
It's worthwhile having/renting a tile cutter- looks like a guilottine. With that one you can make MUCH cleaner/faster cuts than a saw would do- meaning when you but the tiles you won't have much of a gap. If you do, just take a blade and shave the edge of a tile by moving the knife up and down perpendicular on the edge- those small flakes can be rubbed in cracks and won't show because these tiles are same colour all the way through.
Typically these tiles are waxed (for home applications grab a pail and use a mop to spread it)- Walmart and others wax them regularly so the wear is on the wax and not on tiles. Waxing them won't make them much more slippery then they already are, and it makes it easier to keep them clean.
Glue wise, I suggest buying the black one- dries faster and it holds faster and betterr than the white one. But it's harder to clean- although you shouldn't if you wait for it to dry.
no snowflake ever feels responsible for the avalanche...
Ko is offline   Reply With Quote
Old 03-02-2012, 02:28 AM   #4409
Langanobob
Oddometer: 173
Messy/Farm Shop
Excellent! Best shop pictures I've seen so far, makes me feel right at home. Mine is only slightly less orderly. The site for your new shop looks great. I built a 40 by 60 (yeah, I know, small by your standards) a few years ago and it's the best thing I ever did. Thought I had plenty of space but it sure filled up fast.
Bob
Langanobob is offline   Reply With Quote
Old 03-02-2012, 02:58 AM   #4410
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 4,868
Thanks for the tips. I started yesterday and the table swa seems to be doing a good job. Perfect edge. You just have to go REAL slow at the last 1/4" or a little corner will chunk off. It also works to push it through the last bit with a scrap of wood. But I've just been going slow at the end.I'll post some pics tomorrow.
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Times are GMT -7.   It's 01:34 AM.
