Old 10-03-2012, 03:37 PM   #4891
Apxgrndr
In the snow
Apxgrndr's Avatar
Oddometer: 1,001
Originally Posted by Ride_There View Post
First half of my new to me garage painted, 5 gallons on so far. Lots of lighting to follow.
First time in 10 years I have had room for all of my toys. Now I even have room to acquire more cylinders.
Cool, whats your plan for the lighting?
You're stronger than you think.
Apxgrndr is offline   Reply With Quote
Old 10-03-2012, 04:48 PM   #4892
walkingbear
walkingbear's Avatar
Oddometer: 3,549
almost finished
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 10-03-2012, 05:28 PM   #4893
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,734
Originally Posted by walkingbear View Post
Very nice. Question, why the multi leveling in height leading in?
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 10-03-2012, 05:59 PM   #4894
walkingbear
Oddometer: 3,549
lift in the middle
In the middle of the garage .. will be a lift. I wanted it high enough so I could lift my sprinter van 5 feet off the ground. The sprinter is 8ft 7 inch so you add 5 ft you will be at almost 14.. The middle is 16 ft high to the bottom of the trusses.
Old 10-03-2012, 06:32 PM   #4895
Ride_There
Will ride for bacon.
Ride_There's Avatar
Oddometer: 3,119
Still have not set a plan. Thinking of putting up (6-8) 96"L T8 florescent fixtures(Qty 4, 48"L bubs each). 2 in-line on each side plus 1 or 2 rows in the middle area. Plus a couple under cabinet lights over the future work bench.
Was looking at T5HO's and loved the bright light. Could not justify the bulb cost difference. Plus I kept reading that they should be put up ~ 14 feet while I only have 10' ceilings.
This is in a 32' x 28' foot 2 stall garage. If anyone has other lighting ideas or advice I am willing to listen.
Ride_There is offline   Reply With Quote
Old 10-03-2012, 07:59 PM   #4896
walkingbear
Oddometer: 3,549
I used a combination of T5ho and T8. I would have added another set of T5 to the main room. My ceiling are 16 and has a few dark spots in the corner.
My garge is 26 x52 3 pairs of T5ho and 1 pair of T8
Old 10-03-2012, 08:23 PM   #4897
SantaFeTrailer
Stromtrooper
SantaFeTrailer's Avatar
Oddometer: 317
Closed on my man castle (oh yeah, with attached house) last Friday. Pressure wash/degrease/pressure wash/acid etch/pressure wash. 9 gallons of semi gloss on the walls (could have used another coat) and some LANL surplus powerplant epoxy paint on the floor. Start moving in tomorrow!
After cleanup:
After paint:
SantaFeTrailer is offline   Reply With Quote
Old 10-03-2012, 08:29 PM   #4898
150ron
150ron's Avatar
Oddometer: 1,363
Originally Posted by eod3mc View Post
starblade....looks like you have all the bases covered
+1
Just some dude...
150ron is offline   Reply With Quote
Old 10-03-2012, 10:06 PM   #4899
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 814
Originally Posted by jwalters View Post
Well, it's been years of waiting, saving, planning and dreaming! I've read and reread this thread and a bunch of stuff over on garagejournal.com. But the WAC is finally starting to take shape. Let me explain. The WAC aka, Workshop Apartment Cabin is a place to call home when I am in the States and a workshop to keep the Moto-Fleet running! It's a hang out, a workshop, a vacation home, and an office. And it was built by fellow advriders!
With winters like these along the Minnesota North Shore of Lake Superior, one needs a workshop to restore bikes during the months were riding on 2 wheels isn't an option.
Highway 61
It all started during the first ever Minnesota North Shore Shindig, where I met MikeS. Behold, he was a log home builder, who knew a thing or two about contracting. A few months later he was framing the WAC. Before that could happen I had to do some clearing. One afternoon later, this is what I had.
The building was put on the far end of the 17 acres, giving me plenty of room to build a home someday on other parts of the property. It's a 50x30 slab on grade with a partition for livable space (kitchen/bathroom) on the ground floor as well as the workshop on the ground floor. Upstairs consists of a attic trusses with a large living room with plenty of space for pull out couches and a bedroom/office. The slab has two loops of Wirsbo in the cement for two zone heating (livable space and workshop).
Let the construction begin.
Kitchen window.
Progress continued through last fall.
Steel roof goes on and WAC get's wrapped! Mike worked hard on the steel roof and with great results.
The upstairs window has a good view of the lakes. It's fun watching freighters cruise the lake when they hug the Minnesota shore during strong westerly winds.
Another advrider, Arrowhead Rider greatly helped with the electrical rough in! Then came the poly closed cell foam insulation to keep the place above freezing during the long winters. Heat comes from a wood stove when I'm at the place and a Steffes off-peak furnance and Wirsbo infloor heat to keep the WAC above freezing.
The workshop has a high ceiling that will come in handy for future airplane work. I plan on installing some Tongue and Groove pine on the worshop ceiling and drywalling the rest.
More pics of the workshop partition.
The view outside the workshop window. Not bad!
The kitchen/dining room/living room area of the WAC. It's a work in progress, to date the drywall is all hung, taping and muding is ready to start!
More workshop ceiling pic.
Putting in a rock skirt around the base of the building. Should help prevent rotting wood when snow is piled along the house. I'm hoping to blend in the rock with the same material used for the walkway and retaining wall. That will come someday when I have extra $$$.
The 10x10 garage door, is big enough for most vehicles and airplanes, but energy efficient enough to hold in heat from the Wirsbo in the floor.
MikeS did a great job adding the face plate for a future second story deck overlooking the lake.
This is pretty much where it stands. Working on the interior finishing as I get time. But I already see this is going to be a couple years worth of tinkering! It's great having a place to work on bikes! I'm humbled by how many friends and family members have helped out on the place over the past few months. I'll post more pictures as I finish up the interior and the workshop. Thanks for watching!
WOW we have a winner gota love the cabin look, great job and great pics and comments of build
get out and live
sailer is offline   Reply With Quote
Old 10-04-2012, 09:10 AM   #4900
chorizo
Oddometer: 195
Nice cabin. Looks like it'll warm up nice. Were the scissor trusses packed with insulation. R- what ?
Siding looks tight. Makes me want to build.
chorizo is offline   Reply With Quote
Old 10-04-2012, 09:13 AM   #4901
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,738
Pretty sure that's spray foam insulation.
z@ch is offline   Reply With Quote
Old 10-04-2012, 09:26 AM   #4902
chorizo
Oddometer: 195
Garage floors
Ive been tempted to coat my ugly garage with something. Epoxy or some other surface that cleans easy. Also thinking about a race flag checkered grey and white tiles. Any ideas for a good cleanable surface. I work on my vehicles and try not to drip but its gonna happen.
Old 10-04-2012, 11:50 AM   #4903
Hakatan
quality > quantity
Hakatan's Avatar
Oddometer: 1,021
Garage Journal
You might check out the 'flooring' subforum on GarageJournal for recommendations
"Make no little plans. They have no magic to stir men's blood." -- Daniel Burnham
Hakatan is offline   Reply With Quote
Old 10-19-2012, 05:47 AM   #4904
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
The mothership "man cave" with the new 2013 KTM 500EXC getting farkled:
Farkling finished and ready for mountain adventures:
The "mobile man cave" with kayaks, mountain bikes, but no KTM on the front deck........yet:
AND
The "mobile man cave" test fitting the KTM on the front deck.
Now we put it all together and head to Colorado or Montana next season.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 10-19-2012, 05:55 AM   #4905
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,281
Wow. What kind of popup camper is that? Nice!
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Times are GMT -7.   It's 12:08 AM.
