Old 11-21-2012, 07:58 AM   #4921
Aanarchy
Aanarchy's Avatar
Oddometer: 1,137
My Old Garage
For ten years I lived in a townhouse and squeezed my bikes and shop into an 18' x 20' garage with a double roll up door.
It had the HVAC duct work routed into it so it was cool in the summer and warm in the winter. The downside was that I had to share the space with gardening tools, Xmas decorations, other non-moto related stuff. It got crowded.
Maybe it was Utah. - H.I. McDunnough
Aanarchy is offline   Reply With Quote
Old 11-21-2012, 08:03 AM   #4922
Aanarchy
Aanarchy's Avatar
Oddometer: 1,137
New Garage
So we sold that place and moved to a house that has a 1/2 acre lot. Here is the garage - we are still unpacking and organizing.
This is a 60 year old house and has some cool stuff, like the built in shelves, but also has some of the drawbacks of an older home - like the cracking and uneven garage floor, and the driveway, which is being completely replaced.
Old 11-21-2012, 08:14 AM   #4923
Aanarchy
Aanarchy's Avatar
Oddometer: 1,137
Rehab or New Construction
The house comes with this in the back of the lot -
I've moved some of my stuff into it -
Old 11-21-2012, 08:33 AM   #4924
Aanarchy
Aanarchy's Avatar
Oddometer: 1,137
It's a cool old building - 20' x 20' with a single car-width tilt up door. The electrical supply has been upgraded, it has two 8' banks of lights, a porch, the shelves.
It could be a cool man-cave with some TLC. Needs serious repair of some of the siding, maybe go with Hardy board. Put in a roll-up door, cut in a man-door where the window is. Add insulation and paneling and a ceiling, a shop sink. Roof is in good shape.
But the biggest problem is the floor. Apparently the building was built on a pier and beam perimeter foundation and the floor was poured later. The alley side of the foundation has sunk and has some cracks and the floor is crowned in the center, maybe 5" higher than the alley side, a couple of inches higher than the yard side. And the pad outside the door is sloped, and the patio under the arbor is a separate slab. In short, all the concrete work is haphazard and deteriorating.
I got a quote of $6K to level the building, fix the foundation, and pour a new floor. Add to that the cost of rehabbing the siding, walls, etc, and it seems you are approaching the cost of a new building. The foundation guy said he could put in a new foundation and floor from scratch (on a clean pad) for $4K.
My budget is $20,000. So I'm trying to figure out if I can demo this building and put in a new one, including a parking pad, for that.
Or should I live with the f'd up floor and pad and just fix up the building? I hate to pour a bunch of money into a building that's got fundamental problems. If I could get away with $5K to fix it up, I might do that, but I got numbers up to $15K for rehab the way I'd want it. And I'd still have all the floor and pad problems.
Old 11-21-2012, 08:40 AM   #4925
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
Current status...
Got it cleaned out enough to fit one LARGE car, 2 bikes, and a whole bunch of shelves / workbenches. Bikes aren't really accessible, but I can't ride them right now anyways. I'm impressed that, for the first time in my life, we are using a garage to park a car in nightly.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is online now   Reply With Quote
Old 11-21-2012, 08:46 AM   #4926
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,235
Man, you guys have some cool shops. Mine is a bit more cramped. You can see my 1 car garage (more like 4/5 actually) to the left. There is a car, 2 bicycles, 2 motorcyles, and a 3x5 work bench stuffed into that 10x25 garage. When I get home from a ride, I pull the bike up the steep driveway, then slide the rear tire around so the bike is ready to go again. The 250 has been replaced by a 750 Aprilia, which requires a rear wheel stand on dolly wheels to turn it around. There really isn't a level spot on the property to build a shed.
High Country Herb is offline   Reply With Quote
Old 11-21-2012, 10:37 AM   #4927
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
The nice thing about a small garage is it only takes about 10 minutes to go from 20 degrees to 60 degrees with one of these.
-Charles De Mar.
Old 11-21-2012, 10:38 AM   #4928
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
Woa, didn't notice till I posted, but check out the heat coming off that thing!
-Charles De Mar.
Old 11-21-2012, 10:39 AM   #4929
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
Try not to commit heater-cide.
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 11-21-2012, 11:10 AM   #4930
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
Yeah, the front door is about half open and the ceiling fan is going full blast. I only run it about ten minutes every hour if I'm out there working, and I have a carbon monoxide detector just in case.
-Charles De Mar.
Old 11-21-2012, 11:28 AM   #4931
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,834
Does anyone make a portable propane heater with an "exhaust pipe" & intake pipe? ?
It'd be cool if you could stick the exhaust under the garage door so it vents outside .. kinda like the Espar D2 works in my van.
Old 11-21-2012, 11:33 AM   #4932
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
Just use an electric heater ?
Old 11-21-2012, 11:55 AM   #4933
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,318
1500 watt electric is about 5000 btu. The pictured heater is probably 50000 - 75000 btu. The difference is huge.
There are vented propane furnaces/heaters but I don't know of any that are portable (it is a good idea, though).
I have a Kerosun vented kerosene heater, but I don't run it much - the floor stays so cold it somehow doesn't seem worth it. I use the Halogen worklights for light and heat - right on the hands, where it counts (or stay inside near the woodstove).
HapHazard is offline   Reply With Quote
Old 11-21-2012, 12:10 PM   #4934
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,366
My heater is 250,000 btu.
I have 2 7500 w (?) electric heaters that will just HOLD the temp, not really warm it up. If I plan on working a long time, i plug them in, warm it up with the propane, and have the electrics going constantly. Problem with the electric is it is DANG spendy to run them for any length of time, and i cant run anything else electric in my garage with both heaters going...
Maybe i should invest in some insulation?
-Charles De Mar.
Old 11-21-2012, 12:18 PM   #4935
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
........or a home in a warmer location.
Times are GMT -7.   It's 09:09 PM.
