Old 01-09-2013, 10:27 AM   #5071
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Notice the cross member here as they gradually turn. Getting the 1/2 plywood on it took a lot of bending and just a few screws!
PA Slammer is offline   Reply With Quote
Old 01-09-2013, 10:29 AM   #5072
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Originally Posted by go::ahead View Post
Here I was logging on to show off my kitchen counter workbench I whipped up last night and your 8 y/o outdoes me, touche
NO, NO, NO... there at no out doing anyone! Is it functional? Can it hold a couple beers? The only difference is some paint and polish!
Old 01-09-2013, 10:30 AM   #5073
Deans BMW
Granpa Hoon
Oddometer: 3,319
Some of you might be familiar with the MC B&B Man Castle that we built in the mountains of Arizona. We sold that place this past summer and moved to the Smokey Mountains where I am building a new Man Castle
This is the backside of our new place, on the side of a hill, not a lot of room.
A big time amount of Earth work and tree removal was undertaken.
Extensive form work.
67 1/2 yds of concrete later.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 01-09-2013, 10:32 AM   #5074
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Some 1/2 inch going up...
Overhang section...
A better shot of the twist I'll have to make the 1/2 inch plywood do...
Old 01-09-2013, 10:33 AM   #5075
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Finally done with all the plywood...
Old 01-09-2013, 10:33 AM   #5076
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Old 01-09-2013, 10:35 AM   #5077
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
My oldest just couldn't wait...
Old 01-09-2013, 10:37 AM   #5078
go::ahead
go::ahead's Avatar
Oddometer: 69
Well its 7' by 2' and has studs every 15" under the work surface and low shelf, theoretically it could hold A LOT of beer. I'll get back to you after proper testing
2000 KLR 650
2009 Surly Karate Monkey, rigid SS
2012 Specialized Camber 29
2012 Masi CX SS
go::ahead is offline   Reply With Quote
Old 01-09-2013, 10:42 AM   #5079
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Old 01-09-2013, 10:45 AM   #5080
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Some paint... nope no ORANGE. Decided to go with a mountain theme.
Old 01-09-2013, 10:46 AM   #5081
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
BTW, we saved ALL the sawdust and threw in some play sand with some garage floor paint. The texture is awesome!
Old 01-09-2013, 10:50 AM   #5082
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 995
Climbing holds going up...
And some practice...
Old 01-09-2013, 11:08 AM   #5083
Deans BMW
Granpa Hoon
Oddometer: 3,319
Continued.
The slab is 32' x 32' of 4,000 PSI concrete, the retaining wall on the right is 10' hi as will be the ceiling height.
2x6 walls
The upstairs will have a 18' wide by 32 ' deep room.
The upstair room.
The stairs going up, under the stair, pic right will be a little room with a commode inside and a shop sink on the wall outside of the little room.
Metal roofing, large 14' overhangon the left. 8' insulated overhead door on front left with a 16' insulated overhead on the right.
Tyvex over the OSB, then the siding then two coats of brushed on Silkens stain. Windows and doors installed. Every possible space calked.
Vehicles in in at last. Now I am doing the wiring then insulation. A bathroom with a shower upstairs with a little efficiency kitchen upstairs. Wiring, insulation and some type of siding downstairs then work benches etc.
And of course, the wood burning stove.
Dean O
Copperhill, Tn.
Old 01-09-2013, 11:14 AM   #5084
Rinty
Rinty's Avatar
Oddometer: 546
Beautiful, Dean. Are you backfilling between the retaining wall and the hill?
Rinty is offline   Reply With Quote
Old 01-09-2013, 11:52 AM   #5085
Deans BMW
Granpa Hoon
Oddometer: 3,319
Yes, it has been backfilled. Just prior to the back filling, it was coated with a thick tar like substance then a heavy visquene a french drain all along the wall then a layer of gravel then backfilled and packed. The wall is 10" thick in this area and 8" in other areas.
The back retaining wall is on a poured with rebar footer.
Dean O
Copperhill, Tn.
Times are GMT -7.   It's 06:22 AM.
