Old 02-02-2013, 06:10 AM   #5131
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,409
So jealous
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 02-02-2013, 06:14 AM   #5132
Poweranger
Oddometer: 194
Here is the finished product. I bought some basic plumbing and electrical books and did it all myself. Ran all the electrical with conduit. Many people ask why I didn't run the wire in the walls. When I started I really didn't know where I wanted to put stuff like welders, air compressor, ect. With the conduit it is very convenient to add electrical any where you want in the future.
The heated shop side.
I used the overhead radiant heat system. Runs on propane. This heater is very efficient. I have only used 30% of a 500g propane tank since November of 2011. I usually leave the heat on around 55 when I am not working in the shop. But the winters have been kinda mild this year and last.
Plumbed everything with pex. I was amazed how quick and easy it was to work with. I think it took longer going to Menards to get all the stuff than it did to install it. When I eventually get an air compressor it will go in here also so the noise will not be so bad in the workshop. It will be were I was standing to take the picture. I also have a small door in the wall behind the Kegarator where I can access the CO2 bottle in this room.
The storage side.
The storage area above the workshop. Notice the electronic device on the green cabinet. It is a signal booster for cell service. I can get full strength signal standing outside but inside the all steel building with the doors closed nothing. This device works great. Has an antennae outside and inside to boost the signal. I think I bought it off ebay.
http://www.wilsonelectronics.com/sto...y/40/46/db-pro
Poweranger is online now   Reply With Quote
Old 02-02-2013, 06:40 AM   #5133
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Very very nice!
Jim
Old 02-02-2013, 07:05 AM   #5134
ducnut
Oddometer: 2,442
Amazing shop!
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-02-2013, 08:02 AM   #5135
dukethedog
Oddometer: 101
Nice job on your shop build- really impressive!
KTM 690R, XC-F250
Ducati Hypermotard S, 999R, 848
65' BMW R50/2, HP2sport, GS1200ADV
01' HD Heritage Springer
09' Bimota DB7
dukethedog is offline   Reply With Quote
Old 02-02-2013, 08:07 AM   #5136
Poweranger
Oddometer: 194
Thanks for the replies. Next thing I would like to get is a cycle lift. I see lots of different types in this thread. Does anyone know how well the lower cost Harbor Freight ones work?
Old 02-02-2013, 08:15 AM   #5137
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 4,240
Send a message via Yahoo to dorkpunch
I've had my cheapo harbor frieght lift for 6 or 7 years now, and I've never had a problem with it. It'll hoist my fat old ST1100 off the ground without hesitation. One of the best / most usefull tools I have ever purchased, hands down.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 02-02-2013, 08:34 AM   #5138
Poweranger
Oddometer: 194
Do you know if they make the side extensions for it? I have ATVs I would like to be able to fit on it also. Or do you think it would be possible to fabricate some home made extensions on each side? I'm guessing it would handle the weight if it handles your ST1100.
Old 02-02-2013, 04:44 PM   #5139
LI LT Owner
Wrong Island, NY
LI LT Owner's Avatar
Oddometer: 1,236
Fired up the new heater today :
and installed a new shield on my R1150R
20,000 BTUs of sweet heat had the garage toasty in under 10 minutes. Once I insulate and install wallboard, it will warm up even faster.
I'm torn between doing 5/8 sheetrock or tongue and groove panel siding.
Rob VB
2003 BMW K1200LT
2002 BMW R1150R
My Blog- Kickin' Tires and Telling Lies
LI LT Owner is offline   Reply With Quote
Old 02-02-2013, 05:20 PM   #5140
thisflatearth
Pro-Commuter
thisflatearth's Avatar
Oddometer: 928
Sheet rock way easier to modify and do add ons down the road in my humble opinion.
Nice heater by the way
"Is it just me or did Erik Buell hire the same fungineers that Walt Disney did" me - just now
YES THAT IS EVOLIFE IN MY AVATAR
2006 Buell Uly - barricade orange
thisflatearth is offline   Reply With Quote
Old 02-02-2013, 05:55 PM   #5141
dwthump
Oddometer: 236
Damn Nice!
Sweet shop! A man that has his own crapper is very happy. I almost expected a latte machine and microwave on the counter...
Darren
*It's a KLR, I'll catch up*
dwthump is offline   Reply With Quote
Old 02-02-2013, 08:08 PM   #5142
ducnut
Oddometer: 2,442
Originally Posted by LI LT Owner View Post
Is that galvanized pipe and fittings you're using for gas line? Looks awfully bright.
I prefer OSB over drywall, as it's durable. With primer and paint, it looks really nice. Poweranger's is a perfect example.
'96 Ducati 900SS
Old 02-02-2013, 10:01 PM   #5143
Poweranger
Oddometer: 194
I also was thinking of using sheet rock, metal, or osb. With osb you can attach brackets, hangers, ect very easily. It is more durable than sheet rock and doesn't dent like the metal panel liner will if you bump it. If you do use osb make sure to prime it with a oil based primer first. The glue in the osb will bleed through a latex primer. I tried the latex at first and it just didn't cover well at all.
Old 02-03-2013, 07:06 AM   #5144
ducnut
Oddometer: 2,442
OSB is manufactured, using water. Anything water based will "re-activate" any product used in its manufacture.
'96 Ducati 900SS
Old 02-03-2013, 08:11 AM   #5145
rdtbull
Have a Plan
rdtbull's Avatar
Oddometer: 14
My Garage (before move)
I have envy over those with space! I just moved to a 3 car Garage Home! unpacking now.
rdtbull is offline   Reply With Quote
Times are GMT -7.   It's 04:55 PM.
