Old 08-13-2013, 07:37 AM   #5521
PA Slammer
I hate titles...
PA Slammer's Avatar
Oddometer: 994
I've been wanting a couch AND a bench for the motorcycle... but don't have room for both. Maybe a build that can function as both... a tarp, a cover over that, some big old cushions, storage under... hmmm?
PA Slammer
PA Slammer is offline   Reply With Quote
Old 08-13-2013, 08:43 AM   #5522
ducnut
Oddometer: 3,306
LazyBoy, for me.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 08-13-2013, 11:58 AM   #5523
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,775
Originally Posted by bymbie View Post
Are you using a wheel chock? If so, how will it fit under the bench? Or will you remove it every time you need to roll the bench home?
Yes, the wheel chock is removed for storage.
EOD3MC is offline   Reply With Quote
Old 08-15-2013, 01:59 AM   #5524
foggy50361
Oddometer: 74
Pissed This is why twist tops were banned in the UK
Originally Posted by go::ahead View Post
Ok so I tore into the box last night and discovered this mess
Does that look like burns to you?
Back together
Conduit that feed through the wall doesn't reach all the way to the box, maybe 1.5" shy. I can't figure out what this these wires even run to, they go through the wall and down into the ground outside of the house.
Still no where near perfect but its the best I could do to just tidy up the wiring safely, I'll have my guy check it all this weekend. My real fear is that I'll find more birds nests like that in the house, I'm going to poke around and make sure...
Here is the first wall finished. No tape or mud, it would really throw off the aesthetic of the place
Those gaps aren't crooked cuts either, some sheets are unlevel at joints by a quarter inch depending on where the studs are
I'm an electrician, it's not difficult to add an extra socket and that's why people take it upon themselves to have a go. Usually it's not them who pay the price of lost personal items or worst death.
This is only my opinion, other opinions are available on request.
"You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose."
"I do not like green eggs and ham".
Dr Seuss. One man getting it right all the time
foggy50361 is offline   Reply With Quote
Old 08-15-2013, 02:22 PM   #5525
chokozip
Oddometer: 194
That's why we don't use cloth covered wire over here.
The black spots might be burns or it could be the residue from the wire sheath.
I bet if you grabbed that wire sheath it would turn your hand black.
I would just guy it out throw some 12-2 in there and keep moving.
Sean
I will meet you on the long road to the middle.
Colorado/Utah 2014 ride report here:
http://advrider.com/forums/showthread.php?t=1019732
chokozip is offline   Reply With Quote
Old 08-15-2013, 03:17 PM   #5526
Easterner
Just Landed
Oddometer: 304
The black spots in the empty box look like where a live wire touched. I can't quite see it clearly but it almost looks like the clamp has a wire burn out in it where it would meet the wire.
Easterner is offline   Reply With Quote
Old 08-15-2013, 04:10 PM   #5527
chokozip
Oddometer: 194
Very possible.
I had one that let the smoke out in my house.
I spent the summer rewiring my house just to be safe.
Sean
Old 08-24-2013, 05:47 AM   #5528
doc dogg
Oddometer: 17
I can finally put up some pics on my new man castle :) 6m x 8m x 3m (or 20' x 26' x 10' for those not using metric)
Here are a few in the middle of construction. We built the walls on the ground and then (with the help of a few local riders) tilted them up and cemented the posts in the ground.
My dad is just modelling in front of the wheelbarrow, I did all the cement mixing and shovelling...
And the finished product
The concrete floor is coming after I spend some money on the GF (she keeps nagging me about a ring and a wedding )
doc dogg is offline   Reply With Quote
Old 08-31-2013, 09:59 AM   #5529
mbrick
Oddometer: 127
What kind of common mistakes are we talking about here?
mbrick is offline   Reply With Quote
Old 09-01-2013, 09:21 PM   #5530
JagLite
JagLite's Avatar
Oddometer: 1,198
Cool2 Before and after pictures
Before:
I built the cabinets in what I call "reverse stack" style to give more work-around room for my car. It is only a small garage and I needed all the room I could get. They work very well.
I hooked up a washing machine water line from the hose bib to a ball valve mounted on the front for easy access. It always had a short coiled hose with spray gun attached.
All doors have slide bolt locks for our frequent earthquakes, I didn't want a bunch of stuff falling on my car or bikes!
I mounted power strips on the door face since the outlets were inside.
Some cabinets I put adjustable height shelves in and some are just removable while others are fixed.
I built the cabinets out of 1/2" MDF and painted them to look like tool boxes. All simple boxes just glued stapled together. Simple bolt on hinges and latches are through bolted. All interior surfaces painted white gloss oil paint. The doors are painted with silver Hammertite (sp?) and the red is just bright red oil paint.
Not shown are all my tools and folding work tables, two more vices, bench top tools, compressor, rolling toolboxes, and everything that was neatly stored in all the cabinets. Why is the garage empty you wonder?
Because we have moved.
That has been my "before" garage shop for ten years....
And now the "after" pictures!
Another one car garage to design and build cabinets for:
AND a two car garage shop to design and build cabinets and work benches for!
It is amazing how much stuff can be put into cabinets and how much space that same stuff takes up when just "put down somewhere" while moving in.
I am looking forward to designing my new shop and getting back to building bike projects. Unfortunately the inside of the house doesn't look much better and we are living out of boxes.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 09-02-2013, 07:26 AM   #5531
foggy50361
Oddometer: 74
Pissed The problem with the HSE is it removes the Darwin effect
Power sockets spurred off lighting circuits, spurs off spurs, undersized cables, diagonal runs behind walls etc. etc. etc. there is a person that lives near me, when he asked me if the modification he had decided to undertake himself (adding a socket) was OK, was mystified when I told him, twisting the wires together then wrapping in masking tape, is not the correct way to do it.
Old 09-02-2013, 07:39 AM   #5532
Riteris
Dessert Runner
Location: A place many ADV Riders fear: The Nation's Capital
Oddometer: 2,895
Wow! What a doofus. He should have used scotch tape, like I do.
Chris
I am taking the advice of all those people that told me, "Hey kid, why don't you go play in traffic!"
Riteris is offline   Reply With Quote
Old 09-03-2013, 04:38 PM   #5533
Nevada
Oddometer: 300
No, no, no. You're supposed to use cloth adhesive tape. Just make sure that you thoroughly impregnate it with Vaseline after you've wrapped the wires to keep any moisture out.
Nevada is offline   Reply With Quote
Old 09-04-2013, 06:33 PM   #5534
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,619
Wait, I was supposed to TAPE the wires after I used superglue to hold them together??
2006 - Triumph Tiger
1995 XR650L
atokad is offline   Reply With Quote
Old 09-14-2013, 09:21 AM   #5535
ducnut
Oddometer: 3,306
I'll keep this thread moving along and put my money where my mouth is.
In the past, when solicited, I've recommended OSB for sheeting and stains for concrete. This is my smaller garage (22'X22') I just finished. I used Sherwin Williams ProBlock Primer, SW SherScrub latex paint (2 coats-this stuff is high build and thick, like paint used to be) on the walls, SW H&C solvent-based solid color stain (2 coats), and SW H&C solvent-based clear gloss (2 coats) on the floor. I used 2-1/2 tubes of latex painter's caulk on the sheeting seams, joints, and screws/nails. If you have any questions, please ask.
I'm going to be doing my shop next. It's split in halves and will get totally different colors. I'm going to try SW's water-based floor products in it, as it doesn't see near the traffic or chemical exposure as the garage. SW has a "high-gloss" product I want to try.
This is what it looked like, caulked and primed.
'96 Ducati 900SS
Times are GMT -7.   It's 04:51 PM.
