Old 11-19-2013, 01:17 PM   #5641
toto#77
toto#77's Avatar
Oddometer: 97
That's mine:
non facile scrivere mentre mi allaccio il casco...
toto#77 is offline   Reply With Quote
Old 11-19-2013, 09:25 PM   #5642
Crashburndie
Oddometer: 19
Originally Posted by PA Slammer View Post
What's the size of that air compressor? Do you use it for small / large shop stuff? Do you wish for a larger / smaller one. Does it work well for what you need it for? I'm looking for one just for smaller jobs.
PA Slammer
I believe its a 26 or 28 gallon craftsman tank. It's usually use it for impact guns, air chisel and air riveting. The only thing it can't keep up that I've tried it an air cut off wheel, not sure if it's the tank size or the PSI output of the tank
So besides that it works great, when I need to cut something I use my freaky angle grinder with a cutoff wheel. One other note, the craftsman is LOUD compared to the same size tank that Husky makes it seems like it's twice as loud(maybe not twice but close)
Crashburndie is offline   Reply With Quote
Old 11-19-2013, 09:30 PM   #5643
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,925
Originally Posted by brider View Post
anyone can be Cardinal fan. It takes true grit to stick with the Cubs!
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 11-19-2013, 09:30 PM   #5644
lightfighter
where does this go?
Oddometer: 2,254
i have a similar craftsman, just the tank is horizontal instead... same results, its been plugged in, and turned on since 2006, in a shed outside the garage. the only thing ive ever wished for was a quieter one. then I moved it outside.
lightfighter is offline   Reply With Quote
Old 11-20-2013, 08:11 AM   #5645
ducnut
Oddometer: 3,297
You need more pump CFM; not tank size. The pump has to keep up with usage, otherwise the tank supply runs down.
If you put a small pump on a big tank, you lose pressure. The tank's PSI will always be reduced and the pump can't bring it back up. You end up having air tools that are working at a reduced rate (an impact that won't impact), because of it. You're better to have a big pump on a small tank, as it'll always keep up with your tools.
Unfortunately, the commonly available compressors are being sold with small, ceramic piston pumps. They run forever, trying to bring the too big tank back up to pressure. This overheats the pump and destroys the piston. Those pumps are designed for intermittent cycling, such as using finishing guns or staplers. Be sure of what you're buying, before laying down the cash.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is online now   Reply With Quote
Old 11-20-2013, 11:53 AM   #5646
trailer Rails
trailer Rails's Avatar
Oddometer: 3,364
Gotta watch for hose restrictions also. A good 1/2" hose with high flow fittings will help a lot. Also check the pressure regulator on the tank, they can be pretty restrictive to CFM output.
trailer Rails is offline   Reply With Quote
Old 11-21-2013, 06:51 AM   #5647
Bikaholic51
Electric Kaiser
Bikaholic51's Avatar
Oddometer: 492
Some people just enjoy being abused.
The Electric Kaiser
Without deviation from the norm, 'progress' is not possible. FZ
88 R100RT-82 R100S-72 R75/5-70 R75/5 hack
Bikaholic51 is offline   Reply With Quote
Old 11-21-2013, 10:17 AM   #5648
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,618
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 11-21-2013, 01:40 PM   #5649
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,925
Old 11-22-2013, 12:49 PM   #5650
brider
Long suffering Cub Fan
brider's Avatar
Oddometer: 175
Everyone wants to kick a guy when his team has been down for a century or so.
2007 Tiger
2001 DR 650
http://www.sporttouring.us
brider is offline   Reply With Quote
Old 11-22-2013, 06:38 PM   #5651
Rustynuts
Rustynuts's Avatar
Oddometer: 80
Mine just got finished today! Now I get to move in and start decorating
Rustynuts is offline   Reply With Quote
Old 11-22-2013, 08:40 PM   #5652
Hotwheelbill
Hotwheelbill's Avatar
Oddometer: 90
Nice! Very Nice!
Hotwheelbill is offline   Reply With Quote
Old 11-22-2013, 09:44 PM   #5653
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,679
Looks like you can host an NFL game in that man castle!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-23-2013, 06:16 AM   #5654
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 4,247
Wink
Originally Posted by Hotwheelbill View Post
Nice! Very Nice!
Yes it is, and hard to pick a fault, but the place should have windows added.....
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 11-23-2013, 07:04 AM   #5655
trailer Rails
Oddometer: 3,364
Is there a build thread?
What did you do with the slab as far as insulation?
This building is very close to what I would like to do, I just need to dig some hillside away and build a large retaining wall.
Times are GMT -7.   It's 10:06 PM.
