Old 12-20-2013, 04:38 AM   #5761
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,263
Holee shit, does everyone have to quote the entire goddamn post ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 12-20-2013, 05:07 AM   #5762
Strog
Geek on two wheels
Strog's Avatar
Oddometer: 415
Originally Posted by Mercury264 View Post
have to quote the entire post ?
No.
Dale S.
Strog is offline   Reply With Quote
Old 12-20-2013, 10:38 AM   #5763
Hohmie
Hohmie's Avatar
Oddometer: 679
Exactly!
Hohmie is offline   Reply With Quote
Old 12-20-2013, 10:51 AM   #5764
Camarodude
Oddometer: 296
especially when there are a dozen pics, and then multiple people include the same pics in their post.
Camarodude is offline   Reply With Quote
Old 12-20-2013, 01:35 PM   #5765
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
The photos can be edited out even on top of it.
There is a post in the XT thread that had over 1/2 of a page worth of links and stuff that was quoted fully twice almost in a row. so it took almost 2 full pages just for one post.
v-- -- -- --v -- -- - -- -v-- -- -- --v -- -- -- --v
'88xt600 , --> '86 XT600(E-start,3TB motor) , --> '89 XT600 , --> '05 KLR650 ,
'85/'04XT600/660 hybrid ,turbo in the future, --> '85XT600 , --> '83 XT550 , --> '83 XL600 ,
'08 525XC , --> '06 LTR450. looking for '96 thru '05 DR650
jjxlrider is offline   Reply With Quote
Old 12-20-2013, 02:12 PM   #5766
ducnut
Oddometer: 3,320
It's not hard to pick or highlight in the quote and backspace out all the unnecessary shit.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 12-20-2013, 02:31 PM   #5767
JagLite
JagLite's Avatar
Oddometer: 1,382
Question Plywood floor
Originally Posted by bymbie View Post
Can someone educate me about this particular epoxy quartz floor? I have a 16x20 shed with plywood floor and would like to finish it... I watched through epoxy threads... still undecided, but this one looks great.
Sent from my SGH-I747M using Tapatalk
I found your question interesting because I am looking at the opposite.
That is, covering my concrete floor with wood.
My new to me (old) garage has a typically cracked concrete floor that is COLD.
(This is in Anchorage Alaska where winter is long and cold)
I'm coming from the house we designed and built and I had put in-slab heat in the garage so I am used to a comfortably warm floor.
Options I am considering:
1. To run waterlines from the unattached house boiler and pour a new cap slab with PEX tubing for infloor heat.
2. Add a boiler in the garage just for the floor tubing and pour a slab.
3. To just lay plywood over the slab and paint the wood.
I have always preferred a wood shop floor to work on anyway and it is nice to not damage sharp tools by dropping them.
It would insulate the cold concrete and would stay warmer from the existing gas heater.
I would use thick plywood, probably the t&g flooring 1.25" (?) with a vapor barrier under it so it would stay flat.
Hopefully.
I could glue it down even.
I could run the PEX tubing under it with spacer plywood between the rows to support the floor plywood for a future heat source to replace the gas garage heater.
I would love to do a real hardwood floor but that is quite spendy and I would be painting the wood anyway.
Plywood would be easier and with edge gluing and bondo joint filling, a bit of sanding and then really good paint it should be good.
I think.
Anybody familiar with anything like this?
See any problems I am missing?
This is for my bike shop so no cars driving in and out to damage the paint.
I would use a good name brand exterior floor and porch paint since I don't see the benefit of expensive concrete epoxy floor paint..
Recommendations? Thoughts?
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 12-20-2013, 02:59 PM   #5768
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
Wood would be a decent flooring and probably good for insulation against cold. I do know it will be bad for using a normal creeper on since the wheels just dig in same with having to drag or slide stuff, but that may not be an issue. Getting it wet from snow ect and somehow drying the entire thing out may be problematic.
In floor Pex heating is nice but you really need to insulate hevily below the concrete so your not trying to heat 3 ft of ground. I put 3 inches of polystyrene panels under my slab(put as much as I could afford at the time) and have a normal house furnace that outputs on the bottom, then made rectangle spouts that the heat blows out right across the floor. They blow under the vehicles and in several directions.The floor is warm but most of the heat stays above ground. The worst thing I don't like about in floor heating is the time it takes to add 5 to 10 degrees if your going to work in there and had it turned down when you weren't.
Old 12-20-2013, 03:46 PM   #5769
ducnut
Oddometer: 3,320
I would highly recommend Pittsburgh Paint's Revitalize paint. I put it in my lawn trailer and the stuff has been fantastic. One would think with ~1200# on the rear tires they'd stick or the paint would peel. It's been flawless, after one season, so far.
'96 Ducati 900SS
Old 12-21-2013, 04:25 PM   #5770
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,419
cleaned up my work bench, up-cycled a old tire
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 12-21-2013, 04:28 PM   #5771
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
Neat ! Makes it look like a porthole into the toolroom !
Old 12-21-2013, 06:04 PM   #5772
dualdogdave
Twin Power Rules!
dualdogdave's Avatar
Oddometer: 148
DualDogDaves Dog House Remodel Installment #4
In installment #3 the Epoxy Quartz floor was completed
It is now time for some office refinements.
The wood inlays will come out making a perfect relief for the flush mounted track system for my new sliding Mall Doors.
The glass door panels meet at the corner for lock-up.
They slide back for an open shop feel...
I will be experimenting with the placement of fixtures as I get more time.
" In the pursuit of motorcycling excellence"
DDD
Santa Cruz Coastal Mountains
"TransHawk" Dyno Video: http://www.youtube.com/watch?v=tA-y7nxL580
"TransHawk" Dyno Charts:
http://picasaweb.google.com/adv990/D...05658028913170
Transalps and other cool bikes spotted in my travels.
http://picasaweb.google.com/adv990/T...eat=directlink
dualdogdave is offline   Reply With Quote
Old 12-21-2013, 07:18 PM   #5773
DHC-2
Oddometer: 57
Nice!
[QUOTE=scorpion;23041322]cleaned up my work bench, up-cycled a old tire
Cool photo of a Beech 18 on floats in that milk crate!
DHC-2 is offline   Reply With Quote
Old 12-21-2013, 09:24 PM   #5774
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
One of these ,
Old 12-22-2013, 03:18 AM   #5775
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,676
Upper middle class white trash carport extention/mancave .
Guns keep society safe.
Colemanfu is online now   Reply With Quote
Times are GMT -7.   It's 05:23 AM.
