Old 02-24-2014, 02:02 PM   #5971
Poweranger
Oddometer: 728
Originally Posted by ducnut View Post
Probably because of old equipment. There was only two tubes, front to rear. I'm guessing, it wasn't enough to do the job. I believe, they were original to the building and am guessing the building to be at least 20yrs old. Obviously, modern equipment brings efficiency.
Probably the case. I believe the old radiant tubes used to draw intake air from inside building which in turn would draw cold air in. They piped mine to draw outside air in through the unit. I do know you do not want them with low ceilings. A friend of mine owns a motorcycle repair shop with 10' ceilings. When those tubes run they really burn you up if you stand directly under one.
Poweranger is online now   Reply With Quote
Old 02-24-2014, 03:16 PM   #5972
ducnut
Oddometer: 3,295
Yes. They drew air from inside.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-25-2014, 01:49 AM   #5973
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
I have a downdraft propane house furnace 95% efficiency that I made a duct box with 2 flat outlets that blow the heated air right across the floor, each one shoots down the bays so it goes under any vehicles. This setup keeps the floor warm and there is no cold areas. Nice for working under a vehicle. I also have 8inch walls and 3ft insulated ceiling, 34 x 24 x 9.5. The furnace only runs for 1 to 2 minutes even at -15F, kept at 60F. The #1 place to spend extra money on is as much insulation as possible, pays for itself in short order.
v-- -- -- --v -- -- - -- -v-- -- -- --v -- -- -- --v
'88xt600 , --> '86 XT600(E-start,3TB motor) , --> '89 XT600 , --> '05 KLR650 ,
'85/'04XT600/660 hybrid ,turbo in the future, --> '85XT600 , --> '83 XT550 , --> '83 XL600 ,
'08 525XC , --> '06 LTR450. looking for '96 thru '05 DR650
jjxlrider is offline   Reply With Quote
Old 02-25-2014, 02:12 AM   #5974
rc mad
Physycotic gecko
rc mad's Avatar
Oddometer: 1,469
Originally Posted by Hybridchemistry View Post
Nice pipe there, any plans with it?
You see that TDM on the right
Already got the flange adapter cut, just need to find someone local to weld it.
Reason I'm doing it is that the stock pipes were heavy rusty crap, the aftermarket pipe on it at the minute is stainless crap (already blowing the packing out) So a nice titanium exhaust from a gsxr is going on, this will be the third bike I've put them on, previous was a f650 Dakar and a curvy sv650, it's almost to easy to do now
"Mad Science" means never stopping to ask "what's the worst thing that could happen?
http://advrider.com/forums/showthread.php?t=1017669
It's Santa time folks
rc mad is offline   Reply With Quote
Old 02-25-2014, 06:59 AM   #5975
Twotaildog
Old Poop
Twotaildog's Avatar
Oddometer: 1,289
Originally Posted by wfopete View Post
Not if you build them yourself:
http://www.barnplans.com/index.html
Unfortunatley I tore my rotator cuff just before I was to start building mine and I had to have a outside firm build them from my plans. I had 24 made (2' O/C) I think they cost me around $5K.
Thanks for the link Pete.
Twotaildog is offline   Reply With Quote
Old 02-25-2014, 07:11 AM   #5976
ducnut
Oddometer: 3,295
I've though about this, for my own garage. I've got a Reznor, hanging furnace that'll work in, either, my garage or shop. I'm undecided, at the moment. But, one of the local HVAC companies has plenty of takeout furnaces sitting around.
'96 Ducati 900SS
Old 02-25-2014, 12:30 PM   #5977
Poweranger
Oddometer: 728
Here is the unit I have.
http://www.radiantheaters.com/GordonRay.htm
Old 02-28-2014, 11:22 AM   #5978
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
The main problem I have with hanging heaters is the cold floor. With our cold climate up here those floors get cold and any little cold coming in from the outside sits there(or when you drive a snow/ice packed truck in that has been outside at -15F ).You have to have a couple of fans always running to get the heat down there and the under any vehicle. With my furnace coming out the bottom it is hot air right at floor level and then blows across the concrete which warms it up. Best way, I think, of doing it other than the in-floor tubes. Warmer climates it may not make as much of a difference.
Old 02-28-2014, 11:27 AM   #5979
ducnut
Oddometer: 3,295
The Reznor was free.
'96 Ducati 900SS
Old 02-28-2014, 01:14 PM   #5980
Poweranger
Oddometer: 728
Those are the best kind..
Old 03-04-2014, 05:11 PM   #5981
Sawatch
2Old2Change
Sawatch's Avatar
Oddometer: 426
My Setup
Cleaned up the garage & got the '84 CanAm set-up for some work.
I am that...
Sawatch is offline   Reply With Quote
Old 03-04-2014, 06:11 PM   #5982
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,542
I don't know anything about can ams but that looks awesome. What model is that?
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 03-04-2014, 07:28 PM   #5983
Sawatch
2Old2Change
Sawatch's Avatar
Oddometer: 426
CanAms
This is a CanAm 175 ASE "ace" "air cooled/single shock/enduro. The couple of years before the water cooled ASE. The '84 was the first year it was produced and they had a company change and were made in England instead of Canada. The CAN era was known for many international wins on their mx & enduro models and the company was very successful in sales. I bought this one new and rode a couple of enduros on it and it is rather rare I'm told. Only 2 known in the US these days. Still a cool bike.
http://advrider.com/forums/showthrea...835109&page=12
http://en.wikipedia.org/wiki/Can-Am_motorcycles
I am that...
Sawatch screwed with this post 03-04-2014 at 07:36 PM
Old 03-10-2014, 08:07 AM   #5984
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,134
Late last fall I bought this.
It came with this.
I closed on it and moved over the New Year's Holiday. It was -15. I've never moved when it's been -15. I will never move again when it's -15.
The shop was built less than a year ago. The previous owner did nothing inside except for basic electric and a concrete floor. With it being so cold and having so much snow I've not done anything to the interior. All my bikes, tools, and work supplies have basically just been dropped off inside and left for warmer days.
It's finally going to be above freezing this week for the first time since November so I will start with some basic insulating over the course of the next few weeks. By next fall I want to be insulated, heated, and ready to roll for next winter.
I'm contemplating insulating the whole thing and maybe building a 'warm room' for my tools and lift. Don't have all that worked out just yet.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 03-10-2014, 09:55 AM   #5985
1 wheel peel
1 wheel peel's Avatar
Oddometer: 101
Keep us posted on the insulation. I have a simular chore to take care of but it dosent get -15 here.
http://www.rockthegear.org/
1 wheel peel is offline   Reply With Quote
Times are GMT -7.   It's 12:28 PM.
