Old 03-10-2014, 10:05 AM   #5986
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,134
Originally Posted by 1 wheel peel View Post
Keep us posted on the insulation. I have a simular chore to take care of but it dosent get -15 here.
This will be a summer-long project. I'll post the progress.
First winter in a long time that I didn't have a mancave to hide in. I knew I was moving so I spent zero time in the one I had.
In this climate being trapped in the house leads to bad things.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 03-10-2014, 11:51 AM   #5987
Camarodude
Oddometer: 263
Originally Posted by Bultaco206 View Post
Late last fall I bought this.
Nice place you got there!
Camarodude is offline   Reply With Quote
Old 03-10-2014, 02:43 PM   #5988
Bultaco206
Bultaco206's Avatar
Oddometer: 2,134
Old 03-10-2014, 06:07 PM   #5989
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,677
So much potential. Take your time and do it right. Will be following the progress.
AteamNM is offline   Reply With Quote
Old 03-11-2014, 04:47 PM   #5990
jjxlrider
Part time adult
jjxlrider's Avatar
Oddometer: 938
I had the same situation 5 years ago, moved in end of November, no time do any sort of heat thing till next spring. I had a machine shed like yours, uninsulated but gravel floor, made it impossible to do anything. With the way those pole buildings are built I ended up with 7-1/2" insulated walls. I put 1-1/2 foamboard along the steel and behind the 6 x6 square posts to fill in that space. Then stud out the rest with standard 2 x 6's between the posts and 6 inch wall insulation. The walls end up flush on the inside with the 6 x 6 so the sheeting goes right across and finishes off nicely. Add 3 ft blown in ceiling insulation and it doesn't take nothing to heat, even this years miserable crap.
I picked up several pallets of mixed insulation foamboard from Menards for $75 each , any sheets that get broke or corners knocked off they just stack on a 4-5ft tall pallet. I ended up with enough to do my hole shed just piecing the halves together and using the complete sections where they fit.
v-- -- -- --v -- -- - -- -v-- -- -- --v -- -- -- --v
'88xt600 , --> '86 XT600(E-start,3TB motor) , --> '89 XT600 , --> '05 KLR650 ,
'85/'04XT600/660 hybrid ,turbo in the future, --> '85XT600 , --> '83 XT550 , --> '83 XL600 ,
'08 525XC , --> '06 LTR450. looking for '96 thru '05 DR650
jjxlrider screwed with this post 03-11-2014 at 04:53 PM
jjxlrider is offline   Reply With Quote
Old 03-11-2014, 05:48 PM   #5991
TheRoss
TheRoss's Avatar
Oddometer: 331
Always a work in progress, but we had a mild winter so I did more riding than fooling around in the shop.
'12 R1200GSA
'75 R90/6
'88 FJ62
TheRoss is offline   Reply With Quote
Old 03-11-2014, 06:45 PM   #5992
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,559
Yeah I know mine are 3 & 6
Btw I just bought a bultaco alpina 1974. Anything I should know? I know it's a bultaco and that's it haha
My buddy says it's complete other than speedo and speedo cable. He has.the kickstarter etc in a box. Says it turns with good compression
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 03-11-2014, 07:12 PM   #5993
Bultaco206
Bultaco206's Avatar
Oddometer: 2,134
Yeah, there's a few things you need to know. What you have appears to be possibly an M138 Alpina 350. (Circa 1975)
Bultacos weren't sold by the year, they were sold by the model number. Each time a model underwent an upgrade its model number was changed, regardless of the time of the year. Locate the serial number on the steering tube on the frame. It will start with the letter M and the first three numbers (two on older models) dictate what model the bike is.
http://ep.yimg.com/ty/cdn/yhst-13492...ENITYCHART.PDF
As for your bike, the Alpina was made for the U.S. market as an all-around playbike. It's basically the same bike as the Sherpa T trials model (different gear ratios) with a bigger tank and a real seat. Think of it as a cross between an Enduro bike and a Trials bike. Parts are easily obtainable. The bikes aren't all that rare. And they usually don't command a high price. That said, they're extremely fun. I'm down to one lone Bul remaining and it's my M115 Alpina 250 that I setup for vintage trials several years ago. I will never sell it.
Old 03-11-2014, 07:58 PM   #5994
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,559
Cool I knew they weren't that rare but he was selling for $500 and it seemed like a cool bike to fart around on Sunday afternoon with.
It's still at his house, I haven't even seen it other than the pic.
I was thinking about powder coating the frame and swingarm etc and doing a clean up,on everything else. I have another buddy that has a speedo from a Sherpa but no cable.
Nessmuk
Old 03-11-2014, 08:14 PM   #5995
Bultaco206
Bultaco206's Avatar
Oddometer: 2,134
It's a very cool bike to fart around on. Alpinas puke torque...they'll go anywhere, especially the 350s.
These younger guys that think their KTM300s are torquey havent ridden an Alpina.
Old 03-12-2014, 09:23 PM   #5996
mfp4073
mfp4073's Avatar
Oddometer: 2,369
Up until recently I had a spot on my back porch that was both parking spot and workshop. Started looking into adding an addition to the family and had to finally break down and build a real shed, which turned into a workshop. Pretty happy with the results!
Old work/parking space
New work shop/parking space
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is online now   Reply With Quote
Old 04-11-2014, 05:48 AM   #5997
mezcal
mezcal's Avatar
Oddometer: 422
Small 6x7 slab.Name:  uploadfromtaptalk1397216869258.jpg
Sent from my GT-N8010 using Tapatalk
2011 Berg 570
mezcal is offline   Reply With Quote
Old 04-11-2014, 06:34 AM   #5998
bigjeff
A&P Mechanic
bigjeff's Avatar
Oddometer: 11
bigjeff screwed with this post 04-11-2014 at 06:39 AM
bigjeff is offline   Reply With Quote
Old 04-11-2014, 06:39 AM   #5999
bigjeff
A&P Mechanic
bigjeff's Avatar
Oddometer: 11
Old 04-11-2014, 06:44 AM   #6000
bigjeff
A&P Mechanic
bigjeff's Avatar
Oddometer: 11
bigjeff screwed with this post 04-11-2014 at 08:57 AM
Times are GMT -7.   It's 01:07 AM.
