Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 09-10-2012, 01:47 PM   #9421
pow_rider17
pow_rider17's Avatar
Oddometer: 97
'02 KTM 400 EXC Street Legal & Plated
I have had it for a little over a year and have ridden it a total of 36 hours according to the hour meter I installed when I got it. It has performed flawlessly and been on everything from highways to single-track. I have a clear New Mexico title in my name. Plastics are in decent shape, a few scratches but nothing major. I have the owner's and spare parts manuals.
I have done all routine maintenance at or beyond factory recommendations:
Oil changes at least every 12 hours
Oil filter changes at least every 24 hours (I have 5 sets of new oil filters for future oil changes)
Air filter cleaned after every ride (I have 2 air filters)
Brake line fluids replaced and bled
Clutch line fluids replaced and bled
Replaced coolant with Engine Ice Coolant
Checked and adjusted valves (only 1 needed a small adjustment)
New spark plug
Other things I have done or it has (extras):
Replaced water pump seal
New oil screens and o-rings
Replaced rear tire (still 60%)
Installed new front and rear sprockets
New o-ring chain
Repacked silencer (muffler)
PRD oil screen drain plugs (no more stripping of the OEM hex head plugs)
New front and rear tubes
3.1 gallon Clarke gas tank (large capacity)
Exhaust heat shield (for right boot)
Odometer
Bark guards with Moose deflectors
Skid plate
Radiator guards
Enduro-Engineering seat (also have stock seat)
Trail Tech kick stand (also have stock kick stand)
Hour meter
Rear fender bag
It is in Rio Rancho, NM.
$2500 email pow_rider17@yahoo.com or call or txt 5053049501
pow_rider17 is offline   Reply With Quote
Old 09-10-2012, 02:48 PM   #9422
MartiniUp
Oddometer: 1,822
If I wasn't on the far east side of Texas, that 400 would be sold. Very nice bike!
MartiniUp is offline   Reply With Quote
Old 09-10-2012, 03:09 PM   #9423
Trinity_Session
Trinity_Session's Avatar
Oddometer: 533
Isn't NM to the West of Texas?
Trinity_Session is offline   Reply With Quote
Old 09-10-2012, 03:13 PM   #9424
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
3- Trekker 33L cases
http://www.giviusa.com/Side-hardbags...Lateral/TRK33N
http://www.motorcycle-superstore.com...WT.MC_ID=10010
3 -Linners
http://www.revzilla.com/motorcycle/g...-internal-bags
1 - top passenger pad for top box (unmounted)
http://www.sierrabmwonline.com/produ...18-e133-p-2698
System was used for 1 weekend tour. Perfect condition. All keyed the same.
Adds up to aprox $1150 (plus shipping) if new.
$900 - local sale only
i'll break up and sell top case, pad & linner
and 2 sides and liner.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-10-2012, 04:05 PM   #9425
WIDE LOAD
WIDE LOAD's Avatar
Location: SOUTH WEST COLORADO,ADVENTURE,SPORTBIKES,DIRT BIKE
Oddometer: 55
4 tool set
sent you a PM
Originally Posted by Alti Tude View Post
Got some tools I haven't used in a long time, and wont be needing. I bought these a while back for a basement remodel project and haven't used them much at all since.
First a Dewalt 4 tool set. 18V, includes the DW997 hammer drill, DW938 reciprocating saw (excellent for trimming trees), DW936 trim saw, and DW919 light. Includes the charger but no batteries, tools are all in great shape and work as they should. Includes some spare blades for both saws. $100
Next up is a Dewalt DW911 radio, in excellent condition. AM/FM plus an aux input. Also functions as a charger. Spent most of its life on a shelf in the
basement. $50.00
Last up is a Remington 496 nail gun. This uses a 27 caliber round to drive nails through pretty much whatever you want to drive them through. Kicks like the handgun it is. I used it to set footers in the basement and its sat since. Excellent condition, works great and comes with some spare ammo plus the cleaning kit and documentation. $50.00
Wide Load
WIDE LOAD is offline   Reply With Quote
Old 09-10-2012, 10:27 PM   #9426
MountainsandRivers
loves dirty things!
MountainsandRivers's Avatar
Oddometer: 2,473
1996 KLX 650R for sale
1996 Kawasaki KLX 650R for sale
$1300 FIRM
This has been a good bike, but it is just not getting used anymore, could use a new home, someone to love on it again.
The good-motor was rebuilt about 500 miles ago (approximate, speedo broke, but does have a new Vapor in box, uninstalled). OEM piston, but cylinder was resleeved by LA Sleeve to a boreable sleeve, not Nikasil lined, so if you want to go for a bigger piston, you can do so easily. An APE manual cam chain adjuster was added at that time, as well as new timing chains. Valves were adjusted recently. Bars are renthals, CR high bend i believe, much narrower and straighter than stock. New CDI, coil and voltage regulator last summer. Pro Circuit T4 exhaust. 13 tooth up front. Seat was recovered and an inch of foam added, so it is pretty comfy. Rear rim has heavy duty spokes. New tires. Fork seals were done last summer and it hasn't been riden since then. Titled and was last plated in 2010. I did notice the title lists the model as KLR, but the VIN matches. Maybe that is why it passes through the system easily? I do have an extra rear wheel and stock exhaust to go with it.
The bad-missing a few body bolts (front lower radiator shrouds, one bolt on right rear panel is broken off and needs to be tapped). Needs a new brake light switch and a headlight bulb. Front brake feels soft, probably just needs bled. The tank mount tab on the frame needs to be rewelded. I currently has a bungy, the seat bolt and body bolts holding it on, been like this since i got it, so not a major deal. Carb just got adjusted, had been leaking a bit, float adjusted, all good now. Rims have some dings, but it still rolls fine. It plays in rocks, wasn't too worried about perfect rims. Chain should probably be replaced soon. As you can see, a lot of this is easy stuff, just needs a new home and some shop time.
I think that covers it. I wantto be honest, probably to a fault, about condition so expectations are met, but whoever buys it will get a good bike that can run with an XR650R off road just fine. I have done a lot of singletracking with it, around the San Juans and Moab and it gets it done. The low gearing makes it a tractor! PM me with any questions. I can drive a little to help with the sale, but that would need to be at a convenient time. I live in Telluride, so good reason to come down here anyway, it's beautiful this time of year!
2009 Beta 525RR
supporter of COHVCO, RMAR, PAPA, TPA and the GOATS!
MountainsandRivers screwed with this post 09-21-2012 at 02:17 PM
MountainsandRivers is online now   Reply With Quote
Old 09-11-2012, 10:40 AM   #9427
Olas
the darkness
Olas's Avatar
Oddometer: 3,975
DDM 35W Hi/Low H4 HID kit
5000K color (white). Harness was already modified to fit on a motorcycle, it will plug and play on a DR650 for sure, you may need to extend or shorten the battery leads based on how your bike is set up.
This is for an H4 bulb socket.
$25 picked up
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 09-11-2012, 02:06 PM   #9428
pow_rider17
Oddometer: 97
New spark plug
New o-ring chain
Odometer
Skid plate
Radiator guards
Hour meter
Rear fender bag
For the asking price I will drive it as far as Amarillo or Lubbock........
Or any other direction in a 300 mile radius--Larry
Old 09-11-2012, 09:08 PM   #9429
Trinity_Session
Oddometer: 533
IMS shifter for DR650
Anyone have one laying around and don't need it anymore?
Thanks,
Chris
Old 09-12-2012, 09:19 AM   #9430
bobfab
bobfab's Avatar
Oddometer: 1,395
Hey so i am aware this isnt really the place but wanted to offer to you local FF's, i am parting out a 2001 yz125 on ebay, everything starts at a dollar, and there are some money parts in there, (CF guards, Procircuit pipe and Trailtech kickstand). Let me know if you are one of the bidders and we can work out a deal, package deal etc...
http://www.ebay.com/sch/chronicsinne...ESELX:IT&rt=nc
Thanks dudes!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 09-12-2012, 10:47 AM   #9431
PigTrail
PigTrail's Avatar
Oddometer: 177
2000 xr100
2000 Honda XR100
Dependable and mechanically excellent trail bike. Starts, runs, and shifts easily. Wife simply outgrew it. Can remove pink stickers if you'd like.
Includes:
CRF100 number plate
CRF150R front fender
White Acerbis hand guards
long shift lever for use with mx boots
standard xr100 shift lever
Extra red Acerbis hand guards
Extra red Honda XR100 gas tank
Current (through March 2013) Colorado OHV sticker
Front tire is nearly new with only one ride on it.
Rear tire has 80% tread
Oil checked and changed regularly.
$950 OBO
250EXC - plated, KX500, XR650R - plated,CRF250L,TTR125
No Tetas Tour - Mexico
Video - Best of 2012
PigTrail is offline   Reply With Quote
Old 09-12-2012, 11:28 AM   #9432
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 637
Front trial tire
Pirelli MT43 front trial tire. In great shape. $25
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 09-12-2012, 11:37 AM   #9433
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 637
Mountain Smith travel pack
Mountain smith makes some great bags
pack can be used as duffel type bag or full back pack. About 65 liters in size, in great shape, built really sturdy.
MountainSmith Ramble. $50
Old 09-13-2012, 12:32 PM   #9434
ILikeToThump
I'll Ride Anything.......
ILikeToThump's Avatar
Oddometer: 717
Beautiful Adult Owned 2000 SV650 LOW MILES ALBUQUERQUE
This is a wonderful bike with just over 10000 miles! Currently it is setup for a woman or small man. It has a full oil and filter change 100 miles ago! It has been garaged and babied since new. We (myself and the ex) are the second owners. She says she wants it gone but I am out of room!
It has well over $1500 in accessories on it including a staintune slip on pipe ($840!), heated grips, dominator headlights, sliders, custom professionally painted hugger,a ventura rack system for sport touring and more. It currently has a lowering kit on it for a shorter man or woman. I have the stock dog-bones still if you want to return it to stock height. The lowering links are adjustable and it is currently lowered only 1 inch. This bike runs GREAT and sounds even better!
pics taken this Evening:
I will sell the beast with everything for $2200! I am considering stripping everything off of her and selling it even cheaper. I will try to sell it as a package first! Bucky
"You cannot legislate the poor into prosperity by legislating the wealthy out of prosperity. What one person receives without working for, another person must work for without receiving. The government cannot give to anybody anything that the government does not first take from somebody else. "
Adrian Rogers, 1931
ILikeToThump screwed with this post 09-13-2012 at 11:03 PM
ILikeToThump is offline   Reply With Quote
Old 09-13-2012, 05:29 PM   #9435
selaznog
Avoiding pavement
Oddometer: 2,845
Gas Gas EC 300 two stroke!
I'll get some pics up later. It's a 2008. Street registered in NM. About 50-60 hours, great shape, big tank, aluminum skid plate, tires in good shape, Revloc clutch. Located in Albuquerque. Only selling because I've got a project that's going to take some room. The only blemish I can think of is that one of the radiators is bent. I bought it as a dealer demo. These are $8k new.
$3000 for inmates
selaznog is offline   Reply With Quote
Times are GMT -7.   It's 04:47 AM.
