Old 03-17-2007, 10:39 AM   #1
life101 OP
life101's Avatar
Oddometer: 60
Question Help on R80g/s top tripple tree brace?
I've installed a San Jose (or Toaster Tan - I can't remember which) on my R80g/s, and everything's down snug and tight, but I get a pronounced knock when I hit even a small bump.
What am I missing, please? I can't find it - help!
"It ain't the fall that kills you - it's the meeting with the ground."
life101 is offline   Reply With Quote
Old 03-17-2007, 11:11 AM   #2
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,036
Since the new clamp is thicker, the top nut doesn't doesn't screw into it the same amount unless you raise the stanchion.
The new clamp would have to be the same thickness as the old one at the steering head for the dimensions at the fork legs to work out the same. It probably isn't.
Because of all this, your springs aren't preloaded the same amount as they are with the OE clamp.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 03-17-2007, 12:43 PM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
If you tightened the clamp around the fork tubes before you torqued down the top center nut that may be your problem. The top nut needs to be pulled down snug before you tighten the clamps around the forks, other wise it may leave a space and allow that knock. Guess how I know this? JT
jtwind is offline   Reply With Quote
Old 03-17-2007, 03:32 PM   #4
life101 OP
life101's Avatar
Oddometer: 60
Question
OK - so I've checked just about everything I can think of to find this clicking sound I get every time I hit even the smallest bump ...
Loosened the pinch bolts on the TTT and loosened and retorqued the main nut which made no difference.
Then I loosened the pinch bolts on the bottom TT and re-torqued the TTT again - no change.
Maybe it is the springs chattering in the fork tubes - but I installed the longer Progressive springs, and can't imagine them having any play.
Anything else I could be missing?
Thanks for the advice!
Joey.
Old 03-17-2007, 04:03 PM   #5
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
The only other thing I can think of is maybe you don't have the proper adjustment on the steering stem adjusting nut. If there is loosness there torqueing down the large steering stem locknut doesn't remove the play. When I had this problem on mine, I could reach down and feel the little bit of movement when I hit a bump. JT
Old 03-18-2007, 11:10 AM   #6
Mendodave
Road Scholar
Oddometer: 934
Did it do the knocking before?
My G/S has always done that. with stock spring and with progressives, with stock upper plate and with the Toaster Tan sweetheart of a triple tree.
My dealer years and years ago said they all did it.
But if it didn't do it previously....
david
MSF RiderCoach
'81 R80G/S 'Moby'
'82 CT110 "Postie'
Mendodave is offline   Reply With Quote
Old 03-18-2007, 05:15 PM   #7
life101 OP
life101's Avatar
Oddometer: 60
Question
Thanks for all the advice, guys. I've installed a billet triple tree on both my R80ST and now on the R80G/S, and they both knock!
On the G/S I've done all that was suggested here and more. Still have the knock.
And no, it didn't knock before changing the TTT on either bike!
One of those eternal (infernal) mysteries? Well, at least I know from this exercise that nothing's loose or unsafe - just a bit obnoxious!
I appreciate the help,
Joey in Dallas.
Old 03-18-2007, 05:46 PM   #8
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
My knock was clearly attributed to steering bearing preload.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 03-18-2007, 07:30 PM   #9
life101 OP
life101's Avatar
Oddometer: 60
Question
Hey Stephen - thanks for chiming in. I adjusted steering bearing preload twice today. It was originally a bit loose, and I adjusted it first a bit too tight, and then backed off a bit - both times the knock didn't change at all.
BTW - it's a "click" I get when I hit a speedbump or minor bump in the road - the sound seems to come from the very top of the forks.
Thanks all!
Old 03-20-2007, 07:30 PM   #10
ozadvntr
Planning that trip, again
ozadvntr's Avatar
Oddometer: 1,175
Try a spacer on top of the spring to add a little preload. Try about 15mm - 25mm dependant on your weight. This may help.
Mick
ozadvntr is offline   Reply With Quote
Old 03-21-2007, 06:11 AM   #11
life101 OP
life101's Avatar
Oddometer: 60
Yes - that's really the last thing I can think of to try.
Old 03-22-2007, 11:33 AM   #12
life101 OP
life101's Avatar
Oddometer: 60
Pissed Damnit!
So I install spacers on top of the springs - adding about 3/8 inch there. Absolutely no play. Also went ahead and changed the oil to 10 wt. Had 7 wt. before.
Go out for a test ride and I'm greeted with my same familiar click!
And the gods chuckled to themselves ...
Old 03-22-2007, 03:03 PM   #13
OldTiredness
Oddometer: 35
Mine, 81 with progressive springs and spacers, has made that noise for the past 50k. Don't think there is much you can do - if you want to use the progressive springs...
OldTiredness is offline   Reply With Quote
Old 03-24-2007, 05:59 AM   #14
life101 OP
life101's Avatar
Oddometer: 60
Thanks Old tire - that's what I figured, but it's nice to know I'm not the only one to have it happen.
Oh well - it was a good exercise - I know the front end is as bulletproof as it's gonna get for the time being!
Old 03-24-2007, 10:40 AM   #15
Tim McKittrick
Oddometer: 1,763
My R100RT does the same thing- an so did my R100RS- a pronounced "clack" when rolling over small abrupt bumps. I have checked steering head bearings, spring height etc., etc, and can't get the click to go away. On the RS I slid some small lengths of plastic tubing over the springs to keep them from hitting the inside of the fork tube, and that helped some. I'd love to know of a definite fix as it irritates me to no end.
Tim McKittrick is offline   Reply With Quote
Times are GMT -7.   It's 06:15 AM.
