Old 01-22-2010, 01:49 PM   #166
jeep44
junk collector
jeep44's Avatar
Oddometer: 2,066
Originally Posted by Aberdeen
+1 on this as of today...
Had to go to the Twin Cities for work, and the HF store was just off the highway. Stopped in with my 20% off coupon, found it, went to pay and found out it was only $19.99! Gave her the coupon, and the grand total was $17 and change.
Plugged it in when I got back to the truck to test it before leaving. Pretty solid build, nice air hose, threaded connector for the tire, quick connect for the compressor...I'm impressed.
Looking forward to giving it a shot when I get home, and maybe retiring my much noisier Slime compressor, which BTW still does the job.
Cheers!
I picked up one of these compressors today,too. $20.
jeep44 is offline   Reply With Quote
Old 01-22-2010, 02:02 PM   #167
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Originally Posted by numbskull
You SIR, are what we in addiction recovery call an "ENABLER"....
What can I say
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-22-2010, 02:03 PM   #168
jrs200
jrs200's Avatar
Location: Through the big mud hole to the big rock hill SC
Oddometer: 175
Originally Posted by gogogordy
+1.
I never buy anything there that has any moving parts.
What isn't made in China these days. Might as well go for the best price cause all of it is cheap.
I have a lot of HF products. No problems or complaints so far. I have had some things for 10 years or better. I did have a flashlight and a compressor fitting go bad took it back an exchanged without receipt. Just like sears
Not bad for the 100+ items I bought there.
2005 DR650 The doctor is in
2002 KX500 4 Stroke Smoker
jrs200 is offline   Reply With Quote
Old 01-22-2010, 02:15 PM   #169
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Originally Posted by jrs200
Just like sears
Old 01-31-2010, 06:36 PM   #170
aphazia
KLR+Duct tape+Dreams!
aphazia's Avatar
Oddometer: 1,258
Now I just have to wait for the tire changer to go on sale again...
2007 KLR - Black! 35000 miles and counting since July '08.
1997 KLX 300R - plated in NY state- cause KLR + Pine Barrens sand = not so fun!
aphazia is offline   Reply With Quote
Old 01-31-2010, 06:56 PM   #171
B02S4
Aye
B02S4's Avatar
Oddometer: 1,056
Item 92630 8 Piece Right Angle Screwdriver is worth it's weight in gold; typically on-sale for under $3 USD.
http://www.harborfreight.com/cpi/cta...emnumber=92630
B02S4 is offline   Reply With Quote
Old 01-31-2010, 08:00 PM   #172
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,267
one of my favorite tools. I used it tonight even.
Jim
Old 02-01-2010, 08:45 AM   #173
pplassm
Brace for collision!
pplassm's Avatar
Oddometer: 2,557
Bead Beaker
I bought one of these on sale for $15:
http://www.harborfreight.com/cpi/cta...emnumber=98875
I used it on a really stubborn set of tires. The front went well, but the rear was really on there.
I put a fork tube on the handle for added purchase. Do not do that. The handle folded like a wilting flower.
A few minutes with a torch and some steel stock, and I was back in business.
Pete
pplassm is offline   Reply With Quote
Old 02-01-2010, 11:05 AM   #174
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,737
Just my .02
I had one, didn't care for it. For me it's easier with tire irons and a piece of carpet.
Nuke Gay Whales for Jesus.
Porsche Audi VW
B.Curvin is offline   Reply With Quote
Old 02-01-2010, 12:38 PM   #175
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 702
Check your mailbox today....
IBA #33260
cablebandit is offline   Reply With Quote
Old 02-01-2010, 09:15 PM   #176
xroad
Oddometer: 774
Originally Posted by CMWoody
And Bob, I don't recommend the neon condoms...not only do they smell like the store, they itch and I ended up with two kids... Damn China junk!
Are the two kids Chinese? (Sorry, I can't resist )
Carpe diem quam minimum credula postero.
xroad is offline   Reply With Quote
Old 02-01-2010, 10:39 PM   #177
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,522
Picked up a plastic welder today, the $30 one that hooks up to an air comp.... Worthless.
I think it warmed up to 120F, if that, at the recommended 3.5psi. Which is far too much flow for any plastic welding work whatsoever.
It's getting returned tomorrow. I'll stick with the $20 radio shark soldering iron and a dremel tool.
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 02-01-2010, 11:34 PM   #178
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
The instructions are prolly not complete, or did not translate enough. An air heater is specified primarily to flow rate, not pressure. To heat the air to maximum, the flow rate will need to be down at/near 1CFM.
That'd be about right for a low power heater of less than 1500W say. If the heater element isn't adjustable, then regulate the temp output with flow rate. A simple valve downstream of the regulator will do the trick.
Old 02-02-2010, 08:27 PM   #179
xroad
Oddometer: 774
Originally Posted by wibby
Got one, today, on sale and a 20% off coupon ... $17.11 !
First thing I notice, it is quiet. The little $5-10 pumps I had, all 4 of them, one for each vehicle I have, are noisy, and slow. Have not actually use the new pump to pump air into a tire yet. If it live up to the claim of 3.5 minutes per tire as stated on the box I am happy.
Instruction said run it for a max time of 12 minutes and cool for 30 minutes.
Now I remember the small $5-10 pump also had a time limit. But, I forgot. Last weekend, I pumped 15 tires (3 cars) with one little pump, non-stop. Pump did not have a meltdown, just really hot. I guess they are a lot tougher than expected for a $5-10 cheapy. I expect this bigger pump to be better and tougher.
xroad screwed with this post 02-02-2010 at 08:49 PM
Old 02-02-2010, 09:41 PM   #180
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
You can run a bike motor over red line for a while too and it won't grenade.
Sometimes a product is built to exceed the user's penchant to destroy it, and sometimes it isn't. Which detail of this new pump (great deal btw!) makes you think it will perform better, its looks?
Times are GMT -7.   It's 01:03 AM.
