Old 02-03-2010, 03:31 PM   #181
xroad
Oddometer: 774
Originally Posted by Poolside
You can run a bike motor over red line for a while too and it won't grenade.
Sometimes a product is built to exceed the user's penchant to destroy it, and sometimes it isn't. Which detail of this new pump (great deal btw!) makes you think it will perform better, its looks?
I figure if all these pumps are EQUALLY cheap, then the larger pump probably have less stress on the parts. The smaller pumps sounds like it is spinning a lot faster too.
In fact, this larger pump, the exterior fit and finish does look a lot better than the other mini pumps. I am hoping they put in the same effort on the guts as well. The cheap mini pumps are REALLY looks like "minimal production effort" used.
Carpe diem quam minimum credula postero.
xroad is offline   Reply With Quote
Old 02-28-2010, 08:55 AM   #182
TeneRay
2>4
TeneRay's Avatar
Oddometer: 2,095
i've sorta learned what to and what not to buy from HF.
Hand tools: unless it is forged, be weary. I only trust wrenches from them. Sockets I stay away from.
Power tools: Haven't bought one from them yet. Used a HF angle grinder at a shop once and it was a dog. Quit while I was using it so i unplugged it and plugged it back in; started right up.
Pneumatic tools: Hit or miss. Bought a die grinder and it ate itself. Bought an angle die grinder and it works just fine.
Things you can't go wrong with (knock on wood): Small parts washer (if the pump burns out, get a new, better one from Norther Tool), Small blasting cabinet (with an exhaust system, this thing is great), blasting media, hammers, motorcycle chock, motorcycle swingarm stand, and a 12T bottle jack.
Things I broke the first try: cheap wratchet straps and gear puller
Tip: if it's a tool that sees a lot of excessive force and it's not forged, i stay away from it. A lot of the tools are casted which is why they are so cheap and break easily (yes, i know forged parts start out casted). The way you can tell the difference: if it's smooth, there's a chance that it is forged. if it has a rough finish, probably casted.
Print out the 20% off coupon online every time I go
TeneRay screwed with this post 02-28-2010 at 09:00 AM
TeneRay is offline   Reply With Quote
Old 02-28-2010, 01:29 PM   #183
CollinsB
CollinsB's Avatar
Oddometer: 988
Harbor freight lift..
Has anyone had any problems w/ the lift? The hydralic jack requiring fluid, or simply stopped working?
Mine just stopped working (won't lift)...I can't see if it needs fluid, but one my way to pickup some now.
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 02-28-2010, 02:59 PM   #184
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,143
Not really had a problem with mine but it did start to get a bit sluggish and would start to fall if left on it's own. Someone on here suggested pumping it with the down lever down to get rid of air I think ? Did that, been fine ever since.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 02-28-2010, 03:35 PM   #185
CollinsB
CollinsB's Avatar
Oddometer: 988
I just added fluid to the jack....that didn't fix the problem.
The jack will pump when turning the whole lift on it side. That however is not useful. Tried holding down the release lever while pumping, no go.
Anyone have any ideas? Do they sell replacement jacks for these? I count on the lift as I use a couple times a week for servicing.
Brian
Old 02-28-2010, 05:28 PM   #186
showkey
Oddometer: 1,916
In China
Seroiusly this has come up before and the HF jacks are junk from day one try to find a decent quality replacement.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 02-28-2010, 06:33 PM   #187
pne
pne's Avatar
Oddometer: 754
I buy all my tools from HF.
A 3/8 breaker bar $30 from the hardware store.
A 3/8 socket wrench is about $5. I've been using that and a long piece of pipe for the last 5 years, and it hasn't broken yet.
Wrenches, sockets, rachet straps for the bike, safety wire pliers, work stool, creeper, even my 240V space heater in the garage. Hand tools are lifetime warranty anyways
pne is offline   Reply With Quote
Old 02-28-2010, 07:53 PM   #188
weerider650
weerider650's Avatar
Oddometer: 584
Anyone have any ideas? Do they sell replacement jacks for these?.
I asked Harbor Freight beofre buying a lift. They have a 1-800 number to call and they do nothing but work on spare parts for the equipoment they sell. Call your local harbor freight and get the number or check the website. On another note there was a guy on here that was able to buy a similar bottle jack from the hardware store and adapted it to the lift as a replacement.
weerider650 is offline   Reply With Quote
Old 02-28-2010, 08:28 PM   #189
CollinsB
CollinsB's Avatar
Oddometer: 988
Originally Posted by cali_beemer
I asked Harbor Freight beofre buying a lift. They have a 1-800 number to call and they do nothing but work on spare parts for the equipoment they sell. On another note there was a guy on here that was able to buy a similar bottle jack from the hardware store and adapted it to the lift as a replacement.
I'll call the 800 number tomorrow... I'm not even sure just how the jack is secured. Didn't notice whether it is welded or bolted in.
Brian
Old 03-02-2010, 06:09 PM   #190
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,808
I finally got around to using two different HF tools I had bought with hopes they would be useful.
I bought the small bearing & seal driver kit (has 3-driver rods and about 20 different sizes) for $14.99.
Also got the Blind Hole Bearing Puller, for $29.99.
Used them both this weekend on my TTR250 to do front & rear bearings, and all the swingarm bearings too. Worked flawlessley, very useful and considering the price even compared to fleabay alternatives, I'm thrilled.
The Rant-Fu blog & podcast ->Rant-Fu
swingset is offline   Reply With Quote
Old 03-02-2010, 09:53 PM   #191
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,283
My most recent "Man Store" purchases:
Jim
PS Less than $200 in these, and several small tools.
JimVonBaden is online now   Reply With Quote
Old 03-02-2010, 10:28 PM   #192
RedRocket
Yeah! I want Cheesy Poofs
RedRocket's Avatar
Oddometer: 19,872
Let us know how that little blaster works out.
RedRocket is offline   Reply With Quote
Old 03-03-2010, 06:55 AM   #193
JimVonBaden
"Cool" Aid!
Oddometer: 52,283
For $25, if it works at all, it will be worth it.
I have a project car I recently purchassed, and it has some rust. I need to blast the rust, and make some patch pannels. That is what this stuff is for.
My new toy.
Sat untouched for 20 years. I had it running in a couple hours, and drives good!
Jim
Old 03-03-2010, 06:47 PM   #194
B02S4
Aye
B02S4's Avatar
Oddometer: 1,056
Originally Posted by JimVonBaden
...My new toy...Sat untouched for 20 years. I had it running in a couple hours, and drives good!...
Nice! I always liked those GT's. Is yours a 1.9?
That PA plate brings back some memories. I liked that one better than the tri color we have now.
B02S4 is offline   Reply With Quote
Old 03-04-2010, 01:41 PM   #195
weerider650
Oddometer: 584
My new toy.
Jim
Nice car Jim. I would like to get a project vehicle someday myself
Times are GMT -7.   It's 09:30 PM.
