Old 03-20-2007, 01:08 PM   #1
homerj OP
742 Evergreen Terrace
homerj's Avatar
Oddometer: 5,348
Bluhduh Over-reved the engine
So I finally got my bike back together and starting under its own power. On my first ride I missed a shift while merging onto the freeway and over-reved the engine (8K +/-) and the engine starting running poorly (no power, no accelleration). I got the bike off the freeway and stopped.
After getting the bike home and letting it cool down, I pulled the valve cover and noticed about that the valves needed adjusting but looked straight.
I also drained the gas in the tank left over from August and refilled with fresh fuel thinking that bad fuel could have be detonating and caused the valve to move out of adjustment (I know, probably wishful thinking) and the rough running.
After adjusting the valves the bike seems to be running OK but I can't get rid of the feeling that I've fatally wounded the engine.
Can these engines tolerate 8K for very brief durations without needing a total overhaul?
If the engine won't tolerate 8K where should I look for damage?
TIA
I'm so bummed
09 570 Rallye Beast
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…"-Hunter S. Thompson
homerj is offline   Reply With Quote
Old 03-20-2007, 01:28 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,207
TIA
I'm so bummed
I have to believe that they can take very brief intervals of over-revving, like on a missed shift. (lord knows I miss shifts all the time)
but I cant explain why you are experiencing those other problems. maybe they are not related to the over-rev, but are related to the rebuild? You say it was on the first time out.. and just getting onto the highway indicates maybe the first time over 1/2 or 3/4 throttle? Maybe the probems were there already, just not noticed till you got up to a good speed. You may have just had shit gas in it, like you said.
did it run like crap the whole way home?
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 03-20-2007, 01:48 PM   #3
RocketJ
Oddometer: 674
Laugh Relax
Unless you heard some really ugly noises. Most likely the valve adjustment and poor running had nothing to do with it.
With stock pistons and valve train I don't beleive you could hurt it.
RocketJ is offline   Reply With Quote
Old 03-20-2007, 01:51 PM   #4
Lurking Luddite
Lurking Luddite's Avatar
Oddometer: 381
give it a compression test
Don't spoil your woman only ruins her for the next guy
Lurking Luddite is offline   Reply With Quote
Old 03-20-2007, 03:21 PM   #5
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
when was the last time you re-torqued the heads and tuned the valves?
datchew is offline   Reply With Quote
Old 03-20-2007, 03:28 PM   #6
jdiaz
Oddometer: 32,326
I've heard that the rotor windings are the limiting factor to max rpm in an Airhead.
jdiaz is offline   Reply With Quote
Old 03-20-2007, 03:51 PM   #7
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,344
Do a leak down test and compression test.
I've over revved and done nothing and I've over revved and bent valves.
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is online now   Reply With Quote
Old 03-20-2007, 04:06 PM   #8
nick_rhinocycles
nick_rhinocycles's Avatar
Oddometer: 508
I agree. You should not worry, do the general maintenance for the sake of sanity, then go out and over-rev it again! I mean Run it! =-)
--N
nick_rhinocycles is offline   Reply With Quote
Old 03-20-2007, 04:24 PM   #9
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,312
...the valves needed adjusting but looked straight.
I'm going to go against the tide here and suggest that you have a problem. It doesn't mean that the engine needs a total overhaul but you may have bent valves. Did the clearances open up? That indicates a bent valve that isn't closing fully. If performance dropped off then you probably were losing compression. The only way to get loss of compression through the valves WITH increased clearances is if you bent some valves.
If the clearances closed up, then maybe nothing bad happened. But either way, you aren't going to see the bent part just by opening the valve cover.
Just for grins, look inside the valve cover and see if there are rub marks from the rocker arms.
So, which way were the clearances off?
Old 03-20-2007, 07:58 PM   #10
BMWRich
BMWRich's Avatar
Oddometer: 1,687
I'd think you'd have a "valve float" condition.
Motor spinning so fast that the valves don't close all the way,no combustion so no power.
Definition: A high-rpm engine condition in which the valve lifters lose contact with the cam lobes because the valve springs are not strong enough to overcome the momentum of the various valve train components. The onset of valve float prevents higher-rpm operation. Extended periods of valve float will damage the valve train.
Did it a few times on an old airhead GS100. Never any damage just loss of power.
Compression check will tell if valve/s are bent.
2007 GS Adv
Everybody likes a little ass,..but nobody likes a smartass...
BMWRich is offline   Reply With Quote
Old 03-20-2007, 08:04 PM   #11
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,910
TIA
I'm so bummed
I've done similar on my R90/6, was cruising along using the "cruise control" knob mounted on the the throttle. I went to down shift for passing, pull in the clutch and just let go of the throttle, forgetting I'd locked it in place.. ZOOM.. Well over 8 grand, but thousands of miles later, no sign of bent valves..
Boon Booni is online now   Reply With Quote
Old 03-20-2007, 08:23 PM   #12
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
solution there would be stiffer springs but your top end's life is halved...
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 03-20-2007, 08:29 PM   #13
homerj OP
homerj's Avatar
Oddometer: 5,348
They were tight, but i forgot to measure how much they'd moved.
I checked the valve cover and there aren't any rub marks. I also took a look at the pushrod ends by rotating the engine past TDC and they looked OK (not mashed or scarred in any visually detectable way).
It looks like a leakdown compression is the test for bent valves?
Also, I plan on just finishing out this tank of gas (300 mi +/-) and rechecking the valves.
It's been so long since i rode it I'm just having an issue knowing what noises are normal and what noises mean trouble.
Thanks for the help.
09 570 Rallye Beast
Old 03-20-2007, 10:36 PM   #14
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Asked of the Airhead experienced . . . Could he have twanged a pushrod?
- Jim
EDIT: Apparently I had this thread open in another window for a long while, and responded without hitting refresh. And so did not see Homer's response. I see that bending a pushrod would open the valve lash.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 03-21-2007 at 03:36 AM
Poolside is offline   Reply With Quote
Old 03-21-2007, 03:09 AM   #15
AntonLargiader
Oddometer: 4,312
Valves float and the oil pump cavitates (about 8200 RPM I think).
Maybe I misunderstood what you wrote. Did you indicate that you had a persistent loss in performance until you got home and adjusted the valves, or just that power was off while you were over 8000 RPM?
If you just had top end work done, some tightening of the valves would be expected on the first ride. Otherwise, well, dunno. I guess I'm not sure of exactly what you experienced.
Times are GMT -7.   It's 06:12 PM.
