Old 03-24-2007, 02:32 PM   #1
GreatDane OP
BMW GS Team Denmark
GreatDane's Avatar
Oddometer: 73
140/80 TKC80 on R100GS PD?
Hi guys,
It's time for me to change the rubber on my dad's R100 GS PD '92, but I need your advise on the best of two lesser alternatives.. Should I fit the 130/80-17 Tube type, that I happend to order in stupidity , or should I fit my spare 140/80-17 Tubeless (from my HP2)? I'd like to go with the tubeless for obvious reasons, but i'm not sure the rim on the R100 will hold it, since the 140/80 is especially made for the HP2.. Am I wrong and whats your advice?
\Jasper
SmugMug 5$-off coupon code..
aJ5En8uNAMkj2
GreatDane is offline   Reply With Quote
Old 03-24-2007, 05:01 PM   #2
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,256
I believe you will have clearence issues to the swingarm with the 140's. You can fix this with an olfa knife :)
Ron Seida is offline   Reply With Quote
Old 03-24-2007, 06:32 PM   #3
GearHeadGrrrl
Oddometer: 394
The 130/80-17 Gripster just barely clears the swingarm on my R100GS. There is a couple millimeter thick spacer for the K100 that would the wheel out a bit, but probably not enough.
GearHeadGrrrl is offline   Reply With Quote
Old 03-25-2007, 09:03 AM   #4
Motomech
Adventurer in Latin Amer.
Oddometer: 337
Originally Posted by GreatDane
Hi guys,
\Jasper
Due to sketchy tire availability here, I mount tube-type tires tubeless all the time. Never had any problems aside from a couple of frt.s that lose a couple of pounds a week. Hardly a problem though.
Motomech "One modification a day"
'92 BMW R100GS Bumblebee
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
"The BMW Airheads, riding yesterday's technology the day after tomorrow".
Motomech is offline   Reply With Quote
Old 03-25-2007, 10:31 AM   #5
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
is that possible? i wanted metz tourrance but my tire dealer only had a tubed rear. he doesn't recommend using it tubeless. so i settled for the pirelli scorpions, which i'm happy with and look more "trail-appropriate" than the tourrance.
to the original poster, the 140s will definitely foul the swingarm. did you notice how little te remaining clearance is using the correct 130 tires?
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 03-25-2007, 07:29 PM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
If your problem is simply clearning the swingarm and shock, etc, there's an inexpensive spacer that I believe is a bmw part.
Solo Lobo or one of the guys on here has the part number.
datchew is offline   Reply With Quote
Old 03-26-2007, 06:35 AM   #7
GreatDane OP
BMW GS Team Denmark
GreatDane's Avatar
Oddometer: 73
Thanks you guys, i'm gonna fit the 130/80-17, but with the tube.. I think is the better solution of the two alternatives. Although I've also heard of others using tube-type's without ever putting a tube in, I wont risc anything since its not myself riding the bike.
Great input from all of you...
\jasper
aJ5En8uNAMkj2
Old 03-26-2007, 09:18 AM   #8
Motomech
Oddometer: 337
Sure it's possible. The only difference between a "tube" version and a "tubeless" version of the same tire is that the "tubed" tire lacks a membrain(sp?) that is supposed to prevent leakage thru the carcuss.
On the rear, I've used both Metzelers and Pirellis(made in Brazil)tube-types and neither lost any appriecible air.
Metzelers:I've used the genuine German-made, steel-belted radial 130/80(pricey here, $200, as they are imported to the States and then imported here) and while not my favorite tire(they are a little small and hard riding), they will outlast every other tire(and I used many different ones)by a factor of at least 2. Perhaps their long service life is a factor of the stiff carcuss, not allowing as much heat to build up. The Brazilian made Enduro 4 (120/90), which I assume uses the same compound, is only good for 3,000 miles, while the Tourance will more than double that.
Pirelli Scorpions: I am currently running a ST 90/90-21 front and I would have to say that it's the best tire I've had on the front yet. a little less aggressive than the fast-wearing Metz. Enduro 3 Saraha, it still has enough grip for dirt roads(the extent of my off-roading with these bruiser bikes), but is quieter and has been wearing very well. The ST is not available in the raer 130/80 size and I'm thinking about looking for an AT in that size. The more streetable AT would still be plently aggressive for the rear of these models(where the hefty weight assures traction, at least going up-hill). It could be that the ST front/AT rear combo could be a real winner on the GS's.
Note; I run Anakees here in the rainy season, a great, but fast wearing rain tire.
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
Old 03-26-2007, 11:57 AM   #9
Motomech
Oddometer: 337
\jasper
My experience has been, the inner contour of the GS wheels do not lend themselves to tube fitment. I have pinched two tubes on the sharp edges that border the center channel of the wheel. Granted, this was off-road and the tire pressures were low, in the low 20's p.s.i.
On the road, I think tubes would be safe enough, as safe as any wheel fitted with tubes, but never as safe as running tubeless.
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
Old 03-26-2007, 11:43 PM   #10
Steve G.
Steve G.'s Avatar
Oddometer: 6,978
The best tires for the R100GS is the Metz Sahara 3. It was designed specifically for this bike, specifically for these wheels. And 130mm is the biggest I'd put on the rear of this bike, there will probably be clearance issues, and, the rim will be too skinny for this tire.
That said, in the 16 yrs I've had an airhead GS, I've found pricing of Sahara 3's to be silly expensive in Canada, so have been using Avon Gripsters. Not quite as sticky on the street, but they give you fair warning, and the price is right.
Steve
Steve G. is offline   Reply With Quote
Old 03-27-2007, 01:29 AM   #11
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Yeah, what the heck. I use Pirelli Scorpions, tubed front and tubeless rear. And the rate of air loss from both appears to be the same. But in the absence of stocks, I will always go for the combination that offers a tubeless rear for safety.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 03-28-2007, 12:26 AM   #12
Big B
Luft Kopf
Big B's Avatar
Oddometer: 242
No clearance issues
Hi all
I am currently running a 140/80-17 Anakee on My 93 GSPD with Wilbers remote shock with no clearance issues(from PO), can just get my little finger between the tyre and Spring. I have a set of Heidenau K60 130/80-17 and 90/90-21 to go on very soon.
Big B
93 R100GSPD
Ride Reports
The Road to Nowhere
The Plan is there is NO PLAN! A Vietnamese Odyssey
"Semper in stercore versor, solum altitudo mutat"
Big B is offline   Reply With Quote
Times are GMT -7.   It's 05:33 AM.
