Old 03-24-2007, 09:48 PM   #1
Jvarner01 OP
Oddometer: 3
Question Need Some Hawk advice.
How's It going fellas, Im new to the forum, and feel honored to be here.
Now that formalities are out of the way, I need some advice.
I have just recently purchased a 1988 Honda Hawk Gt Nt650, Bone-Stock, except for a Corbin seat, Do any of you know any relatively inexpensive mods for this bike to increase performance?
Lets start with pipes...
Jvarner01 is offline   Reply With Quote
Old 03-25-2007, 07:00 AM   #2
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,767
Thumb
I have a Twobros, I like it a lot.Go with factory Jet kit if you want to get into the carbs. I have racetech in forks, and Fox shock. I like Metzlers for tires. That enough to get you started?
BTW, the forks are same as F2-F3 and CB1 if you wanna lower those bars, easy swap with Clip-ons
'twas ever thus
dfc is offline   Reply With Quote
Old 03-25-2007, 09:21 AM   #3
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,301
Mine has the stock pipe and a jet kit, tuned on a dyno. Improved the mid-range, with a loss of mileage. From what I understand, if you want power out of these, you need to open the airbox before anything else (including a pipe). There is a lot of restriction there.
I would do suspension and brake mods. The forks are the same diameter as the F2/F3, but are not cartridge style. Progressively wound springs and a Race Tech emulator will do wonders up front. The stock shock is a joke after 10-20k miles, and not worth rebuilding. I have a Fox that is fully tuneable, though they don't make motorcycle shocks anymore.
Put a braided brake line on the front to improve the feel in the front. The rear is more than adequate.
And don't forget to ride the damn thing.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 03-25-2007, 10:56 AM   #4
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,271
I have had a lot of Hawk's through the years and built a lot of them.
My opinions:
Better fork springs
Slip-on, the stock headpipes are decent for stock motors.
Take the airbox cover off and use fender washers through the bolts to hold the air filter in.
Factory jet kit
Lower bars, poor mans method, mount the stockers under the upper triple clamps
good rubber
Enjoy it!
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is online now   Reply With Quote
Old 03-25-2007, 11:17 AM   #5
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,683
Cool bike-
Have a pic?
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 03-25-2007, 11:26 AM   #6
Jvarner01 OP
Oddometer: 3
Thanks! now it looks like I have some work to do
I really appreciate all this help, and figured you guys would come through!
thank you.
As requested, here is a pic.
Old 03-26-2007, 06:11 AM   #7
dfc
dfc's Avatar
Oddometer: 2,767
Same Color as mine!
I should mention mine came with a Supertapp, I liked it too, full stainless is nice, I just wanted to change............
I also removed the airbox and installed Pod filters(foam).
Stainless front line is nice also, stock brake is adequate for my needs
Beware the Dynojet kit for this bike, go with Factory
'twas ever thus
Times are GMT -7.   It's 03:43 AM.
