Old 09-23-2012, 09:00 AM   #121
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,124
Originally Posted by warewolf View Post
It's not a 100% failed fuse then, because this morning it was showing 17:29. Definitely needs investigation.
Today I left the bike idling for a while and then stalled it. I couldn't start it again, didn't get any instruments when kicked so probably the idling sucked the life out of the battery. Left the bike alone for 3-5 mins, then when I turned the key on I got instruments and it kicked into life easily.
That does sound like a failure inside the keyswitch when the instruments goes wonky... Also check the wire cluster that are ziptied to the fairing/dash support brace and see if any of the underside wires have rubbed raw and are shorting against the brace... Electrical stuff sucks....
A poor battery does cause all kind of grief with the whole system, I tried to milk a few extra months out of one years back and it made the bike very quirky to start, even with the kicker... When I finally replaced the battery I also had to replace the starter clutch as a related issue... What happened is the weak battery did not engage the starter with enough force to spin the sprague into a good bite on the drum... So the sprague would slip a bit with each start with the weak battery... By the time I put a fresh battery in the sprague was so marred up that it would not hold the drum with the extra gusto from the new battery and just made that horrible slipping squeel...
640 A x 2
BC RIDING 2014
gunnerbuck screwed with this post 09-23-2012 at 09:10 AM
gunnerbuck is online now   Reply With Quote
Old 09-23-2012, 11:15 PM   #122
bmwktmbill
Traveler
Oddometer: 5,049
Guys,
Just did my keyswitch, can't say I enjoyed it at all.
Hard to get apart, hard to get off(needed a short Phillips to remove and a couple of small screw drivers to release the tangs).
It was dirty inside, my wiring was solid.
It was worth doing as my ignition would cut off every so often at speed.
That was a bad feeling.
Of course the dash light didn't work either.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-13-2012, 04:20 AM   #123
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,527
You da man! Right problem, wrong wire
I put my new Shorai in, turned the key on... nuthin'
Check the power socket on the dash which feeds straight from the battery via a fuse, 0 Volts. Bugger.
Check the battery terminals, 13.2V. Hmmm
Check the fuse box (terminals are exposed on the underside) input from battery, 0V. Ok, there's only 100mm of wire left to check! Yup, the main feed from the battery had broken at the battery terminal crimp shared with the starter feed. Pulling the rubber boot back has finally and fully separated the wire. Crimp on a new ring and we are away!
The old battery was 12.84V so not completely dead, but well below par. Most likely was the broken wire causing me grief, but I am certainly not begrudging that 7.5 year old battery anything, or the new Shorai which was available locally for 63% of the price of an Odyssey.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf screwed with this post 10-13-2012 at 04:32 AM
warewolf is offline   Reply With Quote
Old 10-13-2012, 10:11 AM   #124
bmwktmbill
Traveler
Oddometer: 5,049
Good on you Colin....
You dodged a bullet not having to go at the ignition switch.
Wish you would come over and touch my battery. I rarely get 12.8V, usually less with everyday running.
bill
Bill Shockley
Old 10-13-2012, 01:26 PM   #125
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
bill
battery's not a bad investment bill
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 10-13-2012, 08:36 PM   #126
It'sNotTheBike
Oddometer: 704
Especially if you spend your money on a good battery.
This thread is well worth reading, but if you want to save time and just read
the executive summary read post 160 on this page :
http://advrider.com/forums/showthrea...770364&page=11
The point of the above thread is that some batteries are better. To wit :
http://antigravitybatteries.com/
Personally, I think Antigravity should send Bill a battery for free. Bill
has been there and done that, and worn the t-shirt out too,
and he deserves some sponsorship. Maybe if some of us email Antigravity
it could happen.
info@antigravitybatteries.com
It'sNotTheBike screwed with this post 10-13-2012 at 08:46 PM
It'sNotTheBike is offline   Reply With Quote
Old 10-14-2012, 01:53 AM   #127
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,527
...again! I'd only just done that a couple of weeks ago.
Cheers,
Colin
The Stable
Old 10-15-2012, 01:08 AM   #128
bmwktmbill
Traveler
Oddometer: 5,049
[/QUOTE]The point of the above thread is that some batteries are better. To wit :
it could happen.
info@antigravitybatteries.com[QUOTE
It's not the bike,
I have done nothing special.
Never seen the Sahara or the Himalayas.
I am still hoping.
Dreaming....
Let's rob a bank?
bill
Bill Shockley
bmwktmbill screwed with this post 10-15-2012 at 01:18 AM
Old 10-15-2012, 01:35 AM   #129
Sierra Thumper
Oddometer: 641
Thumb Battery tenders are awesome!!
Guys keeping your batteries on a tender when not riding them can save you a ton of problems, cash, and frustration. All my bikes stay on tenders when not being ridden...my 04 busa and 06 zx14 are still on the original batteries, and I get 8+ years of solid starting out of a battery before its time to replace on the other bikes.
Have never had a starter or other electrical problem/quirk yet on these bikes, and they fire up instantly even after sitting all winter.
Its amazing how much better your bike can behave with a well charged battery
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-15-2012, 06:20 AM   #130
Grreatdog
Grreatdog's Avatar
Oddometer: 10,731
+1 on good battery tenders.
My boat batteries are going on ten years old and the four year old Yuasa that came in my LC4E is still going strong. Guess what they all have in common......
525EXC, 640 Enduro, XT200
Grreatdog is online now   Reply With Quote
Old 10-25-2014, 03:10 PM   #131
Casejeep
Casejeep's Avatar
Oddometer: 736
Anyone have a problem keeping the battery charged? The draw when the bike is off is minimal and yet a brand new battery goes dead overnight?
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 10-25-2014, 04:19 PM   #132
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,124
You need to find out if it is a faulty battery or an actual current leach on the bike... With the battery hooked up measure the overnight voltage change and then do the same with the battery unhooked... If the voltage does not change when unhooked after an overnight then you have a current drain on the bike in the form of a small short or something..
640 A x 2
BC RIDING 2014
Times are GMT -7.   It's 12:19 PM.
