Old 04-25-2011, 09:22 AM   #3511
andrewgore
Gôremā
andrewgore's Avatar
Oddometer: 3,620
Originally Posted by a1fa View Post
You bring me your G450X, and I install you a 6th gear by trading you for my WR250R with 6th gear built-in from the factory.
Heh, I'll be passing on that.
Stagehand,
I've got an 8gig card in the thing. I tend to not run continuous shooting though. It makes things easier when I go to edit later on. As far as the HD squashing, it could just be that the video hasn't completely processed yet in youtube. I thought I had the same problem at first when I uploaded and only had 240. After a half hour or so, I had full 1080p.
I'm going to have to pick up a chest mount setup for mine. I like how it shows the abuse that gets taken when riding trails. Should make for some good video
Andrew
andrewgore is online now   Reply With Quote
Old 04-25-2011, 02:20 PM   #3512
DoctorIt
vrooom!
DoctorIt's Avatar
Oddometer: 5,690
Originally Posted by Stagehand View Post
ANdrew- nice video Looks like from the time frame you were using a 1 gig card? Same here: little different terrain, slightly younger bike. Sorry for the jumpy action. We dont have OHV parks out here, so we kinda have to run under the radar.
(at 6:09) I've said the same thing on SO many occasions!!
Erik
Professor for hire.
DoctorIt is offline   Reply With Quote
Old 04-25-2011, 02:26 PM   #3513
Wild Man
Escape Artist
Wild Man's Avatar
Oddometer: 1,471
Oil cooler options
After lots of searching I seem to have found the basis of the oil cooler set-up used on the original G450RRs (Verhoeven's) as shown earlier in this thread
The Twin-Air oil cooler system uses an open 9-tube radiator and has fittings for nearly every standard manufacturer.... except of course the oddball beemer.
It appears that Verhoeven and crew used two of these systems in series, allowing for maximum oil cooling and capacity for the Dakar. Easy enough. The question now becomes how to best tie such a set-up into the 450 powerplant? The stock versions just replace the oil filter cover but the G450 might be more complicated - or not.
Could it really be that the only way to accomplish an oil cooler tie-in is the major modifications seen here in Bobby's (BMW Atlanta) pic?
Any insights out there on how to best accomplish this while keeping MAJOR modifications to the engine block to a minimum? If not, it would explain why Speedbrain chose to not go down this rabbit hole with their "production" G450RR offerings.
Ideas? Relevant experience?
Tuareg Rally 2013 Team Info, Event Updates, Links for T-shirt schwag, and more!
Wild Man is offline   Reply With Quote
Old 04-25-2011, 02:41 PM   #3514
andrewgore
Gôremā
andrewgore's Avatar
Oddometer: 3,620
Wild man,
Funny you should bring this up. I was actually about to design up an oil filter cover like the one in the picture. It should make tying in an oil cooler like the gold one in your picture there pretty simple. I had to do "R&D" on the shock mount pieces this weekend. All work and no play.....
Andrew
Old 04-25-2011, 03:10 PM   #3515
Wild Man
Escape Artist
Wild Man's Avatar
Oddometer: 1,471
Originally Posted by andrewgore View Post
Wild man,
Andrew
Excellent! In that case, put me down for your first production model (or second prototype - I'm not picky)
My only concern was why they would tap into the motor as they did and not just come in through the oil filter cover - unless there's some issue about how it flows that wouldn't make it functional that way. I haven't studied the oil schematics enough to follow the "flow" and see what makes sense.
Regardless, I'm committed to solving the issue one way or another so count me in!
The shock mount looks interesting as well. I'll stay tuned for more "R&D" results from your "work" in the field.
Thanks Andrew.
Old 04-25-2011, 03:13 PM   #3516
The Shred
Airventurer
The Shred's Avatar
Oddometer: 425
You got your own enduro camp!
The Shred is offline   Reply With Quote
Old 04-25-2011, 04:21 PM   #3517
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Originally Posted by FreeTheBeast View Post
BMW G450X changing countershaft sprocket
1. Remove cap on right side frame and screw (swing-arm axle).
2. Remove screw on left side of swing-arm axle.
3. Remove pinch bolts (all 3) from swing-arm.
4. Remove nut (large, left side) with pin wrench (Touratech tool).
5. Remove pivot shaft (axle) and taper roller bearing from right side.
6. Pull swing-arm to rear to remove.
7. Remove c/s sprocket (pinion) two (2) screws and lock washer.
8. Remove pinion.
Install - reverse steps.
1. Torque on pinion screws: 6 Nm
2. Move swing-arm into initial position.
3. Lubricate axle and taper roller bearing and install.
4. Tighten nut (pin wrench) 8 Nm. Make sure that correct tightening torque is applied. This is how bearing play is set.
5. Push the swing-arm to the left in the frame until it is seated against the spacing bushing. The spacing bushing moves as the swing-arm pivots.
6. Tighten 3 pinch bolts. Left: 38 Nm. Right (2x each side, alternately): 19 Nm
7. Use a grease gun to lubricate the inside of the pivot shaft (axle).
8. Install screw into left side of pivot shaft. 8 Nm.
9. Grease right side pivot shaft. Install screw. 8 Nm.
10. Install cap on right side.
Thanks a TON!
Old 04-25-2011, 04:37 PM   #3518
andrewgore
Gôremā
andrewgore's Avatar
Oddometer: 3,620
Thanks Andrew.
I'll keep posted for sure. I spend most of my time at work doing mold designs and not machining anymore. Which is nice, cause I enjoy machining, but for work it's not as fun. Making bike parts is far more exciting to me
I'll aim to tackle it this week, but might be looking more like next week. I've got a YZ to rebuild tonight. Oh the fun!
Andrew
ps. Oddly enough, the dealer had the missing brake part in stock. Now to just make my way out there this week too.
Old 04-26-2011, 06:40 AM   #3519
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Haha- frickin stalling factor!... added to the fact that is a pretty steep slope- when it stalled I flailed like crazy on the downhill side, but decided it was better to eject than ride it down
Oh! Ithought you were talking about the get-off. SAme stalling factor, though
Unintentional psychokinesis.
Stagehand screwed with this post 04-26-2011 at 09:04 AM
Stagehand is offline   Reply With Quote
Old 04-26-2011, 08:52 AM   #3520
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Adjustable rear ride height
Found a new swingarm with adjustable rear ride height.
Just go try it now
Cheers
Pilbara
PS: also found that with this new swingarm the rear ride height can be raised by 50mm and lowered by 30mm.
Pilbara screwed with this post 04-26-2011 at 09:23 AM
Pilbara is offline   Reply With Quote
Old 04-26-2011, 09:01 AM   #3521
Wild Man
Escape Artist
Wild Man's Avatar
Oddometer: 1,471
Old 04-26-2011, 09:30 AM   #3522
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
WP Trax Shock
Hello Tundra61, you asked
Originally Posted by tundra61 View Post
are you familiar with the WP Trax shock on the bike? If so, what have you heard?
Sorry mate, have not heard or have any experience with this. I will be interested though as playing with shocks is on the to-do list.
Cheers
Pilbara
Old 04-26-2011, 05:45 PM   #3523
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
I want your G450X...
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 04-27-2011, 12:27 AM   #3524
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,965
You must regret getting that WR250R...
BTW... I love my G450x
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is online now   Reply With Quote
Old 04-27-2011, 01:29 PM   #3525
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Not at all. I do not regret it one bit. I decided to trailer to the trails, vs ride on the road for extended periods of time.
Times are GMT -7.   It's 02:41 PM.
