Old 08-04-2011, 01:46 AM   #4156
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
300mm Brake Rotor - Front
Has any one a recommended supplier for a 300mm brake rotor for the front of the G450X? I know caliper has to be moved out, reason is I am mounting up a set of Marzocchi 50mm Corse forks and the mounts are out further.
Cheers
Pilbara
Pilbara screwed with this post 08-05-2011 at 11:08 AM
Pilbara is offline   Reply With Quote
Old 08-05-2011, 07:09 AM   #4157
DESERT SCORPION
SINGLE TRACK
DESERT SCORPION's Avatar
Oddometer: 130
Oil filter cover wrench
Originally Posted by WildeBees View Post
@GX-Man , I've tested an old 7/8th socket and even if it is 22.22mm it fitted better.
I also use a 7/8 socket. It is a good fit after grinding back the front of the socket which had a fairly deep countersink on it. Not good when trying to engage the very shallow hex on the filter cover. After the modification, there is full engagement with the cover, and it works fine. I use a stubby ratchet when installing the cover due to the aluminum on aluminum threads. It always stays tight, and breaks free nicely at the next oil change.
THE SCORPION
DESERT SCORPION is offline   Reply With Quote
Old 08-05-2011, 07:46 AM   #4158
KarlNum
Go Dam It, GO!
Oddometer: 55
Lambda Probe? New Header Pipe
My new exhaust head pipe does not have a place for the Lambda Probe to thread into, what do I do? Do I need it? If not what do I do with the Probe and wires? Thanks!!! Kyle
KarlNum is offline   Reply With Quote
Old 08-05-2011, 09:31 AM   #4159
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Unplug it.
KarlNum asked:
Hello Kyle, No you don't need it, It runs fine just uses a little more fuel if you keep the throttle open a lot. It has a connector that you just pull apart after pushing the release clip. Just tape up the plug on the wiring loom to keep it clean and dry. Turf the Lambda in your tool box.
You could just buy a nut to suit the lambda sensor and weld it on to the header pipe and drill a hole. I was able to machine a radius in the nut to suit the diameter of the header tube and it fitted well. Like I said, you do not need it as the computer will just use the fixed fuel map.
Cheers
Pilbara
Old 08-05-2011, 09:36 AM   #4160
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Fork Protectors for Marzocchi Corse
I am hoping someone can point me to a supplier of fork guards/protectors for Marzocchi Corse USD 50mm forks. I have fitted these up to my 450, but the protectors from the standard OEM 45mm forks don't fit. The mounting bolts are not locateed in same place.
I have spent many hours searching the net but can not come up with anything, infact can't seem to find anything on the forks at all.
Any leads would be greatly appreciated.
Cheers
Pilbara
Old 08-05-2011, 09:59 AM   #4161
KarlNum
Go Dam It, GO!
Oddometer: 55
Cheers
Pilbara
Check with your Husky dealer, my 2008 TE250 had 50mm on it.......
Old 08-06-2011, 03:33 PM   #4162
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
Just Grabbed the Last One!!
So this is me getting ready to leave Max's with a new to me 2009 G450X
When I got home I put on the Acerbis Handguards and a real bash plate
Now to get into some woods and ride this thing - local roads around here shows a stout and nimble ride.
Great thread going here - hope to see some of you guys on the trails!
2011 R1200 GS Adventure Smoke Grey Metallic Matt
2009 G450X White
IBA #35651
Semper Fi is offline   Reply With Quote
Old 08-07-2011, 05:16 AM   #4163
DoctorIt
vrooom!
DoctorIt's Avatar
Oddometer: 5,679
Cool - another New Englander! Don't rush on the bash plate - I've said it before, and I'll say it again, thick plastic is every bit as good as thin metal. The stock piece is much sturdier and better covering than it lets on.
Erik
Professor for hire.
DoctorIt is offline   Reply With Quote
Old 08-07-2011, 08:13 AM   #4164
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
too late already put it on
I will however keep the orginal
Any suggestions for a centerstand or something to hold the bike up?
2009 G450X White
IBA #35651
Old 08-07-2011, 06:18 PM   #4165
tundra61
I wish I had a title
tundra61's Avatar
Oddometer: 1,021
I find that with the alum skid plate the bike rests easily on a normal mx stand.
Other mods I would suggest
1. Rear lift strap
2. Small led directionals
3. Led tail light
4. Full hand guards if that's not what you already have.
If you have the money (in priority order)
1. Get the suspension tuned. I had Dicks in ca do the front and have the speed brain WP shock in the rear. Suspension work will make a difference no matter what your riding level.
2. Neutech tubliss setup
3. Touratech header guard
4. Touratech rear rack ( do not get the BMW rack)
5. Touratech rear break cylinder guard
6. Touratech seat
7. Leo Vince or akrapovik exhaust
Lots but currently:
2011 Harley Road Glide
2012 BMW GSA
2012 KTM 350 XCF-W
tundra61 is offline   Reply With Quote
Old 08-08-2011, 04:15 AM   #4166
Gearhead001
Nut
Gearhead001's Avatar
Oddometer: 75
1. Rear lift strap
3. Led tail light
6. Touratech seat
What LED tail light and directional's do you recommend? I like the ones installed on Semper Fi's bike.
Gearhead001 is offline   Reply With Quote
Old 08-08-2011, 05:18 AM   #4167
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
Those were/are stock
2009 G450X White
IBA #35651
Old 08-08-2011, 05:20 AM   #4168
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
1. Rear lift strap
3. Led tail light
6. Touratech seat
Thanks!!!
Where can I find something on the lift strap I noticed that this will be a huge help
All the other stuff is going on the wish list - again thanks for the time outlining these items
2009 G450X White
IBA #35651
Old 08-08-2011, 06:21 AM   #4169
Gearhead001
Nut
Oddometer: 75
Interesting. I have the big ugly tail light on my '09. The smaller lights must have been misplaced before delivery.
Old 08-08-2011, 04:46 PM   #4170
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Hdb
Hello Semper, Highway Dirt Bikes make some neat LED units for the rear and have them integrated into the hand-guards at the front, that are awesome.
'they also have fold out mirrors, which keeps it legal, but out of the way.
...and if you are real keen, Bert's tanks have two great aluminium grab handles built in to the back of them, won't need the grab strap then
Cheers
Pilbara
Thanks!!!
Times are GMT -7.   It's 12:24 AM.
