Old 02-26-2013, 08:04 PM   #5566
GratefulKicks
GratefulKicks's Avatar
Oddometer: 167
yea that setup looks dope....more info please! Good luck at SandBlast!!
2014 KTM 350 XCF-W and 2013 KTM 350 350 XCF-W
2009 BMW G450X (SOLD)
2006 Kawasaki KLX 300R (SOLD)
GratefulKicks is offline   Reply With Quote
Old 02-26-2013, 08:44 PM   #5567
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,490
Looking great! Did you upgrade the stator or not neceassary. Any info on this from anyone appreciated.
BiG DoM
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... 'Fuck, what a trip!'
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcyclists.
BiG DoM is offline   Reply With Quote
Old 02-27-2013, 11:28 AM   #5568
Lamented
Oddometer: 486
Fubar
Looking for help. Advice.
My 2009 had a charging issue and was dropped an independent dealer 3 months ago for repair. Bike is still under warranty and has around 120 hours on it.
I asked them to look over the bike, check a few things and give it a once over (it was new to me, bought from a fellow inmate).
They said it had a bad stator which would be covered under warranty.
They said the clutch adjustment was maxed so I asked them to measure the plates and they were a little under spec so I said do the clutch. (not warrantied)
they said they checked comp (75%) or thereabouts as I remember and there was some blow by in the valves. They asked if I wanted to rebuild the top end. Not under warranty.
I said the bike runs fine (other than the charging) and the loss of power didn't bother me. Don't rebuild it.
a month goes buy no word, so i call... they say they cant get it to charge with the new stator. Replacing the whole harness, will take a while.
call again, replaced the whole wiring harness, stator and bike wont start, we will call you back
finally they call and say bike wont start. they retested compression and its basically ZERO. Blow by is 100%
they want me to do the full rebuild on my dime or come get the bike.
I dropped off a bike that ran fine but drained batteries. They want me to pay for a rebuild on a motor that was running when I dropped it off.
BMW NA has not been any help. They offered to get cash for time the bike has been down. But nothing else they can do.
What do I do?
The same dealer also did a cam on the bike under warranty 600 miles ago and the last full service.
A little armageddon is good for you.
Lamented screwed with this post 02-27-2013 at 11:36 AM
Lamented is offline   Reply With Quote
Old 02-27-2013, 12:37 PM   #5569
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
sounds like they butchered your bike... and want you to pay to fix it..
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 02-27-2013, 01:44 PM   #5570
kiwiAdventure
kiwiAdventure's Avatar
Oddometer: 1,409
If you have a friend who is a lawyer get them to send the dealer a letter.
BMW 1200gs 16
BMW 450 enduro 09
kiwiAdventure is offline   Reply With Quote
Old 02-27-2013, 03:19 PM   #5571
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,729
I really hate to say, but kiwi is right. It sounds like you need a lawyer. You might also check the lemon laws in your state to see if they apply also. Finally, the clutch replacement was covered for me when I took it in, though I suspect it was done instead of the torque limiter, which is probably the real problem.
On another note, anyone have a set of forks to sell?
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is online now   Reply With Quote
Old 02-28-2013, 05:40 AM   #5572
jack splash
Two Sheds
jack splash's Avatar
Oddometer: 2,350
More Info
Originally Posted by compositeboy View Post
Daaaaamn! What can you tell us about the rear tank and and the headlight/fairing?
Hey: Thanks for the posts about the bike. I'm busy getting ready for the rally and will answer questions when I return.
Jack
Stay dirty my friends!
Bigfoot has a picture of me!
www.pinebarrens500.org
www.pinebarrensadventures.com
jack splash is offline   Reply With Quote
Old 02-28-2013, 08:52 AM   #5573
tundra61
I wish I had a title
tundra61's Avatar
Oddometer: 1,014
I have forks and OEM triple clamps I would sell. PM me if interested.
Lots but currently:
2011 Harley Road Glide
2012 BMW GSA
2012 KTM 350 XCF-W
tundra61 is offline   Reply With Quote
Old 02-28-2013, 11:07 AM   #5574
fenske
fenske's Avatar
Oddometer: 29
fuel brether tube
i have a new 2010 450 that kicks butt, but the fuel breather tube keeps spitting fuel??? anyone else having his issue? any tricks on stopping it?
fenske is offline   Reply With Quote
Old 03-01-2013, 03:25 PM   #5575
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,957
This may be a case of "They all do that, sir"
I get a strong smell of fuel on mine, but only at the start of the ride. After a short while, the smell goes away.
The breather connects to the tank just behind the filler and comes out in front of the radiator. So you can probably smell it more than you would on other bikes which have breathers either on the cap itself or ends below the frame.
You could put on a Safari tank, which feed the main tank through the breather, then only half fill the safari tank. I've never noticed the fuel smell when I had either of those tanks on (I have both the front and rear tanks). These tanks have the breather through the cap.
If, on the other hand, you are seeing lots of fuel literally spraying out from your bike, then I suggest you take it to a mechanic, as there is something definitely wrong here.
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is offline   Reply With Quote
Old 03-01-2013, 06:12 PM   #5576
ScienceOfDirt
U-Boat Rider
Oddometer: 1,729
FWIW. Mine only leaks or smells after a tip over.
Old 03-01-2013, 06:20 PM   #5577
FreeTheBeast
Shunpiker
FreeTheBeast's Avatar
Oddometer: 3,046
Cool2 Racing my 450 at Sandblast
Here it is a parc expose tonight after the shakedown. Stage racing happens all day tomorrow.
Chesterfield, South Carolina
Think beyond yourself.
The Hampster Ride - A mainly dirt route to ride the length of New Hampshire.
Max the Motorcycle - children's book written by Mrs. FTB
SmugMug Photo Gallary
FreeTheBeast is offline   Reply With Quote
Old 03-01-2013, 07:13 PM   #5578
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Good Luck Andrew! Stay safe! Bike looks great.
We put the clear fuel tank on ours, the son having been fooled by the fuel gauge a few times, and running right out.
Emmbeedee is online now   Reply With Quote
Old 03-03-2013, 05:04 AM   #5579
Muecke
Muecke's Avatar
Oddometer: 75
Hi,
I want to change the original Marzocchi Shiver 45 fork into a Marzocchi Shiver 50 with Ohlins Cartridge System.
Does anyone know if the axle is the same on these two forks?
And does the brake fit both forks?
Many thanks
Bye
Muecke
Muecke is offline   Reply With Quote
Old 03-03-2013, 07:23 AM   #5580
FreeTheBeast
Shunpiker
Oddometer: 3,046
Cool2 Sandblast Rally
Several BMW G450X bikes in this year's Sandblast Rally. We had a good time. Decent weather and road conditions. Fun times.
Some Dude - all blacked out. 1st in class. 2nd overall.
Crash Dummy - 2nd in class. 7th overall.
Jack Splash - 7th in class. 19th overall.
FreeTheBeast - 6th in class. 18th overall.
Times are GMT -7.   It's 07:35 PM.
