08-10-2012, 08:23 AM
#15661 | |
Are you a Sheeple?
08-10-2012, 08:51 AM
#15662 | |
So much to ponder
Oddometer: 2,545
I can understand your feelings about not needing the weight advantage, but you will be adding a ton of weight with a big tank and other farkles.
Originally Posted by DR. Rock once you leave the pavement, it's like entering a parallel universe... a wormhole in both space and time... sometimes you won't believe you're still in the United States, or in this century. |
08-10-2012, 09:05 AM
#15663 |
Are you a Sheeple?
Two motorcycle batteries in 5 years...doesn't sound like a problem considering the abuse that they take. A guy I used to ride with put a un-named Lithium battery in his 650 prior to going on the CDR this year and it shook a part internally and left him in a lurch part way through. I have enough things to worry about than questionable batteries.
08-10-2012, 01:37 PM
#15664 | |
Meanderthal
Oddometer: 1,392
What I can say about lead acid is that it's a better known technology and when they do break, sometimes you can fix them. Either way, good luck in whatever you decide to do! Here's a post I put on ridedualsport.com in their MacGyver thread: Last week I dumped the bike on the left side and a rock punched a hole in the left side cover. I filled it with JB KWIK and was on my way. Luckily only a little bit of oil had leaked out. A little while later, I noticed the LCD display flickering and stopped to investigate. I guess when I dumped, the negative battery terminal broke loose inside the battery. I was at a convenience store so I borrowed some aluminum foil and wrapped it around the terminal and stuck it back into the battery. It worked good enough to get the bike started and got me home. Broken off terminal. ![]() Since I didn't have the funds for a new battery, I figured I'd bring it into my dual sport luggage rack fabricating shop and see what I could do. I cut away the plastic with a razor blade and saw the broken post. ![]() ![]() So I cleaned up the lead on the terminal and the battery post and put the terminal back in place and drilled a hole down through to accept a screw. ![]() Then I roughed things up and put the JB KWIK to it. I made sure to get it into all the voids and under the plastic cover to lock it all together. ![]() ![]() Then I ground down the screw head so it would fit into the battery box. ![]() Not a brainy MacGyver, but a dependable repair.
Tom - '07 DR-Z400S, '05 DL650 Dual Sport Luggage Racks: DRZ400, DR650, KLR650: http://www.moto-racks.com "I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott jackpiner57 screwed with this post 08-10-2012 at 01:52 PM |
08-10-2012, 01:55 PM
#15665 |
Are you a Sheeple?
That is an awesome repair!!!!
08-10-2012, 02:51 PM
#15666 | |
Cavalera Conspirator
Oddometer: 956
08-10-2012, 03:08 PM
#15667 |
Oddometer: 956
This is the Shorai Lithium Ion I have.....Saved 4 lbs over the SSW Super Start sized batt and cranks my big bore extremely fast.
08-10-2012, 04:01 PM
#15668 | |
Oddometer: 170
08-10-2012, 07:23 PM
#15669 |
Meanderthal
Oddometer: 1,392
Thanks blaster, it's holding up good and I'd swear it has more starting power now.
No, but I'm just as frugal as those guys. I'm from Vermont after all. My neighbor is an old woman who uses ear wax for lip balm.
Tom - '07 DR-Z400S, '05 DL650 Dual Sport Luggage Racks: DRZ400, DR650, KLR650: http://www.moto-racks.com "I sort of realize there's a fundamental truth to our nature. Man must explore." -CMDR. David R. Scott |
08-11-2012, 12:54 PM
#15670 |
Oddometer: 956
[/QUOTE]
08-11-2012, 04:35 PM
#15671 |
Oddometer: 956
While sorting thru my old MX Action mags I found the article from where BBR motorsports built a MX DRZ 400 with a Yoshimura engine. Its in the link below at year 2000 and they called it a RM 400. Its the bottom bike on the cover of the mag beside the year 2000.
http://www.bbrmotorsports.com/Compan...istoryText.htm
08-11-2012, 05:53 PM
#15672 |
Are you a Sheeple?
Manual?
So I recently picked up my DRZ and am in need of a shop manual....any recommendations?
08-11-2012, 08:17 PM
#15673 | |
Meanderthal
Oddometer: 1,392
http://www.tradebit.com/filedetail.p...-drz-400-00-09
08-12-2012, 02:37 AM
#15674 |
Oddometer: 204
Google is your friend. I wish I could remember where I got mine, but managed to find Service manuals and Maintenance manuals for both my DRZ 400 and KLX 650c. They are out there. (for free)
08-12-2012, 02:55 AM
#15675 |
Oddometer: 1,692
The most commonly available "free" manual only covers the earlier bikes... There are subtle differences and if, for example, torque specs for the later cartridge fork internals are required then it is necessary to look elsewhere.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
