08-13-2012, 07:44 PM
#15721 |
Oddometer: 406
It has the rear brake light off of the foot brake and it is in working order. I guess the thing runs with out anything plugged into it. Perhaps I should leave well enough alone?
From what little of it I can trace it appears to head towards the front of the bike.
You, this is me, over. 01 DRZ400E Tagged SSG B screwed with this post 08-13-2012 at 07:46 PM Reason: Added stuff |
08-13-2012, 07:58 PM
#15722 |
Oddometer: 1,692
I was thinking that it might have been an un-lit bike (at least by DOT standards) and someone (if it wasn't you) added a lighting kit with a separate harness to get it tagged.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
08-13-2012, 11:23 PM
#15723 | |
Giant
Oddometer: 89
2010 R1200GSA 2004 KLX400R |
08-13-2012, 11:54 PM
#15724 | |
Butler Maps
Oddometer: 14,458
sweet!
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
08-14-2012, 12:06 AM
#15725 | |
Oddometer: 402
the plug goes to the constant on led running light in stock form with no brake light, that's the orignal drz400e's. from the extra wiring I see, I guess some of the owner may added a dual sport kit to it with a set of tail light assembly and harness as replacment. this is the stock one should look like ![]() Uploaded with ImageShack.us |
08-14-2012, 12:12 AM
#15726 |
Giant
Oddometer: 89
What other sizes would I need to carry, such as on the other end of a tyre lever?
08-14-2012, 05:39 AM
#15727 | |
Oddometer: 777
This is what I generally carry (Keeping in mind that it may be someone elses bike that will stuff your ride up) ![]() Spoke tool Allan keys to suit all attachments on the bike (including for my Nav gear- when in use) Open/ring spanners 8, 10, 12, 13, 14. Suzuki 14/17mm open Pliers. Small blade screwdriver Wheel removal tools Small shifter (someone always foregets to take tools with them) Pointy nose pliers. Valve removal tool. T bar & 8, 10, 12, 13 sockets Sidecutters Tyre levers, chainbreaker Phillips screwdriver Electrical test light. On big trips, I'll also carry some electrical pliers, a bigger blade screwdriver, tools big enough to allow you to remove the front sprocket. I've also just bought a miniature air compressor so that I don't have to bust my gut getting the Dakar tyres up to their recommended 40psi. Don't forget the spares though: An assortment of nuts & bolts for the bike. Some electrical wire, fittings & fuses Tube/s, puncture repair kit Joining link & short length of chain DUCT TAPE & CABLE TIES A rag often comes in handy, as will zip-lock bags (I have even used them to transfer fuel to another bike. )
Have you ever noticed that when you're out on the bike, nothing else matters? http://www.advrider.com/forums/showthread.php?t=709292 |
08-14-2012, 07:32 AM
#15728 |
Oddometer: 205
Kinda siked. I bought all the stuff for using the trucklite 5x7 LED light on my DRZ as a headlight. It was still cheaper than the HID rally light set ups. Just have to wait until I get home late September to do it. Ohhhhh the torture.
08-14-2012, 11:37 AM
#15729 | |
Oddometer: 406
It has a Baja Designs kit on it. Now it all makes perfect sense! Damn you guys are smart
You, this is me, over. 01 DRZ400E Tagged |
08-14-2012, 02:00 PM
#15730 |
Oddometer: 188
434cc Big Bore kits
For those of you that have the BB kits what brand did you install? So far I have found on Ebay
Athena,Cylinder Works and others w/JE pistons.Prices range from $500 down to $320.All seem to be fairly complete with cylinder,piston/rings,gasket set etc. Simple bolt on,uses low grade reg gas(US). So one question I have is does anybody have experience with the $320 kit offered from ApexRacing the Ebay vender? Being the lowest price with no name piston/gaskets/parts taking a big risk? Not in any hurry to buy still researching the farkles and upgrades available for this New to Me '00 E model. Other things I looking into are larger cap.tank,rear rack (got a S subframe if needed for rack choice) Currently have Answer fat bars w/aftermarket top triple that I don't like.Must be the bend/rise ? I will be watching the current discussion on batteries.Mine came with a bikemaster std batt. It will start the bike after sitting 1-2 wks but when it dies if not fully warmed up it will not turn over/restart.Bump starts fine but not always an option.Kick start kit also of interest.Thank you for any input....David |
08-14-2012, 02:05 PM
#15731 | |
Huh?
Oddometer: 508
I would get the Cylinder Works kit. It uses quality components and has a solid track record. The Athena kit is great but over priced.
Pauly '06 DR-Z400S |
08-14-2012, 02:34 PM
#15732 | |
Oddometer: 777
08-14-2012, 03:04 PM
#15733 | |
Scone Rider
Oddometer: 6,719
We don't stop riding because we get old, we get old because we stop riding. |
08-14-2012, 03:08 PM
#15734 | |
Huh?
Oddometer: 508
I don't think JE has any say whether Namura can package their piston in a kit or not.
08-14-2012, 09:19 PM
#15735 |
Giant
Oddometer: 89
