10-04-2012, 08:16 PM
#16426 | |
Oddometer: 1,690
The same can be done with a low oil sensor. It would need a bung in the oil tank and it can be wired to the same or another idiot light and/or through the interlock system.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 10-04-2012 at 08:29 PM |
10-04-2012, 08:23 PM
#16427 | |
Oddometer: 1,690
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 10-04-2012 at 08:43 PM |
10-05-2012, 02:31 AM
#16428 |
I come in Peace!
Oddometer: 160
You Can't Kill a DRZ, but it can Kill YOU!
While out playing with my GoPro's at Willow Springs Kart Track, I high sided and knocked myself unconscious.
Despite walking, talking and answering questions from medical aid, I have no recollection of the crash or anything from just prior to the event, until about half way to hospital. *Warning; Not Graphic, but some may find the audio track entertaining, while others may find it disturbing as I apparently quit breathing for a while. http://www.youtube.com/watch?v=JVk7u...LW4X4F6BXM5nSA
'05 KTM 525 SMR , '09 DRZ 400SM, '02 ZRX1200R |
10-05-2012, 04:50 AM
#16429 |
Oddometer: 1,690
Nova and ACT transmissions are in the Gearing Commander database...
Ignore the years and plug in some sane gearing like 14/47. The bike doesn't have a hope of reasonably pulling the gearing on those pages.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 10-05-2012 at 05:24 AM |
10-05-2012, 11:30 AM
#16430 | |
Oddometer: 214
Anyone know the size/threads for the galley and what sensor might fit? Thanks
"Good judgment comes from experience and experience comes from bad judgment." |
10-05-2012, 05:04 PM
#16431 |
Cavalera Conspirator
Oddometer: 956
The oil drain bolt directly under the oil filter housing is a test port for an oil pressure gauge. Remove that bolt and get a sending unit that fits in that galley, and you have a accurate oil pressure gauge sending unit.
10-06-2012, 02:26 AM
#16432 |
Oddometer: 524
Foot Pegs
My handlebars are CR bend fat bars, with a small rise in the adapters. I had to re-route the cables to get them to work, so I don't reckon I would be able to get much more rise. I'm 6'3" and still feel a bit too bent over when standing. Looking at the foot pegs, there is heaps of room to lower them without protruding below the bashplate. I reckon I could get 30-40mm easy, with the added benefit of lowering my overall CoG. Im thinking i would cut the pin from the peg and weld the pin higher with a vertical piece of flat steel. Anyone done this? Would it work or am I talking bollocks?
10-06-2012, 02:30 AM
#16433 |
Oddometer: 524
Seats
Anyone use the SDG HI seat? How would you rate it for comfort on longer rides? I notice on rocky mountain this complete seat is cheaper then a seat concepts replacement cover.
10-06-2012, 05:40 AM
#16434 | |
Tundra Thumper
Oddometer: 2,226
Check here http://www.wheelingcyclesupply.com/cgi-bin/public.cgi for footpegs. They have "high", "mid" and "low" sets that may work for you, . I really love my Seat Concepts seat, allthough the "gripper" top is really grippy! I got the "add 1 inch" height as I too am 6' 3" and it's good addition.
DONATE TO ADVRider sidestandup.com ridedualsport.com motoboss-terlingua-bound.blogspot.com MSF Rider Coach-Rider's Edge Instructor-Track Coach |
10-06-2012, 05:55 AM
#16435 | |
Oddometer: 524
#16436 |
Tundra Thumper
Oddometer: 2,226
OK, I just bought a new (to me) 2011 DRZ400S. I'm putting several new farkles on it and have a question. Putting new handle bars on I am replacing the grips (obviously) and I can not get the throttle side grip off. I have cut, pulled and done almost everything necessary to remove a grip, but it won't budge. Both ends a hard and I can't even get a small blade between the grip and throttle tube on the bar end.
Is the throttle side grip permanently fused to the throttle tube from the factory? Do I need to buy a new throttle tube just to replace the grip? Thanks for the help..........................
10-06-2012, 06:14 AM
#16437 | |
Oddometer: 37
Its better to be lucky then good. |
10-06-2012, 06:19 AM
#16438 |
Oddometer: 524
Yeh, I did similar. The're a prick to get off. Simplest solution would be to buy a new tube
10-06-2012, 06:22 AM
#16439 |
Tundra Thumper
Oddometer: 2,226
Thanks guys.......I've never had this much trouble with grips.
![]() Going to town today so I may just buy a new throttle tube, just in case my grinding gets to enthusiastic
10-06-2012, 06:23 AM
#16440 |
Oddometer: 1,690
Funny, I didn't think that there was anything wrong with the factory grips so just transferred them onto the new bars.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
