Old 11-14-2012, 10:30 AM   #16441
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,321
Touchy front brake light switch
I was informed yesterday that my brake light is flashing on & off when I am running around 65 mph.
I am pretty sure its my front brake lever as the slightest movement activates the switch & light.
I loosened the screw underneath that holds the switch, but the switch does not want to turn. I assume it has some post it sits on/in.
I was hoping I could rotate it a bit.
Is there a way to adjust the switch so it does activate until the lever is pulled back more.
Ogre_fl is offline   Reply With Quote
Old 11-14-2012, 11:59 AM   #16442
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 16,067
Originally Posted by 0ldhippie View Post
Exactly! Bet there is lots of great open riding over there!
Funny, open isn't a word I'd use. Maybe I'm wrong though.
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is online now   Reply With Quote
Old 11-14-2012, 02:18 PM   #16443
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Could also mean NOT closed by those darn authorities
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 11-14-2012, 03:24 PM   #16444
timsgs
timsgs's Avatar
Oddometer: 54
Originally Posted by 955616846 View Post
Bugger me!!! How about resizing your images.
right click, view image...........
2007 DRZ400s, 1995 Nighthawk 750
Son, don't force that , get a bigger hammer....
timsgs is offline   Reply With Quote
Old 11-14-2012, 05:09 PM   #16445
Oddometer: 532
Smart ass
Good spot though
KLR 650-sold
1977 BMW R100-sold
Old 11-14-2012, 05:55 PM   #16446
150ron
150ron's Avatar
Oddometer: 1,429
Hey drz'ers, i find that with the new 16T front sprocket my chain is way too tight, even on the flat part of the snails, BEFORE the 0, how do i go about adding another link to my chain? one link will make it perfect, i have the master link on it that i can remove and re install, so how would i add another link? or would it be easier and cheaper to just remove the chain again and take it to the mx shop for them to do it, i have no chain tools what so ever.
Just some dude...
150ron is offline   Reply With Quote
Old 11-14-2012, 08:11 PM   #16447
340hp
340hp's Avatar
Oddometer: 156
You need two links, a narrow link & another master link, or you need to add a half-link.
A half link looks like the upper center link in this photo... between two master links, and above a narrow link.
https://www.denniskirk.com/520-stand...it.p113131.prd
340hp is offline   Reply With Quote
Old 11-15-2012, 07:59 AM   #16448
150ron
150ron's Avatar
Oddometer: 1,429
Thanks for that, is it safe to have 2 master links on?
Just some dude...
Old 11-15-2012, 08:16 AM   #16449
Ryel
Ryel's Avatar
Oddometer: 246
I'm sure you know, but if you have the "O" ring chain use the oring master
just to be said
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is offline   Reply With Quote
Old 11-15-2012, 09:07 AM   #16450
340hp
340hp's Avatar
Oddometer: 156
Yes. Two master links are preferred to a half-link, The half-link is more of an emergency measure to get out of trouble.
Just keep the master links clips facing the correct direction, and use the same style links as the chain (o-ring, x-ring, or standard chain).
It used to be common to carry two countershaft sprockets and a short length of chain to allow a lower final drive ratio change when you got to the riding area, and then back to highway gearing before you hit the pavement to return home. This was much easier with cushion hubs as the countershaft did not receive the shock loading from the road with the cush drive, and as a result you did not need to lock down the countershaft sprocket as much. Normal bike tools were capable of wrenching the countershaft sprocket change. A 15 tooth change to a 13 tooth countershaft sprocket will make a significant gearing change, equivalent to a six toot increase on the rear sprocket count, and the parts easily fit in a baggie in a jacket pocket.
The DRZ400 countershaft experiences more shock through the rigid hub & rear sprocket, and the shock demands the locktite & bent french-lock washer to keep the nut from getting hammered loose. The extra torque and locking needed on the countershaft sprocket nut tend to discourage on the road gearing changes, but it's still a viable option with the tools.
You should also try to keep the sprockets tooth count in a odd bias, even tooth countershaft drive mixed with an odd tooth rear driven sprocket, even/odd or odd/even tooth combination. This prevents the chain from wearing in the same link repeating on the same tooth of the sprockets, causing an uneven wear pattern. The uneven wear will shorten both the sprockets and chain life. An odd/odd sprocket tooth combination is also not bad, but an even/even tooth sprocket combination should always be avoided if possible to prevent an poor wear pattern and short sprocket life.
Old 11-15-2012, 10:35 AM   #16451
150ron
150ron's Avatar
Oddometer: 1,429
That is some great info, thanks a lot
the front is now a 16T, the rear is the stock 44, so they are both even, not good according to what you say, i will have to see how to go about changing that.
Just some dude...
Old 11-15-2012, 12:12 PM   #16452
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,097
I think the chain link count factors into this somehow, because I run 16/39 on my SM wheels, and I can easily tell that the inner chain links wear on the same place on the CS. I mitigate this by aligning the chain to a different tooth every time I reinstall the SM set-up.
Starchamp is offline   Reply With Quote
Old 11-15-2012, 12:58 PM   #16453
AtlasExp
beer me
AtlasExp's Avatar
Oddometer: 448
Price drop!!!!!!!!!!
Any body need rack for DRZ! Best price ever!!!!!!!!!!!!!!!!
http://www.advrider.com/forums/showt...667912&page=13
Dual Sport Luggage Racks for: DRZ-S, SM and E and KLR650 and DR650: http://www.moto-racks.com/ Find me on Instagram " ahtoxa007 "
AtlasExp is offline   Reply With Quote
Old 11-15-2012, 08:20 PM   #16454
fifthcircle
Beer Knurd
fifthcircle's Avatar
Oddometer: 5,716
Fucking genius!: lol2
S vs SM:
It sounds like you will be on the pavement more. I think the SM would fit "your bill" best.
If I am wrong, and you will be in the dirt for more than not...the S may be the better choice.
Buying new? I may have missed that if you mentioned it....but I would think you could get a used S cheaper than an SM, simply because there are more of them.
Either way, get a new seat and let'r rip!
Sent from my fat thumbs on a small touch screen.
GRAVEL WORLDS
'14 KTM ADV R - '06 DRZ 400 - lot's of bicycles
fifthcircle is offline   Reply With Quote
Old 11-16-2012, 04:39 AM   #16455
mark1150
mark1150's Avatar
Oddometer: 196
my latest steed, bought a couple of days ago to supplement my trusty XR 400R.
mark1150 is offline   Reply With Quote
Times are GMT -7.   It's 10:53 PM.
